      12-10-2023, 11:35 AM   #1
MPizza
MPizza's Avatar
248
Drives: 2015 X5 M-Sport
Heated steering wheel fault code
My heated steering wheel worked fine last winter, but this season it will not work at all.
I press the button on the wheel and the light turns on then immediately goes out. I scanned with Carly and got code 030482: Heated Steering Wheel Short.
I just replaced the main battery and the problem persists. Aux battery voltage looks normal. Any ideas? I searched and found a thread of f30 owners that fixed the issue by "resetting the FEM with ISTA+," however I don't think the f15 has an FEM module.
I've also disconnected both batteries and let the car sit for an hour, but that didn't do anything either.
      12-31-2023, 12:53 PM   #2
gonghao
gonghao's Avatar
Drives: BMW 120i
Maybe you should try to find the resetting option in BDC module?
      01-01-2024, 03:21 PM   #3
MPizza
MPizza's Avatar
248
Is this a real thing? Do I need all the coding files for ISTA+ to do this or can I do it with diagnostics only?
      01-02-2024, 07:57 AM   #4
Qsilver7
Qsilver7's Avatar
When you look up the fault code you listed…for the f15…the fault is in the BDC….but the issue is not the control module…it is a short in the steering wheel’s heating mesh. Perhaps the connections from the steering wheel to the steering column has a short…or the short is actually in the heating mesh itself?
See screenshots below from the BMW fault code website: https://bmwfault.codes/. (Feel free to bookmark this site for future use)
      01-03-2024, 04:19 AM   #5
gonghao
gonghao's Avatar
Drives: BMW 120i
diagnostics only is enough to do so.
      02-02-2024, 03:41 PM   #6
MPizza
MPizza's Avatar
248
For anyone that finds this thread with the same issue, I figured out the cause of this fault. I think generally you can assume the heating element in the wheel is broken in some way. In my case, over the summer I replaced the little stripe on top of my steering wheel because it was worn down. I accidentally severed one of the tiny copper wires that heat the wheel during that process. Guess it's new steering wheel time!
      02-02-2024, 07:22 PM   #7
Qsilver7
Qsilver7's Avatar
Thanks for the update and confirmation of the 030482 fault code…it was the heating mesh.
