03-30-2019, 07:34 AM | #1 |
M Performance Class ;)
51
Rep 204
Any issues buying a X5 imported from Canada?
Found an interesting X5 that ticks all my boxes for options but it appears to originally been a Canadian car.
Car fax on it shows US Dept of Transportation: Vehicle imported and declared to meet US highway safety specifications Bond released on 02/05/2019 The pictures show the speedometer at MPH and temperature on climate control Fahrenheit. Wondering if there any other issues that I may run into? If I am looking for aftermarket warranty will they deny coverage? Just wondering if anyone else has experienced this living in some of the bordering states. |
03-30-2019, 09:03 AM | #2 |
Rep 196
If it was a Canadian x5 it would have had the 6wb digital cluster which is standard I believe in all the Canadian f15s. I could imagine, but never looked myself to be able to switch between metric and imperial measurements though the idrive pretty easily.
I bought mine from Quebec and brought it back to Ontario and it had to be reverted from French to English, which was easily done. My Canadian spec MY15 x5 doesn't use the same flat tire monitoring system as the US. Mine runs off the ABS/ wheel speed, where the US specs have the sensors in the wheels themselves. Although I had a MY19 g01 x3 loaner last week from BMW and it had the sensors in the wheels Canadian spec x5's unless equip with the LED headlights will have halogen fog lights. Not sure what else would be different on this side of the pond. Hope that helps a bit.
2015 X5 35d M sport
2017 340i M sport 1991 M5 1988 M5 |
03-30-2019, 10:20 AM | #3 | |
51
Rep 204
552 Full LED Lights 5AC Automatic high beams This is what car fax shows 08/22/2015 British Columbia Motor Vehicle Dept. Surrey, BC Registration issued or renewed First owner reported Registered as lease vehicle 12/05/2015 British Columbia Motor Vehicle Dept. Surrey, BC Registration issued or renewed Registered as lease vehicle 12/04/2016 British Columbia Motor Vehicle Dept. Surrey, BC Registration issued or renewed Registered as lease vehicle 05/08/2017 29,452 BMW MINI Langley Langley, BC 604-533-0269 https://openroadauto group.com/locations/ mini-langley Maintenance inspection completed Oil and filter changed 12/02/2017 British Columbia Motor Vehicle Dept. Surrey, BC Registration issued or renewed Registered as lease vehicle 12/17/2018 US Dept of Transportation Blaine,WA Vehicle imported and declared to meet US highway safety specifications Bond released on 02/05/2019 01/21/2019 51,841 Dealer Inventory Vehicle offered for sale |
03-30-2019, 10:39 AM | #4 |
Freude am Fahren.
835
Rep 1,287
Drives: F15 X5 xDrive35i
It's 6WB dashboard, you can switch mph to kph and back via iDrive. The same story with the temperature units.
Freude am Fahren.
03-30-2019, 10:40 AM | #5 |
Freude am Fahren.
835
Rep 1,287
sensors are available as an option in Canada.
Freude am Fahren.
03-30-2019, 10:43 AM | #6 |
51
Rep 204
Shouldn't be an issue as far as emissions and getting the car registered right? I am in NC and emissions laws are not to strict, nothing like CA.
Is there a code for he sensor ? I can check mcoder to see if has it? As far as the dash is 6WB different then whats in the US ? |
03-30-2019, 11:21 AM | #7 |
<3 Flat Four
217
Rep 754
looks like an "executive demo", so leased/driven by dealership management. most BMWs since the E90ish era can be switched between KM/H or MPH via settings.
2011 335is Le Mans Blue
03-30-2019, 11:36 AM | #8 |
51
Rep 204
03-30-2019, 11:38 AM | #9 |
Rep 535
canadian cars dont have tpms by default
oem factory warranty does not include brakes in canada but i have had a US dealer replace my brakes on my canadian car without issues. for a bc car, i would get a icbc history report. |
03-30-2019, 07:14 PM | #10 | |
Freude am Fahren.
835
Rep 1,287
But sensors are relatively cheap and easy to retrofit - you just need sensors and some coding. 2VB
Freude am Fahren.
03-30-2019, 08:15 PM | #11 |
1152
Rep 2,426
TPMS nice to have, but not that important. As long as you check your pressures regularly with a gauge and it has the flat monitor (which is would), it should be enough.
My biggest concern is that it shows there has only been one service done at 30k km?!
2015 BMW X5 xDrive50i
BMW CCA 509766 |
03-30-2019, 08:16 PM | #12 |
1152
Rep 2,426
Yes. I switch everything to metric when I drive in Canada. I don't look at the analog speedometer at all.
BMW CCA 509766 |
03-30-2019, 11:06 PM | #13 |
<3 Flat Four
217
Rep 754
pretty much dash, HUD, navigation, and even the HVAC changes when u change the settings in idrive.
03-31-2019, 06:45 AM | #14 |
51
Rep 204
01-19-2022, 10:17 PM | #15 | |
Rep 3
Thank you |
