10-05-2017, 10:10 PM | #177 | |||
Registered Member
661
Rep 608
Edit: Fixed the original quote by expidia Last edited by Chadmatic; 10-05-2017 at 10:25 PM.. |
10-06-2017, 07:49 AM | #178 |
162
Rep 317
Here is a better one for you. I’m tired of reading your curt and inciteful responses to others in the forum.
No point in responding back to me as I’ve just banished you to my “ignore list”. Forums always seem to unearth posters that for some reason try and ruin the experience for everyone else. ignore list = drain the swamp Buh Bye
2016 X5 35i color: Jet Black
2014 Audi Q5 Premier Plus color: Ibis White Last edited by expidia; 10-06-2017 at 08:00 AM.. |
10-06-2017, 11:00 AM | #179 | |
Registered Member
661
Rep 608
Edit: I just read through all of my posts on this thread and I am just not seeing how I could have offended you or anybody else on any level, especially enough for you to react in such an extreme fashion. Maybe you’re upset with my quote in post #175 above referring to people as idiots, but those are literally your words and not mine because you didn’t end my original quote properly in post #171 which is why I fixed it in post #177. It starts getting very confusing when other member’s words suddenly become your words. Last edited by Chadmatic; 10-08-2017 at 01:50 PM.. |
iconoclast7265.50 |
10-06-2017, 02:47 PM | #180 | |
Rep 180
iconoclast7265.50 Chadmatic660.50 |
10-08-2017, 09:34 AM | #181 |
Rep 12
I got my front windows tinted with huper optic ceramic. Waited on the windshield. Had a couple hot days in SoCal and it has helped.
But I think the issue is not the AC unit. At least for me it gets cold and works OK. But the cabin heat is definitely due to the large moonroof. I always keep it closed, but on very hot days you can just feel the heat come through. Pass your hand along the roof and it’s basically all hot air flowing down so that the AC just has to keep up with the “heater”. And being taller it just feels like the cabin doesn’t cool down. So I think the design remediation is a stronger layer between the glass to insulate from heat/cold |
Ex_Stig2594.00 deutsch1003936.00 |
10-08-2017, 05:56 PM | #182 | |
162
Rep 317
2014 Audi Q5 Premier Plus color: Ibis White Last edited by expidia; 10-08-2017 at 08:04 PM.. |
deutsch1003936.00 |
10-13-2017, 10:50 AM | #183 |
Rep 2,683
Drives: '24 X7 M60i
Temps were in the upper 60s this morning on my drive to the office. I finally got to experience what some of you are posting about. I finally had to turn my AC down because I was getting too cold. Of course, I had the windows open too.
Ex Stig
'25 M5 Touring (on the list, first slot) '24 X7 M60i '22 M5 CS - (sold) |
10-14-2017, 10:18 AM | #184 | |
Registered Member
661
Rep 608
I just can’t imagine that BMW would go to such extreme measures as to spend so much of their time and resources by bringing in a special team to diagnose your AC system and then stop there and write you (two?) checks rather than simply replace it if there was something wrong with it. In the grand scheme of things, it would be so easy for them to replace it if it were faulty. Btw... I’m not trying to encite you, I’m genuinely having a hard time understanding this. |
10-14-2017, 10:54 AM | #185 | |
Rep 2,683
Drives: '24 X7 M60i
Basically, the only next step that I could take was a class action lawsuit. BMW NA continued to fall back on their language that the system was "working as designed" and that there was nothing to replace. Since this version of the X5 has been in production for many years there is no way that they could admit that there is a wide spread issue. At the end of the day, I just ran out of time, energy and resources to continue to fight them. I took the money because it had no strings attached. I didn't have to sign any type of NDA or indemnification. It doesn't stop me from pursuing things in the future and, if a class action suit were to start, I would be one of the first to sign up. BTW, we got 2 checks because we have 2 X5s (got them both on the same day).
Ex Stig
deutsch1003936.00 |
10-28-2017, 01:55 PM | #186 |
Registered Member
661
Rep 608
We just had a record-breaking heat wave come through southern California, the temperatures reached 105+ degrees during the day and cooled down to the low 90s - upper 80s at night which is incredibly hot for the end of October around here.
I had to park my car in a baking-hot parking lot in direct sun for the better part of the day so I used my windshield sunshade and closed my sunroof cover, when I returned the interior was like an oven! I vented the sunroof, opened all four windows and cranked the AC. It had absolutely no problem cooling the cabin down quickly and within 5 minutes I had to dial it back because it was getting too cold, which leads me to believe that you must have a defect in your AC system. |
10-28-2017, 09:37 PM | #187 | |
Rep 2,382
When I opened the door, it literally felt like an oven inside. I started my '17 35d. The HAVC was set to AUTO 70F and the blower intensity to Level III. In our M6 and G63 (and every other car I have had with auto HVAC since the early 1990's)...with the outside temp over 100F and the inside of the car at least 120-130F, the HVAC set to AUTO, the A/C would just blast full power to cool the car down. NOT my X5...the air was VERY cold coming out but just a gentle, light fan blower. WTF? With the outside and inside temp so hot...my A/C on AUTO 70 should have been blasting. Annoying!!! |
10-29-2017, 04:46 AM | #188 |
Rep 188
You need to set the fan speed indicator to Max. When set to auto the system will use whatever fan speed it needs up to the setting you have specified. If you have it set in 3 then 3 will be the most you ever see!
deutsch1003936.00 |
10-29-2017, 08:25 AM | #189 | |
162
Rep 317
The AUTO setting (especially on a high priced luxury vehicle) should do just that . . . You select your temperature setting and the HVAC system should then take over and do whatever it takes and as fast as it can to get that inside temp to as example 70 degrees. We shouldn't have to futz around with speeds of the fan (thats just plain ridiculous). I could see the occasional use of MAX on a super hot day and the car was in the sun to help blow out the super heated air but that should take like 3 minutes. Then the AUTO should take over. This is the way "ALL" of my other former vehicle's automatic climate control operated and any rental I've ever driven. X5's have really missed the boat here with their HVAC system and it's going to be a deal breaker for me in 2 years when I sell this one and buy my next SUV. Damn shame that my Wife's Audi Q5 has an MSRP for $15000 leass than my X5 and her AUTO AC works flawlessly. You don't even know its there. You set the temp and never even think about it after that. And I don't even live in a hot climate. The Northeast doesn't have long periods of sweltering days.
2014 Audi Q5 Premier Plus color: Ibis White |
deutsch1003936.00 |
10-29-2017, 09:48 AM | #190 | |
Rep 2,382
My past few cars: 2014 Range Rover Supercharged, 2016 G550, 2016 911S, Bentley Mulsanne and 2 Phantoms and 2 Ghosts...HVAC set to Auto, was just that.. AUTO. If any of these cars were exposed to hot temps, the A/C on AUTO would just pump full power, and then gradually lower the fan speed as the interior cabin cooled down. The X5 should do the same. Btw, IMO, the best A/C I have ever, ever experienced is Range Rover and Ford!! |
10-29-2017, 08:15 PM | #191 |
Rep 188
That's as may be guys, but push one button twice more in the lifetime of your ownership and it will do what you want.
You choose whether the depreciation of an early change of ownership to [insert make and model of you choice] is worth that. I chose two more button presses and lost the stress. |
10-30-2017, 11:59 AM | #192 |
Registered Member
661
Rep 608
OP has updated his first post, BMW was able to fix his AC and all is well. If you feel that the AC in your car is not working properly then I would encourage you to schedule it for service.
10-30-2017, 01:45 PM | #193 |
Rep 2,683
Drives: '24 X7 M60i
They were unable to fix my X5 because they say it is "operating as designed".
Next summer it will be just as miserable as this summer. The only suggestion I got from my dealership (after admitting that the X5 has significant ac issues) was to put it up on lease trader.
Ex Stig
10-30-2017, 02:34 PM | #194 | |
Registered Member
661
Rep 608
deutsch1003936.00 |
10-30-2017, 02:45 PM | #195 |
Rep 2,683
Drives: '24 X7 M60i
It was the regional technical engineer who said it was working as designed. Not the dealership.
Ex Stig
10-30-2017, 04:07 PM | #197 |
Rep 2,683
Drives: '24 X7 M60i
No. My dealership is the one who said that the X5 has issues.
Ex Stig
deutsch1003936.00 |
11-05-2017, 08:38 AM | #198 |
Rep 2,382
Bringing this old thread back to life, yet once again (sorry!).
Yesterday, I did an "experiment". It was not hot outside, maybe 70F (beautiful blue skies, puffy white clouds, breezy and bright sun). I parked my new '17 35d in full sun, while I went out to lunch. I left a new, high quality thermometer in the car while I ate. When I locked the car, the car said 70/71F (thermometer was not placed in sun, but on the driver footwell, in full darkness). When I returned over an hour later, the interior of the car was 95F. Considering outside was about 70F (or even less)...95F felt very uncomfortable. I had my HVAC set to AUTO 70F and I even had the intensity set to max/5 bars!! 5 bars! Now with a cabin temp of 95F, our M6 or G63 would have kicked the A/C to near max to pull the temp down to 70F as quickly as it could. If this would have been Range Rover or any Ford...it would have froze you out doing this!!! Oh...not the F15. 70F AUTO with 5 bars of blower intensity.....cold air output, but a mere dribble of air coming out of all vents. Without any exaggeration, I could not even feel cooled air hit my face or body! I really, really do not understand how and why a lot of our F15s behave like this. It cannot be right. I hate it actually. I had 3 E70s and 2 E53s, and A/C never behaved this poorly (oddly '06 E90 330i was as bad or worse than F15). Ughhhhh! But, Happy Sunday!! |
