01-28-2022, 02:47 PM | #1 |
Rep 106
Anti-sway when towing with Invisi/Stealth/BMW hitches and OEM active harness
I have 2015 35d with Invisihitch using OEM active harness/module and wired Tekonsha P3 brake controller. I have all the coded trailer features when harness/trailer is hooked up (like rear camera hitch zoom, disabled pdc, and trailer light out notification except not sure the following one
Stability Controls- Utilized anti-lock brakes to dampen trailer sway in unsafe conditions Anybody know the easy way to find it out? I ask this because sometimes I feel a little sway/fishtail when I tow trailer at > 70 mph (I know I shouldn't drive > 65 when towing). Invisi/Stealth/BMW hitches can't use any mechanic weight distribution hitch and sway control bar. I wonder even with the above anti-sway coded feature working, it is still probably not good enough to control the sway unless the coded feature can also apply trailer braking without driver applying X5's brakes . I have found Sway Command Electronic Sway Control System at etrailer and amazon https://www.etrailer.com/p-LC380605.html https://www.amazon.com/Trailair-Sway.../dp/B07CP9VV26 It detects sway and apply trailer brake. Wonder if it works and anybody has used it and has some opinions. TIA Last edited by milkyway; 01-28-2022 at 02:58 PM.. Reason: typo |
01-28-2022, 04:18 PM | #2 |
Rep 2,517
Check this thread out, has some helpful info on this topic:
https://f15.bimmerpost.com/forums/sh....php?t=1665188 |
01-28-2022, 05:06 PM | #3 | ||
Reads books at a 4th grade level; I'm an enabler
78
Rep 116
Drives: X5 35d, 335i Msport, X3, 325iX
Garage List 1993 BMW 525iT [0.00]
1989 BMW 325iX [0.00] 2015 BMW 335i M-Sport [0.00] 2007 BMW X3 M-Sport [0.00] 2015 BMW X5 [0.00] |
Last edited by X Mon™; 01-28-2022 at 05:18 PM.. Reason: Correction: Trailer sway not in AHM, but rather DSC_Premium und ICMQL. |
01-28-2022, 06:22 PM | #4 |
Rep 650
I can't help you with coding, or the brake controllers; But are you on airbags, or coil springs, and is the ball mount the correct height?
Years ago I ran into issues with Uhaul trailers being too tall for the standard Stealthhitch ball mount and my lowered X5. I have the rear airbags "spring" that helps to keep level, but towing a 7 series on a Uhaul carhauler that was a bit low in the front, and I got a bad sway at around 60-65mph. Now I have a the tallest version of the Stealthhitch ballmount, and Uhaul trailers ride perfectly level. Makes a difference in how the trailer pulls behind the car. So my point is that it might be more than just a brake controller or programming you are dealing with. You also need to considering trailer tongue weight and height. |
01-28-2022, 07:14 PM | #5 |
Rep 106
[QUOTE=X Mon™;28524202]It's as easy as checking the coding of the DSC and Integrated Chassis Management module. Did you use K235 or 3AC? Moreover did you code it yourself, or did someone else?
I didn't code it, a local body shop installed the hitch. I can use ISTA (without coding/programming) a little, like registering new battery. Can ISTA shows the following feature in question? Stability Controls- Utilized anti-lock brakes to dampen trailer sway in unsafe conditions Last edited by milkyway; 01-28-2022 at 07:15 PM.. Reason: typo |
01-28-2022, 07:20 PM | #6 | |
Rep 106
I think my trailer is pretty leveled with the towing X5. Here is the picture https://f15.bimmerpost.com/forums/sh...&postcount=154 Last edited by milkyway; 01-28-2022 at 07:35 PM.. Reason: missing something |
01-29-2022, 07:24 PM | #7 | |
Rep 650
You really want to try to keep all weight in the middle of trailer, above the axle, even if that means letting spare tires ride inside the camper instead. Having that much weigh that far back, can make sway worse. |
01-29-2022, 07:45 PM | #8 | |
78
Rep 116
NO, you need to look at the coding of the modules I mentioned above via ESys at this point.
01-31-2022, 10:09 AM | #9 | |
Rep 106
Also found 2 bolts/nuts to the frame at back of trailer were loose, and I tightened them up. I would estimate 2 tires are about 70 lbs, the total weight on carrier is about 250 lbs. |
01-31-2022, 10:23 AM | #10 |
Rep 106
Thank you. I have E-SYS 3.27.1 installed, but I haven't gotten a chance to learn and use it. I definitely like to try to get my feet wet with it. Now is good time familiarize it by just looking it current coding parameters' values not coding any. Can you/anybody give a brief steps/instructions in E-SYS to look the coding parameters' values in question?
02-03-2022, 09:54 PM | #11 | |
Rep 650
I'd take off all the weight at the back, do a test drive, and see if anything changes. Even if you have or get the correct programming, it won't remove the reasons you get sway, but might mitigate the problem. |
02-04-2022, 10:22 AM | #12 | |
Rep 106
02-05-2022, 02:40 PM | #13 | |
Rep 650
The trailer wheels is the center of trailer, and the further away from the wheels, that you add weight, the worse it is for sway, regardless of front or back. If using weight on front to balance out the back, you will also make the trailer easier, compared to trying to add the weight above the wheels. If you keep having problems with trailer sway, you might want to consider transporting what you can inside the trailer, and then when camping, use the outside storage space for stuff. |
