04-25-2017, 05:01 PM | #3367 |
Rep 40,650
janexus8.00 |
04-25-2017, 07:52 PM | #3368 |
Rep 60
I'm getting an error when I'm trying to save my changes for FDL coding.
When I change the value to FF, I get this error. And there's an UNKNOWN right above it. I can edit other FDLs in HU_NBT2, but not this one or SPEEDLOCK_SPEEDVALUE_MAX to ff. Suggestions? |
04-25-2017, 07:58 PM | #3369 | |
Rep 40,650
HU_NBT2 => VIDEO_HANDBRAKE => nicht_aktiv HU_NBT2 => VIDEO_FRONT_LOCKED => nicht_aktiv HU_NBT2 => VIDEO_SPEEDLOCK_CONDITION => none HU_NBT2 => SPEEDLOCK_CAR_STANDSTILL => none HU_NBT2 => SPEEDLOCK_X_KMH_MAX => Werte = FF HU_NBT2 => SPEEDLOCK_X_KMH_MIN => Werte = FF HU_NBT2 => SPEEDLOCK_SPEEDVALUE_MIN => nicht_aktiv for ID4 or 1F for ID5 HU_NBT2 => SPEEDLOCK_SPEEDVALUE_MAX => nicht_aktiv for ID4 or 3F for ID5 (63 kmh or 39 mph)
04-25-2017, 08:15 PM | #3370 | |
Rep 60
I don't understand how the MIN MAX values work. Why 31 min and 63 max? Right now, the video shuts off at approx. 40 mph. Should I just enter 65 HEX for 100 mph as the max? |
04-25-2017, 08:35 PM | #3371 | |
Rep 40,650
For the Memory Byte used by SPEEDLOCK_SPEEDVALUE_MAX, you have the following: Maske=00111111b = SPEEDLOCK_SPEEDVALUE_MAX Maske=01000000b = IONISATOR Maske=10000000b = UNBELEGT Binary 00111111 is 3F Hexadecimal, which is 63 Decimal. This is the maximum value that is supported for SPEEDLOCK_SPEEDVALUE_MAX, thus max speed is 63 kmh or 39 mph.
04-26-2017, 04:28 AM | #3372 |
Rep 9
Hi guys, I've managed to successfully unlock enhanced Bluetooth and office on my F15 however I need a little help with having digital speed reading on the instrument panel. I've read that there is a way to have this so it reads the actual speed as opposed to copying from the analog speedometer. Once I've connected the car to esys, what's the next step? Is it the same as with enhanced Bluetooth as in I need to add a simple 3 digit code to the VO?
Many thanks in advance. |
04-26-2017, 07:59 AM | #3373 | |
Rep 60
04-26-2017, 09:26 PM | #3374 | |
Rep 8,364
There are two parameters in KOMBI:
04-28-2017, 07:09 AM | #3376 |
Rep 40,650
PM sent.
04-29-2017, 11:50 AM | #3379 |
Rep 40,650
04-29-2017, 12:38 PM | #3380 |
Neon Garden
85
Rep 402
Hey Shawn can you please PM the links of working E-Sys and ESysLauncher Premium. I have ESysLauncherPremiumSetup_2.6.2_Build_124.msi and after installation it keep asking activation code and TokenMaster never responded back with my request. I keep sending him a massages but no luck.
Thank you so much! |
04-29-2017, 12:46 PM | #3381 | |
Rep 40,650
04-29-2017, 02:48 PM | #3382 |
Neon Garden
85
Rep 402
I have E-Sys 3.28.1 with EsysLauncher Premium 2.7.1 V 135 and Launcher after i installation asking activation code.
I did install everything by installation instruction to many times with same issue. Any suggestions? |
04-29-2017, 02:54 PM | #3384 |
Rep 40,650
Do you use it in a Windows or Mac Virtual Machine?
04-29-2017, 03:08 PM | #3387 |
Rep 40,650
So long as you are NOT using Launcher PREMIUM in a Virtual machine, and in Control Panel you do NOT have any secondary language for the keyboard input installed, and the Region is set to United States, and the Language is set to English (United States), and Time Zone is set for a U.S. Time Zone, then Launcher PREMIUM should not ask for an Activation Code.
Are all the above conditions met?
04-29-2017, 03:13 PM | #3388 |
Neon Garden
85
Rep 402
Language is set to English (United States) Time Zone is set for a U.S. Time Zone No second language installed installation never mentioned about virtual machine so i did not install it in virtual machine |
