      04-21-2017, 08:05 PM   #1
Jkizzle
Drives: 2017 X5 35i xdrive M Sport
Aftermarket Air Filter or Cold Air Intake
I haven't read any threads about this. I was thinking about K&N drop in filters or a cold air intake. I don't see anyone posting about these. Do they not work on x5's or is there not much performance? I figured it would probably work well with the MPPK?
      04-21-2017, 10:58 PM   #2
TOPEC
<3 Flat Four
Drives: 335is LM Blue
no cold air intakes are available, only a handful of manufactures makes short ram intake for the X5, BMS and dinan comes to mind. K&N drop in panel filters yields no performance gains, only good as a replacement filter when ur oem gets dirty. do remember tho that K&N filters are usually oiled vs oem dry paper material filters. the oil is supposed to help with filtering and catching dirt, but some people dont like oiled filters due to the fact that the oil can be sucked into the intake track and coat the intake run/sensors if its oiled improperly.
2011 335is Le Mans Blue
      04-21-2017, 11:47 PM   #3
Jkizzle
Wow... thanks for the info. Usually that's one of the first things I change. I thought it was weird no one discusses it. Thanks.
      04-22-2017, 05:34 AM   #4
Kzang
Kzang's Avatar
3221
Drives: 2015 X5 35i Msport SG
Us BMW people are more educated than the other car brands
But seriously, K&N filter drop in filter does absolutely nothing for performance.
      04-22-2017, 10:37 AM   #5
Flying Ace
Flying Ace's Avatar
4983
Drives: G05 45e, 997.1 & 991.1 GT3s
Doesn't do anything for your car. Car is designed and tuned to optimize performance already. This isn't a 1987 Honda Accord
      04-22-2017, 11:34 AM   #6
Jkizzle
Yeah I know it's not a Honda Accord. I had K&N intakes on my M6 which sounded awesome! Most BMW's benefit from getting more air into the motor. Your comment is ridiculous!
      04-22-2017, 01:51 PM   #7
TOPEC
<3 Flat Four
doesnt that apply to every and all engines in the world? fact is modern oem intakes are designed and optimized with the largest amount of air flow and least amount of restriction already, so at stock and close to stock power levels, any aftermarket intake will gain nothing other than noise.
      04-22-2017, 02:28 PM   #8
Kzang
Kzang's Avatar
3221
Haha yep!
Start the video at 4:45
      04-22-2017, 06:24 PM   #9
Flying Ace
Flying Ace's Avatar
4983
Yeah, but intake noise = 10 street cred HP
      04-23-2017, 06:30 AM   #10
mefferso
Drives: 2010 335d
Check out post# 126 http://www.e90post.com/forums/showth...1233118&page=6
That's a dyno comparison between a "modern oem intake" and an aftermarket one on a BMW. +15hp and 25 ft.lbs by just swapping out the intakes
      04-23-2017, 01:15 PM   #11
Jkizzle
I know that Dinan makes a cold air intake that added 12 to 14hp on the X5M on a dunk. I guess the M stock intake isn't as efficient as the standard X5.
      04-23-2017, 09:52 PM   #12
Enrico 35d
Drives: 2014 x5 35d
Just using aftermarket air filters will yield no gain. Stay away from oiled filters as they can screw up the MAF's. A proper cold air setup with larger ducting and a relocated intake would yield marginal gains.
For what it would cost, you're better off going with a tune from race chip or JB
Search this Thread:
Advanced Search
