05-03-2016, 12:35 AM | #1 |
Rep 5
Mismatching grills
Just took delivery and realized the 2 front grills do not match. Has anyone else seen this before? I guess I only need to replace the driver side one now
05-03-2016, 01:28 AM | #2 |
<3 Flat Four
215
Rep 754
maybe u have a special intake on the passenger side
been digging through the forums lately as i wait for my x5 to arrive, all these mismatched parts is scaring me. now i need to check the car over throughly before signing papers ps: u got lucky
2011 335is Le Mans Blue
05-03-2016, 01:54 AM | #3 |
Rep 3,341
i think this is normal, vents on one side only. same as on my '11 with the previous body style.
Currently:
2018 GT3 2020 X3MC Previously: 1999 M3 2002 M3 2005 S4 2008 C63 2015 M3 2016 X5M 2019 911S |
05-03-2016, 03:45 AM | #4 |
Rep 3,990
Not mismatched. That is how they come because there is an air intake (if I remember correctly when this was swapped/discussed a long while back) on the right and not on the left side (thus, it is closed). If you want the open version for the left, PM Ben (r33_RGSport), and he will get you that piece. The installation instructions are noted here in his pdf along with the euro grille inserts: http://f15.bimmerpost.com/forums/sho....php?t=1001636
This thread talks about it: http://f15.bimmerpost.com/forums/sho...d.php?t=910781 This is the part number if you want to order it yourself (I recommend getting it from Ben; he knows the install, and he's a good guy who helps everyone on the forum): 51118064633
05-03-2016, 08:19 AM | #5 |
Rep 660
There is an additional radiator on the right side that needs airflow. That is why that vent is open. The left side is closed to improve vehicle aerodynamics and fuel economy. Some models will have the left side open as well as there is another radiator installed on the left side. I may be wrong but I believe that is V8 models only.
05-03-2016, 08:22 AM | #6 |
Self-Deprecating Narcissist
7266
Rep 6,561
eight cylinder is closed on one side as well.
05-03-2016, 08:42 AM | #7 |
Rep 18,706
Thanks opasha .
I do have them in stock. The reason it is open is to let airflow going through the oil cooler sitting behind it. The only X5 that have both side open is the M50d since it got 2 oil cooler. As far as it will create a drag and reduce fuel economy, you are driving a 50i for humanity's sake. The car is gas guzzler already. How much more mpg can be wasted by creating that little drag where the whole car is a drag. Even some ppl with prius, i3, i8, tesla, don't even care with mpg anymore. A grill is meant to be open with holes, a grill without a hole might as well make it smooth as the body panels. Why BMW design it like that? Beats me, I just happened to found the solution for it. Oh, the configuration are like this: - 35i/35d , both sides closed - 50i , US Driver side closed
05-03-2016, 09:07 AM | #8 |
Rep 3,834
Here's what I know as far as bumper vents for X5:
Oil coolers.
05-03-2016, 10:37 AM | #9 |
7266
Rep 6,561
i have a 50i msport and it is closed on one side.
05-03-2016, 10:28 PM | #11 |
1150
Rep 2,426
It looks silly if you ask me. Why they do this giant plastic thing all blocked up and plasticky.
05-04-2016, 04:14 PM | #12 |
Rep 145
05-05-2016, 07:57 AM | #13 |
7266
Rep 6,561
with everyone hunting for the best MPG this is not a trend that will fade quickly. anything and everything that will even yield a fraction of an MPG increase will become standard for a while.
