09-10-2018, 12:08 AM | #639 |
Rep 944
I have a 2015 model and have been in the shop 2 times for the clicking. Shouldn’t of let them touch it to begin with as they made the clicking much louder and the last attempt the worse. Didn’t really bother me before I had them work on the car but now it’s so loud. Literally sounds like a ball bearing that is lose and dropping everytime the wheel rotates
Wondering if I switched to a different company wheel bearing and if that would fix the issue |
09-10-2018, 12:32 AM | #640 |
Rep 1,328
I've had the latest fix applied a few weeks back now, fitting the shim, and i'm happy to report that i haven't heard the sound once. To be clear, my car is a 2018. I also had a 2016 and when the same fix was applied, it didn't work. No idea whats different between years, or whether or not this issue will return.
2020 BMW X3M Competition ///M - ALPINE WHITE / SAKHIR ORANGE Past: 18' BMW M3CS | 18' BMW X5M | '17 BMW M3 Competition | '16 Mercedes GLC250 | '16 BMW X5M | '15 BMW X5 M50d | '14 Audi SQ5 |
09-10-2018, 10:02 AM | #641 |
72
Rep 315
Drives: 13 AWSO M5,16 DGMR X5M
So does mine.. 3 weeks after the shim fix.. all sounds good so far
2012 Rosso Mars Lamborghini Gallardo STS LP570-4
2013 AW SO F10 M5 upgrades: RKP front spoiler, M performance carbon spoiler, 3D design rear carbon diffuser, KW HAS Sleeve Kit, Akrapovic Evolution Carbon tips, ind black LCI front and rear grills, GruppeM RAM intake, 20" HRE P104 satin charcoal with PSS tires) |
01-02-2019, 02:19 PM | #642 |
Rep 47
Gentlemen - picking up a low mileage Melbourne Red/ Aragon. Haven't heard the clicking as yet and is this something of a DYI? appears straight forward. It's a CPO car so, 'should' the dealer do this? thanks!
01-03-2019, 08:56 PM | #643 | |
72
Rep 315
vics6.50 |
01-04-2019, 09:09 AM | #645 |
72
Rep 315
Mine has been quiet so far.. finger crossed..
01-23-2019, 07:32 AM | #646 |
Rep 208
04-18-2019, 04:36 PM | #647 | ||
Rep 5,733
Drives: '24 iX50; '23 i4 M50
So the above image/SIB is what I need completed and it appears to resolve the issue for good?
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
04-22-2019, 08:58 AM | #648 | |||
72
Rep 315
Kief4440.00 |
04-22-2019, 06:49 PM | #649 |
Rep 123
just noticed the clicking on my 18 X5M. Going to call the dealer for a service appointment and hopefully a fix. Was easy to find a helpful thread on this board.
18 BMW X5M
20 Mclaren 720S Spider 19 X7 20 992 C4S 15 458 Speciale |
04-23-2019, 06:41 AM | #650 | |
Rep 5,733
I'm waiting until June to take it in for my annual service/state inspection, along with possibly new exhaust due to my exhaust tip chrome delamination.
04-23-2019, 07:42 PM | #651 | |
Rep 123
18 BMW X5M
Kief4440.00 |
04-23-2019, 09:37 PM | #652 |
Rep 81
My car is also bothered by the crack. Once I changed the left and right bearings at the dealer. However, in half a year the sound began to become.
I now look at ISTA. Then the solution is written as follows. I will try to put it into practice. Repair notes for tick during cornering Fault cause: Play between wheel hub and brake disc causes a tick during cornering. Repair instructions: Remove the brake disc on the front axle Clean the contact surfaces on the inside of the brake disc chamber and then sand down using coarse sandpaper (graining 80) Note: No grease may be used on the contact surface between the wheel bearing and the brake disc during the assembly! The contact surface must be free of grease! Install the washer for increasing the coefficient of friction no. 963 as shown in the video (see document Auxiliary materials and operating fluids) Mount the brake disc on the front axle Note: For vehicles older from before 2018, all the front and rear wheel bolts, and locking wheel bolts if applicable, must be replaced! |
Kief4440.00 |
05-16-2019, 06:15 AM | #653 | |
Rep 5,733
Thanks
06-09-2019, 11:10 PM | #655 |
Rep 1,035
If you drive with the widows up all the time can you hear it?
From reading this thread it doesn't seem like it's a safety issue just an annoying sound? I always drive windows up so hopefully I won't even know it's there? Thanks!! |
07-10-2019, 11:38 PM | #656 |
Rep 210
Ugh, I just noticed this happening on my 2018 and found this thread. Taking it to the dealership tomorrow. Even if not a safety issue, it's embarrassing being in a drive-thru and having your $120k SUV clicking like a junker when turning.
07-15-2019, 11:02 AM | #657 |
528
Rep 2,822
Drives: X5M F85
Mine was doing this badly. On the front right wheel. I took wheel off and noticed the 2 hub pins were ceazed. I drilled both out and slapped the wheel back on, then tightened the wheel bolts. Clicking is gone.
07-19-2019, 07:56 AM | #658 |
Rep 4
Hi,
pls help. my e70 have a click on driver wheel: https://www.youtube.com/watch?v=8a0-4PBh4NY wheel bearing? :s |
07-19-2019, 11:50 AM | #659 |
528
Rep 2,822
Drives: X5M F85
See if they will take the hub pins out and tighten the wheel bolts on as an alternative to the pis. My pins were stopping the hub from completely clamping together. After removing the pins my noise is gone. The E70 X5M guys were retrofitting the F85 rotors and the pins didn't line up so they used the lugbolts to secure the hub.... just an idea.
07-22-2019, 07:20 AM | #660 |
Rep 5
So I have the clicking on my '18 F85 now as well - started at around 11K Miles.
I have an appointment this Friday. It will be interesting to see if the fix is handled the same way here in Germany. |
