09-25-2016, 10:16 PM | #2773 |
Rep 176
Highbeam with welcome lights
Hi All,
I was able to code my F12 M6 with the high beams on with Welcome Lights. Is there away i can program my F16 X6 with the the same, i know the functions are a little different. I wanted to get the fog lights on as well, but i read somewhere that it doesn't work on the F16. Any help is greatly appreciated. |
09-26-2016, 01:16 AM | #2774 |
Rep 8,364
09-26-2016, 10:47 AM | #2775 |
Rep 494
I'm going in for my regular servicing and I'm wondering if my software is updated, what is the quickest way to restore my settings?
1) Can I somehow replace the new cafd file with the backup that has all the coded settings? 2) Do a file compare and then manually re-code? thanks. |
09-26-2016, 01:56 PM | #2776 | |
Rep 176
So it depends if they reprogram your car and change the CAFD files. if not then just put your back up files and FDL code them. with my X6 they reprogrammed the car but the files stayed the same so i just FDL Coded my back up files and I'm back to where i was. I would take a back up of everything, the FA file and SVT files, then also the CAFD files before you bring it in. I hope that will help you. |
09-26-2016, 02:32 PM | #2777 | |
Rep 40,310
09-26-2016, 04:12 PM | #2778 | |
Rep 8,364
When programmed, usually CAFD_ID's (eg, CAFD_00000DED) will not change; however, the major, minor, and patch version (ie three sets of numbers after ID) will change. If you do not have a list of options you coded, you can use TM's NCD / CAFD Tool to highlight differences. Be aware that updates sometimes come with tweaks in settings; so, depending on the ECU modules, it may highlight changes you would not want to set back. The quickest way to recode is with Built in Launcher Cheat Codes. |
09-26-2016, 11:01 PM | #2779 | |
Rep 494
09-27-2016, 12:10 AM | #2780 | |
Rep 8,364
09-27-2016, 12:00 PM | #2781 |
Rep 570
This might be somewhere in this huge thread, sorry for the re-questioning if so... Besides this, do you know how to disable the PDC (or just sound) when a trailer is connected it's always driving me nuts... |
09-27-2016, 12:04 PM | #2782 | ||
Rep 570
09-27-2016, 02:37 PM | #2783 | |
Rep 982
09-28-2016, 06:07 PM | #2784 | |
Rep 176
I have Comfort+ and Sport+ but I'm just curious to know if i can comfigure Comfort+ in iDriver? |
09-28-2016, 07:11 PM | #2785 |
Rep 980
Shawnsheridan-
Could I get a link to the latest files, please? Also, do you have a link to the FSC/NBT code generator? The ones I have tried to download from the 2addicts forum here are not working/sketchy as hell!. I have managed to find the latest map torrent. Thanks in advance |
09-28-2016, 07:17 PM | #2786 |
Rep 40,310
PM sent.
BMW - BEKTAS15.50 |
09-30-2016, 10:31 AM | #2787 |
Rep 980
Thanks Shawn!
On another note, had dealer install hitch and wiring recently, and now the rear left window will not auto-roll up (from either the drivers or rear door switches). Any idea if there is some coding I can do to fix this? Also the confirmation gong one usually gets with setting seat memory disappeared. would like to try a coding fix as it will be a while before it needs to go to the dealer otherwise. |
09-30-2016, 11:09 AM | #2788 | |
Rep 40,310
Erasure of initialization: • Open door window glass fully • Operate power window switch in "Open" position four times within 10 seconds This erases initialization of the power window, anti-trapping protection and toll function are inactive. Check whether one-touch control (toll) function is inactive, otherwise repeat procedure. Reinitialization: Avoid a break between the two steps! • Open door window glass fully • Operate and hold power window switch in "Close" position (second switch stage) • Once the upper end position has been reached, hold power window switch in "Close" position for approx. 2 seconds longer • Open door window glass fully • Operate and hold power window switch in "Close" position (second switch stage) • Once the upper end position has been reached, hold power window switch in "Close" position for approx. 2 seconds longer For Gong, there is coding in Seat Module, but not sure it works in latest firmware or not: http://www.2addicts.com/forums/showthread.php?t=1278132
09-30-2016, 07:14 PM | #2790 | |
Rep 980
Thanks |
10-01-2016, 02:56 PM | #2792 | |
Rep 8,364
EDIT: You can always use TM's NCD / CAFD Tool to check which ECU's are affected. |
10-01-2016, 03:07 PM | #2793 |
Rep 176
High Beam with WelcomeLights
Hi
For The F16 which code is it to turn the high beams with Welcome Lights? Also, did anyone figure out how we can turn on the icon on the cluster to show the heated steering wheel is activated or not? Thank you in advance |
