10-06-2016, 12:11 AM | #2 |
1150
Rep 2,426
Different lights. You would need to retrofit EU lights as well.
10-07-2016, 01:43 PM | #3 |
Rep 99
I mean our Fog Lights are there but just used for the Panic Brake. I find it hard to believe that we cant just pop in the correct button and have it coded. I have not done any coding and won't until I know I can do the taillights. Even if I can have the two rear fog lights light up everytime I step on brake pad would be a good bargain instead of the panic brake lighting.
kobe8136711.00 |
10-07-2016, 03:34 PM | #4 | |
Rep 595
If it could be done cheap and quickly someone might have figure out the way to do it in here. |
10-11-2016, 12:29 AM | #5 |
Rep 47
Search for posts by wdimagineer - he put the euro taillights, switch and wiring (from memory I think there's a different harness and connector) into his F85. If I recall he said he would not recommend the trouble.
10-06-2017, 10:40 AM | #6 |
Rep 1,011
AHCPAX5 i saw you were online recently so figured it would be good to resurrect this thread with photos that work and to say it is possible and very easily.
i know this is old but not sure where the confusion is on rear fogs not working on the f15. just wanted to update on my 2017 f15 USA build i installed the euro switch and coded rear fog lamps successfully. i like it a lot and integration into the 6WB also swapped over with the OEM lamp light is very clean and i like that all the buttons on the lighting switch panel light up unlike on my f30 where it was dead unless you also swapped the panel. |
5
10-06-2017, 10:53 AM | #7 | |
Rep 7,063
10-07-2017, 11:00 AM | #9 |
Rep 131
I did that on my f30 335 previously....Just got my f15 recently, haven't try this mod yet.
Monkiboy...Where did you get the switch and how did u code it. Pls share |
10-07-2017, 11:53 AM | #10 | |
Rep 1,011
switch i got off ebay international. part number i believe was 61319265303. https://www.ebay.co.uk/sch/i.html?_f...265303&_sop=15 you can also get from ecs-tuning or see more photos there: https://www.ecstuning.com/b-genuine-...319265303~oeb/ ecs was backordered for a while last i checked and much more expensive. it doesn't matter what trim comes around the switch if you find it the way i did as the switch panel pops out completely. check out the photos in my build thread for more detail and the install. |
10-07-2017, 01:07 PM | #11 |
Rep 18,713
I got a few sets that is for the F series without front fog light.
You can switch the board and the button to get it work on the F15. Coding if very easy. Should be on my cheatsheet.
10-08-2017, 04:26 AM | #13 |
Rep 1,887
And that is exactly why we don't get them here in America... too many idiots would drive around with them on all the time, just like they do with their front fog lights.
10-08-2017, 02:39 PM | #14 | |
Rep 18,713
Because they have smarter drivers?? Hahaha.
12-05-2021, 01:34 PM | #15 |
Rep 17
Hello, you have to change the European Headlight Switch only ? or there is a coding to do ? if yes is it possible with bimmercode ?
GS
12-05-2021, 04:30 PM | #16 |
Rep 2,511
12-06-2021, 07:34 AM | #17 | |
150
Rep 349
Things are different on the F15? No extra wiring required? Also, can you post a link to your install? |
12-06-2021, 10:02 AM | #18 | |
Rep 2,511
Install the Euro switch, code. Done. |
