      11-13-2017, 03:24 PM   #45
underworldfury
Drives: 2016 BMW X6M
Did anyone ever determine which connector to pull out for the X6M?
Thanks
Originally Posted by R0ut3r View Post
Hi
On X6M looks a little different.
Is the small box on top of amp the ASD unit I have to disconnect? My fat fingers can't reach the connector
      02-09-2018, 03:32 PM   #46
ericliuhc
Drives: M
Unplugged
      02-09-2018, 03:47 PM   #47
kanvas
kanvas's Avatar
Drives: V8
Anyone have before and after videos?
2014 X5 xDrive50i
      02-27-2018, 09:55 AM   #48
withrow79
Drives: 2016 X6m
Thanks
I unhooked mine on my 2016 X6m last night and my car sounds SOOOOOOOO much better now! It is just asinine that BMW puts this in a car and doesn't make a simple setting to toggle it on or off... took me less than 10 mins total. I unbolted it so my fat fingers could easily reach the connector that needed to be removed.
Here's the panel on the driver's side rear that it is behind, a simple pull and it pops out:
Here's what's behind there:
There are two 5/6" nuts that come off easily with a deep socket. You can see the one in the front, but there's another one in the back in the exact same spot.
This is after the first one is removed:
And with both nuts removed and the unit pulled out:
Push the little grey button in and slide the black lever over it and the connector comes right off:
Put the heat sink unit back onto the bolts, tuck the wire and connector up behind there, and re-install the 2 nuts holding the heat sink onto the bracket and voila! Push the cover panel back on and your ears will be saved going forward!
      02-27-2018, 10:47 AM   #49
onfireX5
Drives: F90M5,F85X5M
No doubt the fake sound is terrible. The new M5 has it and is being blasted by the test Mags. I’ll have to figure how to disable that one in March.
      02-27-2018, 08:34 PM   #50
underworldfury
Thanks for posting this. I have my car at OnEighty getting some work done so as soon as I get it back, I'll be doing this.
      03-05-2018, 12:18 AM   #51
underworldfury
Sounds much better with it unplugged. Thanks for sharing.
      08-25-2018, 03:59 PM   #52
fbuzila
Drives: 2023 BMW XM
Just did my f86...thanks for posting
      08-26-2018, 12:08 AM   #53
Apple Corps
Drives: 2018 X5 M
For those that went the fuse approach - what fuse box location and what fuse number please?
      08-26-2018, 02:52 AM   #54
SNAGuy
Drives: 2015 X5M
Disabling ASD by taking out a fuse..
https://f15.bimmerpost.com/forums/sh....php?t=1243856
iconoclast7262.50
      08-27-2018, 06:51 PM   #55
fbuzila
Drives: 2023 BMW XM
There is any wire harness or something that can enable/disable ASD while driving?
You may think I'm crazy but sometimes I want to hear the fake sound
      08-29-2018, 06:50 PM   #56
Johngm45
Drives: 535xi m sport
I can’t find it! I have B&0 stereo if that makes a difference . There are two plugs up top ?
      08-29-2018, 06:52 PM   #57
fbuzila
Drives: 2023 BMW XM
do you have an X6? I can take a picture now if you do...
      08-29-2018, 06:58 PM   #58
Johngm45
I can't find it! I have B&0 stereo if that makes a difference . There are two plugs up top ?
Sorry I have a x5m .
      08-29-2018, 07:08 PM   #59
fbuzila
Drives: 2023 BMW XM
if helpful, it's the plug to that small metal box
      08-29-2018, 07:09 PM   #60
Johngm45
With several wires connected ?
      08-29-2018, 07:11 PM   #61
fbuzila
Drives: 2023 BMW XM
yes, scroll up and you will see a picture; the plug is gray
      08-29-2018, 07:12 PM   #62
fbuzila
Drives: 2023 BMW XM
this one
      08-29-2018, 10:18 PM   #63
F85MTuNED
IG: @88jae88
F85MTuNED's Avatar
1621
Drives: ///Ⓜ️
I'm gonna give this a shot in the a.m. to see if it makes a difference for me.
IM POOR..
      10-08-2018, 02:20 PM   #64
F85MTuNED
IG: @88jae88
F85MTuNED's Avatar
1621
Drives: ///Ⓜ️
So I did it via coding with the Carly app and man what I difference! I rather the the sound of the natural exhaust and my sound system is clear and clean!
IM POOR..
      10-08-2018, 03:28 PM   #65
dorian
Drives: 2017 X5//M
I cannot for one second understand you people that pull the plug on the ASD rather than the fuse.
1) power still going down the cable needlessly
2) takes max 10 seconds to pull the fuse
SNAGuy91.00
F85MTuNED1620.50
iconoclast7262.50
      10-08-2018, 03:41 PM   #66
FrankWright
Drives: 2017 BMW X5M
Just to confirm, it is fuse 129 in the rear cargo compartment?
