10-18-2017, 07:38 AM | #3763 | |||
Rep 473
10-18-2017, 09:47 AM | #3764 |
Rep 8,364
10-18-2017, 09:21 PM | #3765 | |
Rep 473
1. I have 2018 x5, I step level is f025-17-07-504 2. Got latest from Mega data files (light v3.62.5) 3. Coded several modules w/o problems 4. Wanted to code open/close trunk with keys and button. After reading and activating FA I see HKFM2. Read coding data for CAFD section. No errors. Do Edit FL and on the next screen I see full structure but not the parameters and their values. Again, no errors. Tried several times to disconnect/connect to car, re read FA, this module - the same result Any suggestions? Thanks in advance! |
10-18-2017, 10:35 PM | #3766 | |
Rep 8,364
10-18-2017, 10:41 PM | #3767 | |
Rep 591
10-19-2017, 04:51 AM | #3768 | ||
Rep 473
I see the list of 300x numbers, but not the names of the functions and subfolders where you can change the values |
10-19-2017, 07:21 AM | #3769 | ||
Rep 193
I just bought the WiFi adapter and BimmerCode app. Hopefully I can change it back to 100%. |
10-19-2017, 07:51 AM | #3770 |
Rep 473
Coding DRL with headlights and parking on
All,
Thanks for all your assistance, much appreciated. Have 2018 x5 with comes with standard Xenon headlights but hallo wings are LEDs. Saw post about coding parameters ( from 7v to 13v) in BODY unit instead of FLE folders. Would the same approach and values work in my car? Thanks in advance! |
10-19-2017, 10:38 AM | #3771 | |
Rep 8,364
10-19-2017, 10:47 AM | #3772 | ||
Rep 473
10-19-2017, 12:11 PM | #3773 |
Rep 8,364
10-19-2017, 12:48 PM | #3774 | |
Rep 473
10-19-2017, 05:34 PM | #3775 |
Rep 8,364
10-19-2017, 05:49 PM | #3776 |
Rep 473
10-19-2017, 05:50 PM | #3777 | |||
Rep 473
10-19-2017, 08:37 PM | #3778 |
126
Rep 303
2017 x5 here ...e-sys
so far no DVDIM after 39MPH trunk cant close with remote no fog ( corner) lights on with low beam lights ( respect to all but please dont comment or judge,if you dont know how to fix ) Vmax= 135mph.....anyone know how to fix them via e-sys yet .. i had tried VMAX to 250kmh but still locked on 135mph... Tried but didn't work turn signal x 5 Last edited by Katsumoto; 10-19-2017 at 08:48 PM.. Reason: forgot |
10-21-2017, 02:01 PM | #3779 |
Rep 11
Hi all.
Tried coding the dimming mirror function on my x5 m50d (BDC_BODY 3120 as per the coding cheat sheet). Changed value from default 20 to 39. In doing so, I noticed my interior led strip lights and footwell lights no longer work. There were no errors whilst coding and I'm certain this value does affect the interior lights. Anyone seen this before? Many thanks. |
10-21-2017, 06:23 PM | #3783 |
Rep 123
May I get a link to latest software? I used this guide to code 2015 X6. Now I have 2017 X6M, can I use software and guide the same way?
Thank you in advance! |
10-21-2017, 10:51 PM | #3784 | |
Rep 8,364
HKFM2 with CAFD_00005710 and CAFD_0000570E are both unmapped. Though, position of codes has not moved so you can use CAFD_00002098 or Launcher Cheat Codes as reference.
If coded correctly it will. That should be on from factory. Vmax can only be changed within 10 operating hours. For turn signal, there are two functions. You should use newer one with your firmware. |
