      08-27-2023, 08:28 AM   #1
X6m50dlancs
Drives: Bmw x6 m50d
Idrive screen fault lines showing HELP!
Hi guys, ive just picked up a 2016 plate X6 m50d in the UK which has an issue with the screen. It displays some loss of display on the right hand side of the screen. Im wondering if anybody knows a fix or what the issue is?
When im on normal idrive it goes fuzzy, when i go to reverse camera there is a considerable issue.
Thanks in advance
      08-27-2023, 10:04 AM   #2
stocktree
Drives: x5
You try hitting it?
      08-27-2023, 11:24 AM   #3
X6m50dlancs
Drives: Bmw x6 m50d
Are you serious?
      08-27-2023, 11:50 AM   #4
stocktree
Drives: x5
Originally Posted by X6m50dlancs View Post
Are you serious?
What do you got to loose? Otherwise buy a used one off ebay to save a few bucks.
      08-27-2023, 12:12 PM   #5
X6m50dlancs
Drives: Bmw x6 m50d
I guess you are being serious, were exactly are you propising i hit it?
      08-27-2023, 12:21 PM   #6
Tomcat_F15_STL
Tomcat_F15_STL's Avatar
150
Drives: BMW F15
A likely hardware failure in the display panel.
I would attempt to buy a used replacement and see if the problem disappears.
First step is to pull it out and get a good part number from it. It is entirely possible some coding or firmware updates may be required to finish.
Likely, this one...
or, possibly this one...
      08-27-2023, 03:20 PM   #7
X6m50dlancs
Drives: Bmw x6 m50d
Thanks Tomcat_F15_STL seems plausible ill give it a try
      08-28-2023, 01:49 AM   #8
X6m50dlancs
Drives: Bmw x6 m50d
I also have a feeling it could be a loose or fauoty cable but not sure which one. The readon i say that is because when i go over a bumpy surface the bad sections do appear good. Any help appreciated in locating which cable it could be
      08-28-2023, 05:29 AM   #9
X6m50dlancs
Drives: Bmw x6 m50d
Ok so i got the screen out today and it says part number 65509347878 03, i have found a replacement on ebay from on f15 x5, with part number 65509347878 02. My question is does anybody know if its compatible and whats the difference between the 02 and the 03 at the end of the model number. Thanks
      08-28-2023, 05:48 AM   #10
X6m50dlancs
Drives: Bmw x6 m50d
Also found one with 04 at the end. Would it be a straight swap?
      08-28-2023, 08:20 AM   #11
stocktree
Drives: x5
Read this.
https://blog.fcpeuro.com/understandi...mbering-system
      08-28-2023, 10:31 AM   #12
Tomcat_F15_STL
150
Drives: BMW F15
My thought is that revisions would all be compatible.
Having said that, here is a seller in Germany with an offering for an -03 revision...
Seller's link
      08-28-2023, 11:29 AM   #13
X6m50dlancs
Drives: Bmw x6 m50d
Thanks ive ordered the 04 revision and gona risk it. Ill let u guys know how i get along. Thanks alot for your help everyone.
      08-28-2023, 05:42 PM   #14
Tomcat_F15_STL
150
Drives: BMW F15
You’re breaking new ground! Best of Luck.
      08-31-2023, 12:26 PM   #15
X6m50dlancs
Drives: Bmw x6 m50d
Glad to announce having broken new ground and the innovater that i am the 04 revision is installed and working perfectly. Thank you Tomcat_F15_STL and everybody else who helped me fix this problem. Kind Regards
