03-07-2023, 07:14 PM | #1 |
Rep 1,497
Powerflex Rear Sway Bar Bushings
Do they squeak over time? I've searched and many on here have used them, but have seen very little reviews on if they are noisy after 10-15K miles. Figured I'd go ahead replace these bushings while I'm doing both the front and rear sway bar end links.
03-08-2023, 04:30 PM | #2 |
Rep 1,532
Install them with marine grease, it'll stave off the noise for a very long time. Rear is thankfully easy to re-grease, compared to the front.
03-08-2023, 05:11 PM | #3 |
Rep 1,497
So in other words if they aren't greased then they will squeak? I'm def not messing with the fronts considering the complexity of getting to it.
03-09-2023, 02:28 AM | #4 |
Rep 1,532
Yes ungreased poly bushings will be noisy
M302_imola844.50 |
