06-27-2017, 10:44 PM | #1 |
Rep 97
18 inch wheels on X5 50i M Sport
Ive seen conflicting posts about whether 18inch wheels would fit on a 2015 x5 50i m sport? (for winter wheels) theyre from a 2008 e70 4.8 which I believe had the 365mm rotors anyone know if theyll fit?
07-02-2017, 07:16 PM | #2 |
Rep 97
Well since there seems to be no clear information on this topic, looks like I'll be the white mouse.
It was too good of a deal for basically new winter run flats, so I went ahead and bought the wheel/tire set, worst case ill throw it on my e70 for the winter. But the e70 18 inch style 209 wheels do fit BARELY on the f15 x5 50i though I feel perhaps I should get 19s anyway but it should work fine if I dont. See attached pics, perhaps this will help out someone who was wondering. |
10-30-2017, 03:08 PM | #3 |
Rep 1,066
Drives: 2015 X5 50i M Sport
Do you have any update on style 209 fitting on your F15 50i? I saw a local seller with this style of wheels and snow tires. Not sure if I should pull the trigger. Please let me know.
2019 Cayenne Turbo
10-30-2017, 03:57 PM | #4 |
Rep 109
Watch out for wheel weight to caliper contact.
nyalpine907380.00 |
10-31-2017, 12:10 PM | #5 |
Rep 1,066
That's good point. The calipers would fit within the wheel barrel but need to put the weight out like the OP.
2019 Cayenne Turbo
11-01-2017, 09:52 PM | #6 |
Rep 536
Please be careful with old sets, yours look manufactured in 2011. Even if unused if the DOT on the tires is too old, they may not be fit to drive at the indicated speed/load levels.
Present: 2014 X5 50i
11-02-2017, 10:47 AM | #7 |
Rep 1,066
Not all 18" wheels fit to this car due to the larger brake disc and caliper. The same with 550i that I owned before.
2019 Cayenne Turbo
11-03-2017, 08:17 AM | #9 | |
Rep 1,066
But it's alright for winter set up. The wheels will be covered with snow/mud/salt/sand most of the time.
2019 Cayenne Turbo
11-11-2017, 05:10 PM | #10 |
Rep 97
Thanks for all the replies. I decided to get a 19inch style 449 with pirelli winter runflats set just incase for the f15 x5 50i and will use the 18's on my old e70 4.8 (noticed the older tires but I use the old e70 on the weekends occasionally to grocery shop etc so it shouldnt be too dangerous)
