      07-28-2016, 06:37 PM   #1
aman27
Drives: 2016 F15 x35i MSport
F15 spare options
Hey everyone:
Im planning a roadtrip soon and was wondering whats the best option that everyone else runs with?
Spare donut + jack kit? (Most costly option)
Fix a flat? (Low cost)
Im running 21inch RFTs, will the fix a flat even work?
      07-28-2016, 07:25 PM   #2
TOPEC
<3 Flat Four
Drives: 335is LM Blue
U have run flats n u want a spare tire why?
      07-28-2016, 07:27 PM   #3
aman27
Just in case i get a flat or tire blows on the highway..planning a 10-12hr road trip with kids and dont want to be stuck by the side of the hwy
      07-28-2016, 08:07 PM   #4
alphaod
alphaod's Avatar
Definitely get a spare. I had a blowout (cut sidewall) and one big puncture on the highway both on runflats, thank goodness I had a spare. Blowout just outside of Mt. Rushmore on the way to NY and recently on the LIE I couldn't avoid it when a truck tire blew up in front of me and cut my tire up real bad. Already did about 1200 miles on the spare.
There isn't much for choice. I got mine from bimmerzone. The E70 one is the same for the F15. As for jack... I could have gone the BMW way, but instead I got a 6 ton bottle jack and tire iron from my local auto parts store. Just make sure there is at least 15" height if you have rear air suspension. I got a 2 ton the first time and it didn't reach at all. Also get the BMW jackpad if you don't go OEM jack. I got mine on Amazon.
      07-29-2016, 09:53 AM   #5
stewy604
stewy604's Avatar
290
I swapped to go flat Conti DWS06's earlier this year. I carry a small/portable compressor that runs off 12v and a plug kit. Both fit easily into the driver's side luggage area 'cubby.'
2007 Suzuki GSX-R 750
      07-29-2016, 09:57 AM   #6
karzrkewl
Drives: 2015 X5 Msport
I also swapped the stock RFT's for the DWS06's. I ordered a spare tired and a jack at the same time.
      07-29-2016, 09:59 AM   #7
stewy604
stewy604's Avatar
290
I've got a third row, so that wasn't an option for me unfortunately.
      07-29-2016, 10:41 AM   #8
alphaod
alphaod's Avatar
I also have third row seats. Unless I know I'm going to hauling stuff, I just keep my spare in the trunk. I have a Weathertech cargo liner to keep it all clean and the spare doesn't move. I've seen and used my spare to the point that I realized how indispensable it is when you really need it.
The 6 ton bottle jack I mentioned earlier fits perfectly in the little cubby behind the third row seats. 8 ton bottle jacks and scissor jacks do not fit. 2/4 ton bottle jacks fit of course, but with the air suspension they do not lift the rear tire off the ground high enough, so they're useless. Also put a breaker bar in there because a lot of shops use an air gun to put on tires.
I also keep a tire plug kit, pliers (for pulling out screws and stuff), wheel chocks, an air compressor in the left cubby behind the cover.
      08-08-2016, 10:30 PM   #9
karzrkewl
Ah yes, with the 3rd row that limits your options. I keep a first aid kit, reflective vest, flashlight and fire extinguisher in the left cubby. A set of reflective triangles goes in with the spare tire and jack.
      08-12-2016, 04:56 PM   #10
Class5Kayaker
Class5Kayaker's Avatar
Drives: 2016 BMW F15, 2014 Porsche 991
My "Spare" in both my BMWs is a high-quality 12v air compressor (you're gonna pay $80-$100 but it's worth it), a $20 scissor jack from Harbor Freight, a Torque Wrench w/ 17MM deep socket w/ plastic outer-casing, and the StopNGo tire plug kit.
2016 BMW F15 xDrive 35i - Imperial Blue Metallic
2014 Porsche 991- Sapphire Blue Metallic
      08-12-2016, 09:31 PM   #11
Since you'll have your wife and kids with you, I'd go for the spare tire + jack option. Cannot take any risks.
