      04-24-2017, 03:21 PM   #1
Chancepowell
Drives: E90 M3
Loud intake noise on X35d
I just had my entire fuel system replaced under warranty due to a damaged high pressure fuel pump which subsequently led to "metal" pieces caught in the injectors. Everything was replace from lines to the tank itself.
When the X5 was returned I thought I noticed the engine being louder than before it was in the shop. It sounds like a loud sucking noise (I know- jokes here please) similar to the noise my Vacuum cleaner makes. The acceleration seems fine but I swear it sounds different.
Is the sound normal or is something not right with the engine?
      04-24-2017, 03:23 PM   #2
Kzang
Kzang's Avatar
3239
Drives: 2015 X5 35i Msport SG
Make sure the service guys closed the air intake filter cover correctly. If that is loose then it will make a louder engine noise.
      04-24-2017, 06:19 PM   #3
stewy604
stewy604's Avatar
290
Agreed, something's not right. Pop the hood and check the intake routing and make sure its all snug.
2007 Suzuki GSX-R 750
      05-01-2017, 04:57 PM   #4
Chancepowell
Drives: E90 M3
thank you
I poked around and found the housing for the filter was open, broken or missing clip on one side
Good call and thanks
