      10-07-2020, 04:06 PM   #1
M3ANMACHINE
Admiral
M3ANMACHINE's Avatar
Drives: 2011 E90 M3 + 2014 F15 X5
2014 X5 sdrive 35i Vibration at Idle
Hey guys, so I recently had the spark plugs and valve cover gasket replaced on my wife's X5 and we are now experiencing a vibration at idle in both park and in drive/reverse. The vibration seems to be slightly worse when in gear.
The car seems to idle at what looks to be around 600rpm?
However upon accelerating or simply increasing RPM's as little as 250-500rpm, the vibration dissipates.
Any idea what the culprit could be? No CEL or anything.
Thank you in advance!
2020 FORD RAPTOR
2014 F15 X5 | M-SPORT
SOLD
2011 SG E90 M3 | 2008 AW E90 M3 | 2004 E46 M3
      10-07-2020, 04:25 PM   #2
S1nner
Drives: 2018 F15 N55, 2014 F10 N55
There might be a misfire that would cause a vibration, but not too bad to cause CEL. Did you change coils as well? I would check if there is any misfire, because I had the same issue.
      10-08-2020, 02:06 PM   #3
M3ANMACHINE
Admiral
Ran a scan and no misfire or anything. Wondering if the cause could be a bad bushing or engine mount even? It's just strange that it is only at idle rpm's
2020 FORD RAPTOR
SOLD
      10-08-2020, 02:37 PM   #4
S1nner
It could be, but you didn't have any vibration before changing plugs and valve cover right? Also I would make sure there is no air leak, however, I was told that even a small air lear will cause a CEL.
      03-25-2021, 05:16 PM   #5
M3ANMACHINE
Admiral
Has anybody changed their engine mounts themselves? How tough is the job?
2020 FORD RAPTOR
SOLD
      03-25-2021, 11:40 PM   #6
Vdesai0326
Drives: BMW X5
2015 bmw x5  [0.00]
Seems like the motor mount is starting to weaken/collapse probably on the passenger side
      03-26-2021, 11:22 PM   #7
M3ANMACHINE
Admiral
Yea I'm guessing motor mounts as well.
Would like to DIY but haven't found any tips or videos yet
2020 FORD RAPTOR
SOLD
      01-02-2024, 10:57 PM   #8
futurejl
Drives: 2015 X5 xdrive 35i, 2016 M235i
Did you end up replacing the engine mounts? If so, does it help?
      01-18-2024, 04:15 PM   #9
M3ANMACHINE
Admiral
Yes it did. Very much so. However, a good amount of noise and vibration when the AC is running. Might look into that as well
2020 FORD RAPTOR
SOLD
      01-29-2024, 12:50 PM   #10
futurejl
I just ordered the mounts and will replace them soon. Did you DIY or bring it to a shop? I also noticed vibration from the AC when it is on, is it the AC compressor going bad or just the mounting is getting loose?
      02-07-2024, 09:38 PM   #11
salvageland
Drives: X5 s35i
I also just ordered mounts for my 2014 s35i. Definitely interested in any tips for DIY job.
      02-12-2024, 01:23 AM   #12
Hashtag
Drives: X5
How much vibrations are you guys getting at idle? My indy noticed one of mounts are starting to wear, but I don't have any discernable vibration.
      03-09-2024, 10:22 AM   #13
M3ANMACHINE
Admiral
Yea after getting the mounts done i noticed that a lot of it was definitely from the AC. Haven’t determined if there’s a way to remedy it yet.
I had them done at my local shop, so unfortunately no tips
It’s not a ton of vibration but it’s noticeable
2020 FORD RAPTOR
SOLD
      03-10-2024, 01:54 AM   #14
salvageland
Drives: X5 s35i
Just an update...I installed a pair of new aftermarket mounts a couple of weeks ago and the idle vibration is completely gone! e70 mounts are the same part number for many of the aftermarket brands so check ebay for deals. I got both motor and trans mount as a kit for $80 shipped.
      03-10-2024, 09:12 AM   #15
Monkeypoop
39
Drives: 2017 Bmw X5 sDrive
Did you replace all the mounts yourself? If so, any tips? TIA
      03-10-2024, 07:41 PM   #16
Hashtag
Drives: X5
What are the potential issues if the mounts don't get replaced asap?
