      05-05-2016, 08:05 AM   #1
JonM
Drives: E90 M3 Sedan
X5D: does anyone use a cetane booster
Is anyone currently using a cetane booster (like the Royal Purple one, for example) on a regular basis? If so can you post about your experiences?
Jon Maddux
coupenut.blogspot.com
x5nut.blogspot.com
16 X5d | 08 M3 Sedan | 06 M Coupe | 01 M coupe | 99 M coupe
      05-05-2016, 09:16 AM   #2
ixlr8
Drives: 2016 X5 35i
I don't have a X5d, I have a X5i. But I did use a lubrication additive to the fuel I put in my VW TDI diesels. The fuel sold in the US meets the US standards for lubrication, barely... but it does not meet the VW Bosch pump spec so in a VW it is a good idea to add some. I have no idea how the lubrication spec for the BMW pump compares with the US fuel standards. But it would be something I would look into and put in a lubrication additive if one is needed. These pumps are very expensive and if you trash one, the entire fuel system needs replacing.
The lubrication additive I used in my VW was also a Cetane booster, 3-4 points, and maybe, just maybe, the engine was a little quieter with it. Other than that I didn't notice any difference.
      05-05-2016, 09:45 AM   #3
JonM
ixlr8, I agree with all your points. I know BMW says use no additives, but I also know not all diesel fuel is the same.
It is a small hassle to add it but also seems like it could not hurt to use it... either Royal Purple, Liqui Moly, etc.
Jon Maddux
x5nut.blogspot.com
      05-05-2016, 09:59 AM   #4
MotoWPK
Drives: '13 128i vert, '14 X5 40i
Except the high pressure fuel pumps in the VW's and BMW's are not the same. They are both manufactured by Bosch, but are very different pumps. Where there has been a history of failures in common rail VW's (on the order of a few percent), failures in BMW's are extremely rare.
Also, Bosch's specification with regard to lubrication is that the diesel fuel used (in the US) must meet ASTM D975 (which includes an HFRR rating of 520 max), which is the standard fuel specification here.
      05-05-2016, 10:10 AM   #5
stewy604
stewy604's Avatar
290
No additives in mine as of yet, just over 70k on the odo...I've been following the 'no additives' rule.
2007 Suzuki GSX-R 750
      05-05-2016, 09:54 PM   #6
motex
2020 Mineral White 30d MSport
motex's Avatar
Costa Rica
523
Diesel Kleen since day 1 (http://powerservice.com/psp_product/...-cetane-boost/)
      05-08-2016, 05:51 PM   #7
MattBianco
MattBianco's Avatar
Drives: 2015 X5 35d msport
I have not used one, but 42pilot who is amongst most knowledgeable people one may come across about engines (both diesels and gassers), uses an additive. He has commented about it in other threads, and that he uses it on his diesel pick up truck as well.
I have been too lazy to do this, especially as the primary driver is my wife, who does the refueling most of the time.
      05-08-2016, 11:28 PM   #8
42pilot
42pilot's Avatar
591
Drives: 2014 X5 35d MSport
I don't use it for boosting cetane rating. I use it for fuel conditioning, fuel system cleaning and lubricity. If it positively affects the cetane rating, then even better. With fuel injectors using piezo technology and fuel pressures over 30,000 psi, you need a clean fuel with lubrication properties that will keep injectors working properly. Think of our injectors working or injecting fuel 6 times per event at 2500 rpm for an hour. That's nearly a quarter of a million operations in an hour on a four stroke diesel engine. My pick up has over 120,000 miles on it and I use an additive very other tank. The injectors were tested two weeks ago at the dealer and showed equal fuel delivery across all 8 injectors. Not bad since their life expectancy is less than 150,000 miles and mine are perfect. So far....
Also, if you use an additive and notice a difference in any way, you already have engine problems.
      05-09-2016, 11:02 AM   #9
motex
motex's Avatar
Costa Rica
523
+1
Since ULSD (ultra low sulfur diesel) is here, Diesel fuels have lost some conditions that were given back in the days from the sulfur that is almost gone (power and lubricity mostly) so the main reason for me using Diesel Kleen is to treat the fuel with lubricants and also have a cetane boost, our Diesel here in Costa Rica has come from 5000 PPM's (parts per million of sulfur) to less than 50, the new ULSD is "too dry" and can have a bad impact on engine parts (fuel pump mostly) and engine gaskets, I have been using this aditive for almost 10 years on my cars and company trucks, no issue and the engines never had to be overhauled
      05-09-2016, 03:25 PM   #10
igom3
Drives: 02 E46M3 15 F80 M3 16 X5 35d
2016 X5 35d  [0.00]
2015 BMW M3  [0.00]
2002 E46 M3  [0.00]
Which additive you are using. Thanks
      05-09-2016, 08:36 PM   #11
42pilot
42pilot's Avatar
591
BMW - Howse, Diesel Kleen or Stanadyne
Pickup - Walmart Tec3 2 cycle oil (no emissions on the Powerstroke) or any of the above.
Any of the above listed with the BMW are fine and really no difference we will notice. If you had a fleet of 50 trucks and paid for your own maintenance, you would be guided by cost, using any of the above three. There aren't any magic potions, so buy what is most convenient - buy large quantities at Walmart, then prepare 8 oz bottles for the fill.
      05-10-2016, 09:34 AM   #12
igom3
2016 X5 35d  [0.00]
2015 BMW M3  [0.00]
2002 E46 M3  [0.00]
Thank you
