10-25-2021, 11:12 PM | #199 | |
Rep 4,114
I would go with 275/40 & 315/35 21 to improve comfort. This combo is used by some forum members. |
JDE92M3874.00 |
11-27-2021, 08:12 AM | #200 |
Rep 3,834
There's no issue and you cannot tell the difference of added 10mm front and rear.
11-27-2021, 08:15 AM | #201 | ||
Rep 3,834
11-27-2021, 10:17 AM | #202 |
Rep 4,114
01-02-2022, 10:56 AM | #203 |
Rep 1,030
I agree a NON RFT would be better haha. But options were limited at the time I purchased. I’m coming up on new tires needed again lol, go figure. This time I’m thinking about trying 285/40/21 and 315/35/21. I found great tire options here because Porsche has a lot of cars using this size. This does have a 1% difference where my current setup has a 0%. The car is lowered on Dinan now, and over 10K miles not a single issue or hiccup along the way. Ride comfort although lowered and on RFT is amazing, no exaggeration!
JD Last edited by JDE92M3; 01-02-2022 at 01:31 PM.. |
01-02-2022, 12:38 PM | #204 | |
Rep 1,233
By the way, unless there is a typo somewhere, the sizes you mentioned will be 6.9% difference in diameter according to tire size calculator. Last edited by Blue By You; 01-02-2022 at 01:28 PM.. |
01-02-2022, 01:31 PM | #205 | |
Rep 1,030
JD |
01-02-2022, 01:49 PM | #206 | |
Rep 1,233
Got it
Yeah, that's a lot of extra cushion for those wheels. I never thought I'd say this. But I'm debating using OEM sizes for a new set of BC Forged wheels partially for that same reason. (The 22" setup I like is almost the same exact diameter as OEM, so it's simply sidewall loss.) And because I have two full sets of OEM tires, it just might make more sense as long as I can get aggressive enough with the offsets. Yours look great so there is hope for me! |
JDE92M3874.00 |
01-02-2022, 02:53 PM | #207 | |
Rep 1,030
JD |
01-02-2022, 03:49 PM | #208 |
Rep 1,252
Any ways to get the new X5M wheels to fit safely? I know they make hub conversions etc, but don't know much about them. Lots of those wheels on EBay for decent prices, however the bolt pattern has been changed.
01-02-2022, 04:15 PM | #209 |
Rep 1,030
And I feel like it looks better as the suspension settled over some decent miles now. Happy to report ride is still great!
*phone app sucks lol* JD |
01-15-2022, 09:25 AM | #211 |
Rep 1,233
04-13-2022, 01:07 PM | #212 |
Rep 11,145
Thought I'd add some fun facts here regarding my latest set of 285/325 Michelin Pilot Super Sports...
Installed at 67,397 miles Replaced at 96,290 miles Total miles out of a set: 28,893 I really wanted to get to 30,000 miles but I didn't even make 29,000. I could have if it wasn't for the passenger front showing the steel belts on the outside of the tire. Final stats at 28,893 miles: Passenger front: Inside: 3.5/32nds Middle: 5/32nds Outer: 5.25/32nds Driver front: Inside: 3.5/32nds Middle: 5.5/32nds Outer: 5.75/32nds Passenger rear: Inside: 3/32nds Middle: 4.25/32nds Outer: 4.25/32nds Driver rear: Inside: 3.5/32nds Middle: 4.25/32nds Outer: 4.5/32nds |
05-03-2022, 03:34 PM | #213 |
Rep 26
so ive read this entire thread and am still kind of confused on what i can and cant do. i understand that the front to back size ratio needs to be within 1-1.5 percent of each other. i am thinking of upgrading to 22" wheels and found some tires that i like which are the nitto nv420v in a 325/35R22 for the rear and 285/40R22 for the front.
i understand the larger tire size is 2" bigger than factory and that would change the speedometer/actual speed settings but other than that it should not be an issue right? really would like to updgrade to a 22" wheel and still have a decent sidewall amount while filling in the wheel well gap. |
05-04-2022, 12:42 AM | #214 | |
Rep 1,233
But think about jacking up your M off of the ground by more than 1" due to the increase in overall diameter. You'll get the tire sizes and fender fill, but the height might look a little goofy. |
chrises081.50 |
05-04-2022, 08:13 AM | #215 | |
Rep 26
05-05-2022, 08:33 PM | #217 | ||
Rep 26
I just looked under there and will it not rub the upper control arms/ball joints? Geussing I'd have to get spacers for them lol |
05-06-2022, 02:12 PM | #219 | |
Rep 26
Tags |
tire size f85, wheel size, x5m tire, x5m wheel and tire size |
