04-16-2023, 09:18 AM | #1 |
Rep 167
Drives: '18 540i '15 X5 '03 530i
OBD tool recommendations
I’m getting ready to replace my 8+ years old battery, would need to buy a OBD tool just for registration.
Anyone have a good recommendation for affordable tool ? I have BimmerCode but it does not do battery registration. Thanks in advance for any info. |
04-18-2023, 10:27 AM | #3 |
Rep 7,584
Ditto...just download the Bimmerlink app and use the same OBD dongle you use for the Bimmercode. Here's a direct link to the Bimmerlink app website: https://bimmerlink.app/
If you change the type of battery (like from AGM to wet cell or the AH rating from 92AH to 105AH or vice versa)..then you will need to "CODE" that change in Bimmercode...then "REGISTER" the new battery using Bimmerlink. If the type and/or AH rating is basically the same...then all you will need to do is register the battery using Bimmerlink. Here's some screen shots below:
04-19-2023, 11:02 AM | #4 |
Rep 668
Agree with Red_Y_ and Qsilver7 input, but also throwing Foxwell NT530 or above in the mix. It has paid for itself over and over for me.
- Read Codes - Clear Codes - Live Data - Register Battery (Main and Aux) - Transfer Case adjustments - Fuel Filter Priming |
04-19-2023, 03:55 PM | #5 |
Rep 167
[QUOTE=Qsilver7;30046251]Ditto...just download the Bimmerlink app and use the same OBD dongle you use for the Bimmercode. Here's a direct link to the Bimmerlink app website: https://bimmerlink.app/
If you change the type of battery (like from AGM to wet cell or the AH rating from 92AH to 105AH or vice versa)..then you will need to "CODE" that change in Bimmercode...then "REGISTER" the new battery using Bimmerlink. If the type and/or AH rating is basically the same...then all you will need to do is register the battery using Bimmerlink. Here's some screen shots below: top pic = battery registration screenshot using BimmerLink app bottom pic = battery coding screenshot using Bimmercode app Thanks to all. Appreciate the very good info. Got it changed to same battery capacity and used Bimmerlink. Btw, BMW brand replacement battery does not come with vent hole plug for unused hole and old plug woul not come out of old battery. I had to use trim snaps to plug the unused hole. I even asked dealer parts person and was told new ones don’t have plugs, weird. |
04-20-2023, 03:19 PM | #6 | |
Rep 7,584
05-07-2024, 05:02 PM | #7 | |
Rep 36
I don’t it shown here? https://www.bimmerworld.com/Tools/Fa...BoCMNAQAvD_BwE |
05-07-2024, 05:10 PM | #8 |
85
Rep 374
nothing replaces ISTA+ in a long run .... get an used laptop like Lenovo 380X $200 + OBD ethernet cable or bm3 (wi-fi if want the convenience of been outside the car) and setup is complete with all the functionalities provided by BMW
05-07-2024, 05:43 PM | #9 |
Rep 668
