      11-18-2020, 11:20 PM   #1
Bmwdrocher
Drives: BMW X5 F15 M SPORT
Y-pe or Super Sprint Exhaust F15 35i
Hello everyone.I have f15 35i M sport stage 2 with catless downpipe installed.In my exhaust I have a popcorn sound but no bass.Who knows what will be sound better?And what the difference?
Y-Pipe with mufler deleted or Super Sprint exhaust?
I want to add some bass and make exhaust louder for 20-30%
      11-19-2020, 01:09 AM   #2
hufington
hufington's Avatar
3121
Drives: 2022 X5 m50i
Any muffler delete with straight pipes would make it go even further from bass. The most bass for your engine that I have heard so far came from a Supersprint cat-back exhaust, but it is an expensive upgrade IMO.
2022 BMW X5 m50i
2024 MB S63 on order
'18 X5 50i / '16 BMW F10 550xi / '13 BMW F10 535i / '07 BMW E64 630i / '03 BMW E65 745i / '95 BMW E34 540i / '89 BMW E30 M3
      11-19-2020, 09:40 AM   #3
Bmwdrocher
Yes,Y-pipe cost of $400,Super Sprint muffler cost $1200.You think it will be much better than OEM M performance exhaust which installed from manufacture?
      11-19-2020, 09:42 AM   #4
Bmwdrocher
I had before E60 528i with mufler and resonator deleted,and it sounded great,But in this car I still can't get that sound.
My previous car sound
https://drive.google.com/u/0/uc?id=1...xport=download
      11-19-2020, 10:12 AM   #5
hufington
hufington's Avatar
3121
You can get a Y-pipe done by any decent muffler shop for much less. The aftermarket mufflers and OEM M performance will be similar in performance but different in tone. I personally don't like how the M Performance sounds.
If I were you, I would delete the OEM exhaust at the back and install Vibrant Performance 10633 Muffler (2.5" inlet/2.25" double outlets) or Vibrant Performance 10632 Muffler (3.0" inlet/2.50" double outlets) and use it with the factory tips. These mufflers cost less than $200 on Amazon and they are well-made.
2022 BMW X5 m50i
      11-19-2020, 04:53 PM   #6
Bmwdrocher
And this way I can add some bass?It will sound much louder?What do you think
      11-19-2020, 05:07 PM   #7
hufington
hufington's Avatar
3121
Will be louder than the OEM for sure.
2022 BMW X5 m50i
      01-06-2021, 05:17 PM   #8
Bmwdrocher
I installed the super Sprint exhaust muffler,now between 1 and 2k rpm it's making a loud annoying drone🤦*♂️Don't know now what to do,put the resonator?I think it's because I have installed catless downpipe
      01-06-2021, 06:53 PM   #9
hufington
hufington's Avatar
3121
Get an ultraquiet muffler for the mid section or research Helmholtz resonators. (check here: http://synapseengineering.com/synaps...3eb26nmm54fu62 or http://synapseengineering.com/suppor...ons_111513.pdf)
2022 BMW X5 m50i
1norseman398.00
      01-16-2021, 01:44 AM   #10
Bmwdrocher
The resonator did not help
      01-20-2021, 08:21 AM   #11
M302_imola
M302_imola's Avatar
843
Drives: '15 X5 35i Xdrive Mineral Whit
I'm glad I ran across this because I've got an xline with factory exhaust with some custom tips I'd like to keep while turning up the volume. So I could just replace the muffler with one of the two you suggested to achieve this. Would I also need to do the exhaust flap hack for maximum volume? I've read about it but not sure with my particular model (xline) if the flap is closed? I'll have to look up some sounds clips of this muffler. Would any additional piping be needed or is the muffler plug and play with my OEM setup?
      01-20-2021, 12:12 PM   #12
hufington
hufington's Avatar
3121
The Vibrant mufflers are off the shelf and you need an exhaust shop to weld them in and also weld your custom tips. Not plug and play. You can find some clips online how the Vibrants sound.
2022 BMW X5 m50i
      01-20-2021, 01:10 PM   #13
M302_imola
M302_imola's Avatar
843
I see, is the piping that exits the OEM muffler welded in? I guess what I'm asking is will the exhaust shop have to custom fab the piping that is downstream the Vibrants muffler? My custom tips screw on to the existing exhaust piping currently.
      01-20-2021, 01:48 PM   #14
hufington
hufington's Avatar
3121
At the marked areas below, the OEM muffler needs to be cut out and then the new muffler needs to be fitted/welded on. I'd go with 3" inlet and double 2.5 " outlet one.
2022 BMW X5 m50i
      01-20-2021, 03:34 PM   #15
M302_imola
M302_imola's Avatar
843
Perfect! Thank you sir!
hufington3120.50
      01-20-2021, 05:26 PM   #16
hufington
hufington's Avatar
3121
No prob!
2022 BMW X5 m50i
      01-21-2021, 10:48 AM   #17
M302_imola
M302_imola's Avatar
843
Huffington, got any of those Vibrant muffler sound clips handy? Google didn't land me much.
      01-22-2021, 08:43 AM   #18
hufington
hufington's Avatar
3121
Nope, what's available on the Internet.
2022 BMW X5 m50i
      01-22-2021, 03:23 PM   #19
M302_imola
M302_imola's Avatar
843
I finally found that one sound clip of that X6 with the Vibrant muffler. Sounded pretty good even with the phone falling down
      01-22-2021, 03:26 PM   #20
hufington
hufington's Avatar
3121
Great. I am using the bottle type Vibrants on my X5 and they sound good but it is a 50i not a 35i.
2022 BMW X5 m50i
      01-22-2021, 06:47 PM   #21
M302_imola
M302_imola's Avatar
843
I see...total different animal. I think I actually ran across a post of yours. I believe you stated you paid around $370 muffler + labor.
      01-22-2021, 06:52 PM   #22
hufington
hufington's Avatar
3121
Around that for the x-pipe, 2 mufflers, tips. Since I have no lift and welding equipment.
2022 BMW X5 m50i
