04-15-2019, 01:23 PM | #1 |
Rep 4
Best OBD Adapter for coding X5
Hi All,
I am thinking of doing some basic coding to my 2018 X5. After watching couple of YouTube videos I found the easiest way would be to use BimmerCode app. Most of the people in these videos were using Vgate iCar Pro OBD adapter to use with BimmerCode app. However on Amazon I find three different version of this adapter. WiFi, Bluetooth 4.0 and Bluetooth 3.0. Anyone have experience with these adapters, which one should I go with ? Thanks, IP Last edited by imran7799; 04-15-2019 at 01:24 PM.. Reason: typo |
04-15-2019, 01:29 PM | #3 | |
Rep 1,343
I use vgate Bluetooth and it works well for me.
04-16-2019, 05:11 PM | #4 | |
Rep 7,165
04-16-2019, 07:08 PM | #5 |
ex deus machina
124
Rep 968
i personally bought this one,
https://www.ebay.com/itm/BMW-ENET-Et...72.m2749.l2649 i used the a combination of software from the listing and what i found on the forums, you can PM me for download links
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK Gone: E92 335i N54 468rwtq |
04-18-2019, 10:40 PM | #9 | |
Rep 7,165
04-18-2019, 11:42 PM | #10 |
231
Rep 369
I also have 2018 x5 and I'm using VeePeak OBDCheck Bluetooth, that's the one suggested by developer, so far so good, no problem with connection and never had any error codes
Current
12-05-2019, 10:04 AM | #11 | |
Rep 4
I briefly read the obd manual and followed it. Basically, make sure you turn on your Bluetooth and turn on airplane mode so nothing interferes with the signal. Make sure you have at least 50% battery life on your phone. You can start your engine to leave the car on or turn on the accessories by pressing the start/stop button (be sure to fasten seat belt so the accessories does not turn off). From there, plug in the device to your car, the blue light will lit up on the obd device. Then open up the coding app (Bimmercode) and press connect. It'll try to connect and read the vehicles code. From there when you go into one of the functions it'll load the codes you can do your car and towards it seems that it'll automatically back up your settings. Be sure to check the backups. It'll show date and time backed up. Once coded, it'll say success and then you can test it out. I started off by coding the side mirrors to have it folded and unfolded when pressing the lock/unlock key. Worked really well with no errors when I went in to bimmerlink app to check for errors. |
12-05-2019, 11:22 AM | #13 | |
Rep 2,527
If you don't want to start new thread why don't you use the existing one for Bimmercode one? https://f15.bimmerpost.com/forums/sh....php?t=1391908 |
12-05-2019, 01:31 PM | #14 | |
Wisdom Searcher
58
Rep 193
where is BimmerLink?
I have same adapter and it's working well. But I've never seen BimmerLink, and the app is not in the Google Play Store. Only BimmerCode. ??
BLUE HEAVEN
My cars - 2002 Lemans M5, 2006 Interlagos M3 |
12-05-2019, 01:46 PM | #15 |
Rep 10
12-05-2019, 03:14 PM | #16 | ||
Rep 4
No way this an ad 🙂 |
Tags |
bimmercode, bmw x5, coding, vgate |
