07-19-2019, 09:30 AM | #1 |
Rep 4
Tire pressure for non-run flat tires (2015 F15 X5)
I cant seem to find a definitive answer for this. Recently went with a non run flat tire on the X5 (NON staggered - 255/55R18). So all the same wheel and tires all around. I have seen different answers to what PSI to run in the new tires. Some say to stick with the what the psi says on the inside of the door, 41 in the rear and 33 in the front. Others say to run the same psi all around. Looking for some guidance here on the right psi to run. For those that say "it's all about preference"....I am really just trying to to be safe and prolong the life of the tires.
07-19-2019, 09:59 AM | #2 |
Rep 110
I got my non-runflats at Costco and they put 33 for Front and 36 for rear with Michelin. My old door sticker says 32/39. The door sticker is for runflats only. You will initially feel the ride is softer with non-runflats, so increase the PSI a bit, then gradually reduce the PSI to your comfort. Also inspect the tire wear when you get 2-3k miles on it and making adjustment accordingly, then rotate the tire every 10k or year. if you are OCD, go with 5k!
07-19-2019, 10:10 AM | #3 |
Rep 2,194
Owner’s Manual...read it
Here is what BMW says...good luck
4
07-19-2019, 10:50 AM | #4 |
Rep 7,525
If that is what you want to do...then I suggest you start with the BMW PSI recommendation in the owners manual (graciously posted above by Violater)...following the recommendation for which ever model (engine weight differences considered) you have and other options listed + number of passengers and cargo.
ComasF1553.50 |
07-19-2019, 03:18 PM | #5 |
1152
Rep 2,426
Non-runflat tire pressure and runflat tire pressures are the same for me.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
07-19-2019, 04:59 PM | #6 |
Rep 289
I think it's personal preference, I tend to run slightly higher psi than the BMW manual states for a non-staggered 20" setup, just because it handles better in the turns (for me). I run 42 psi all round with just me, but I will bump it up for family vacations whe the car is fully loaded. YMMV
Eibach Pro Kit & Lowering Links, RC GTS Black 2014 M135i 3dr |
07-20-2019, 10:42 AM | #10 | |
Rep 494
It means that you should not inflate (cold!) tires above 40 psi, not that you should never operate them above 40 psi. A 40 psi cold inflated tire may reach 50 psi when hot (or, partially, if you climb real high to lower external pressures) - that's ok by design. |
duercos201.00 |
07-20-2019, 02:11 PM | #11 |
261
Rep 733
You know that your inflation pressures are close to correct for your application when the difference between cold/hot pressures yields a difference of less than 10% between the two at normal cruising speeds. Aggressive driving and heavy braking will add to the temperature and will bump up your reading.
The pressures on the door frame label are excellent initial starting points for the majority of drivers and will satisfy most everyone. But, be honest with yourself, are you checking tire pressures monthly?
07-20-2019, 04:43 PM | #12 |
Rep 174
Tire pressure is a engineered number between the tire manufacturer and vehicle manufacturer.
The correct pressure is designed to bring the tire to the correct operating temperature. |
11-25-2019, 07:05 PM | #13 |
KingBiscuit
4
Rep 33
If it's possible I think I'm more confused...
And this is for run-flat... right?
2014 X5 xDrive 35i
11-25-2019, 07:25 PM | #14 |
261
Rep 733
Yes
11-26-2019, 09:20 AM | #17 |
KingBiscuit
4
Rep 33
That's what I did and will stick with. Thanks for the help.
2014 X5 xDrive 35i
11-26-2019, 12:48 PM | #19 |
Rep 112
IIRC tire pressure recommendations are at ~70 degrees F. Drop about 1 psi for every 10 degrees F colder, and add 1 psi for every 10 degrees F warmer. Also noteworthy is if your car is parked outside, are the tires on one side exposed to sunlight or not. I've had tires on the sunny side measure ~2 psi higher just being in direct sunlight after they were set to the same pressure in the garage just a day or two prior. Surface temperatures measured with a laser thermometer confirmed a 20-25 degree difference, so after an hour+ of direct sunlight warming up one side you can get these wide differences.
201199.50 |
