      06-16-2017, 08:55 PM   #3521
Maxipes
Maxipes's Avatar
Drives: 2017 X5 e40
# of turn blinks
Is anybody could give an advice?
What is new code for to change number of turn blinks?
This one doesn't work anymore:
BDC_BODY 3068 Changing the # of Turn Signal Blinks werte=04 werte=02
Thanks!
Maxipes
      06-16-2017, 11:19 PM   #3522
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Originally Posted by Maxipes View Post
I paste it from BMW Coding Database.
Cannot find it in ECU in my F15 e40. There is only HKFM2 and there is no:
3010 HKL_BEDIENUNG TASTER_FBD aktiv nicht_aktiv Close trunk via Keyfob/footwell button (Part 1/3)
Any advice?
Thanks!
Launcher Cheat Codes
      06-16-2017, 11:20 PM   #3523
Almaretto
Almaretto's Avatar
2374
Thanks!
Sections are meaningless.
Use cheat sheet in OP.
      06-19-2017, 12:55 AM   #3524
mkdan2004
Drives: BMW X5 F15
Hi guys
I found the code for updating the user interface for iDrive 5 to the one found on iDrive 6, no gesture control supported but everything else looks and works fine. For those interested, parameter HMI_ID_VERSION found in HU_NBT2 must be changed from ID5_plus_plus to ID_6_lite (pay attention to select "lite").
Many thank to the guys on the F30 forum where i found this information . Maybe it should be added to the OP if others find it useful.
      06-19-2017, 02:22 PM   #3525
Maxipes
Maxipes's Avatar
Drives: 2017 X5 e40
I guess I didn't have enough knowledge about coding. As far I could do coding it is using E-Sys when I go to module and edit FDL. Is there any instructions how to use Launcher Premium for coding?
There are only small things will make me happy after all coding I perform with my e40 are:
1. Change soft turn signal from 3 to 5 blinks
2. Make trunk door closed from FOB and from driver's door knob
3. Disable "Goodbye" message on screen after engine stopped
Any advice how to change these options would be greatly appreciated.
      06-19-2017, 02:46 PM   #3526
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
New code for # of turn signal blinks:
PIA_DEFAULT_TIPPBLINKEN
Change to 02 = 5 blinks!
Other stuff should work from the Cheat Sheet as far as I know. For launcher codes hopefully other more experience members can explain more..
      06-19-2017, 03:08 PM   #3527
Maxipes
Maxipes's Avatar
Drives: 2017 X5 e40
Thank you,
What module for change turn number of turn signal? Same as in sheet in beginning of this thread? BDC_BODY 3068?There is no HKFM n my ECU, I have HKFM2 and there is no commands for Close trunk via Keyfob/inside button
Maxipes
      06-19-2017, 04:55 PM   #3528
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
Thank you,
Yes, same module in the sheet for the blinkers, just open FDL editor and type it in the search bar.
My car has all the modules in the sheet, not sure why you don't have them.. If you want to learn how to use the luncher codes look at bottom of this thread.
http://www.bimmerfest.com/forums/sho...d.php?t=983245
      06-19-2017, 09:33 PM   #3529
Almaretto
Almaretto's Avatar
2374
Coding Made Easier (Cheat Codes in E-Sys Launcher)
      06-26-2017, 03:02 PM   #3530
NPickles
United Kingdom
71
shawnsheridan Can I get a link to the latest coding data files please.
Thanks,
      06-26-2017, 03:38 PM   #3531
shawnsheridan
shawnsheridan's Avatar
Thanks,
PM sent.
      06-27-2017, 02:42 PM   #3532
NPickles
United Kingdom
71
That option is in BDC_BODY? What number is it under, I can't find it having had my F15 reprogrammed yesterday because all my online stuff stopped working. I've put all my other codes back, I think, just not this one.
I've just double checked this and this option is definitely not in BDC_BODY\3069 like it should be.
I did read on another forum for a different F model BMW that this new option was only visible when using E-Sys 3.28, I am using E-Sys 3.27.1 and the latest data files as of yesterday.
      06-29-2017, 12:38 PM   #3533
Almaretto
Almaretto's Avatar
2374
Sections are meaningless. Either use Launcher Cheat Codes or search function.
Mapping has nothing to do with E-sys or PSdZ version. You likely need to update E-sys Launcher past 2.6.x (current version 2.7.1) so that you can have updated mapping to find FDL.
Fxx, Ixx, & Gxx Series Coding: (No Request) Latest Software Links
      06-29-2017, 03:37 PM   #3534
Jlu88
Jlu88's Avatar
360
Drives: X5 XDrive35i M Sport
Received my cable today and decided to have a crack at doing some coding.
Just been outside sat in the car for the past hour following the guide and tutorials.
I've managed to change a few things I wanted in the BDC_BODY section such as close windows and mirrors via key fob and door handle lights when in reverse.
However, I'm having issues with the other sections e.g;
Can't SCH_FBD, FCH_TOEHKI and TASTER_FBD in HKFM for trunk close via fob.
My HU_NBT2 section looks like the below, all the folders have no names and are just named "."
I understand the cheat sheet is a little out of date for the 2017 models, is there an updated guide anywhere else? or maybe I'm just clueless and looking in the wrong places? lol
2017 X5 xDrive35i M Sport - Space Gray | Adaptive M | Eibach Pro | H&R Spacers | MPPK | MPE | Autotechnik Gloss Black Dual Slat Kidney Grills | Autotechnik Gloss Black Fender Vents | Leather Knee Pads | Painted Front Reflectors | M50D Trim - Gone
      06-29-2017, 09:20 PM   #3535
Almaretto
Almaretto's Avatar
2374
You should have HKFM2 so those functions are not found. You should be using Launcher Cheat Codes that I wrote.
Dots means you incorrectly configured E-sys Launcher.
Jlu88360.00
      06-29-2017, 11:41 PM   #3536
Jlu88
Jlu88's Avatar
360
Ah I see, I'll have to backtrack and see if I missed anything and maybe reinstall the whole thing.
I looked at the Launcher Cheats Codes you created, but wasn't how to sync all the Github coding into E-Sys, so I copy and pasted all the codes into a wordpad file, gave it a .xml file extension and dropped it into C:\Program Files (x86)\TokenMaster\E-Sys Launcher Premium\FDLCodes and yes, nothing happened lol.
Seem to be getting worse at using computers these days *sighs*
      06-30-2017, 05:23 PM   #3537
Almaretto
Almaretto's Avatar
2374
Only pro launcher syncs. For premium, you manually download.
You got the right location. Open XML in internet explorer to make sure you copied correctly. Git can display in multiple forms.
For latest premium launcher, you must select authors in configuration window.
Then, first time you go to fdl editor, you need to check auto fetch and select refresh.
      07-06-2017, 01:23 AM   #3538
aleksaleks
Drives: F15 50i (2014)
6WA combi - night mod off?
hello,
how to forbid my combi instrument (6WA) to switch to night mode pls?
COMBI
DIM_NACHT_EIN
active
non active
own value
if I put in my own value, like "FF" or if I set it to "non active" - it doesnt help and after restart my combi instrument switches back again from day to night mode.
any help would be very appreciated !
      07-06-2017, 06:02 PM   #3539
Almaretto
Almaretto's Avatar
2374
Originally Posted by aleksaleks View Post
hello,
COMBI
DIM_NACHT_EIN
active
non active
own value
Any of the newer clusters (All F15's) can no longer code Day White at night.
      07-06-2017, 09:03 PM   #3540
Jlu88
Jlu88's Avatar
360
Had my MPPK tune done today and as expected, all my previous coding changes were wiped, so I recoded everything again.
Still wasn't able to figure out how to get the Launcher Cheat codes to work.
However, I re-read the 1st page and realized I forgot to deselect Update "VCM after TAL execution" and "Update MSM after TAL execution". After I deselected those, all the folders were displaying correctly instead of displaying ".", so I just referenced the cheat sheet.
Pretty happy with the changes, coded the following;
Mirror folding via key fob
Mirror folding via comfort access
M startup splash screen
Indicators display on HUD
Removed iDrive disclaimer
Removed camera disclaimer
Handle lights on reverse
Close windows via key fob
Remember whether AC was on or off when car was shutdown
Trunk close via key fob - this one I had to search for as it wasn't in the cheat sheet for the iDrive 5.0. Going to list the instructions below just in case anyone else is searching for it.
You won't find "SCH_FBD", "SCH_TOEHKI" or "TASTER_FBD" in HKFM2. Instead you need to look for the below in HKFM2 instead;
300B HKL_REMOTECONTROLLIFTGATEBUTTON_BUTTON_TYPE change werte from 02 to 05 (allows remote button to both close and open the tail gate)
      07-11-2017, 07:53 PM   #3541
destronik
Drives: X5
Opasha,
Thanks for the great post! New to the forum and tried PM'ing for the download links but got an error that your inbox was full. When you get a chance could you PM the download links for the applications? Thanks!
      07-11-2017, 07:55 PM   #3542
shawnsheridan
Originally Posted by destronik View Post
Opasha,
PM sent.
