      05-04-2016, 02:10 PM   #1
denniss
denniss's Avatar
392
Drives: BMW
Wheel weight corrosion
I have a 16 x5 sport with the sport package that gives it the 20in. aluminum rims. Since I live in NJ and they use salt in the winters, the rims have corroded under the wheel weights.
Is it just bad weights ? What everyone do to clean them ? Did i get the cheap ones ? Are there better quality weights ? Has anyone else experienced this ?
Thank you
      05-05-2016, 08:22 AM   #2
nyalpine90
nyalpine90's Avatar
7431
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
      05-05-2016, 10:16 AM   #3
stewy604
stewy604's Avatar
290
Agreed...we need pics. I've never really seen wheel weights themselves corrode on these. That said, I just went through having my 469M's re-finished under warranty due to corrosion (around the center caps).
2007 Suzuki GSX-R 750
      05-06-2016, 08:59 PM   #4
denniss
denniss's Avatar
392
Drives: BMW
Here you go. Sorry forgot to take the pic earlier.
2022 x4mc (gone)
2019 X5 40i M-Sport (gone)
2016 X5 35i M-Sport (gone)
      05-06-2016, 09:12 PM   #5
artem123
artem123's Avatar
250
Drives: G30
This is where adhesive for the weight for balancing used to be.
      05-08-2016, 09:55 AM   #6
Kzang
Kzang's Avatar
3239
Drives: 2015 X5 35i Msport SG
No, that looks like the actual wheel weights being corroded.
      05-08-2016, 01:15 PM   #7
Doanster
Doanster's Avatar
627
Doesn't look like the wheel is affected at all, so this is a simple fix. Just replace the weights by yourself or have the tire shop donor for you.
      05-08-2016, 01:46 PM   #8
kcheves
Drives: 2013 X5 x35d
They probably used steel weights rather than lead, which may be a requirement in your region. Lead weights are readily available.
