      05-06-2016, 08:06 AM   #133
atomic80
Drives: 997TT
Originally Posted by kyledo123 View Post
Unfortunately Reighngold is required which was the only reason it took me so long.
Can you clarify what Reighngold is? Is that something that's in the latest version of pszd?
Xolinlevh175.00
      05-09-2016, 03:26 PM   #134
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Rheingold is separate piece of diagnostic and coding software that also comes with over 200 documents of step-by-step repair and replacement guides. Also goes by ISTA+, ISTA-P, and ISTA-D.
      10-11-2016, 07:28 AM   #135
lyjfe_ning
Drives: BMW X5 F15 30D
Thanks for sharing. I am working on mine. Is there any chance you could please send me the link for Reighngold 3.45?
Hi PlayTookies,
The whole retrofitting process is pretty simple if you know what to do.
For me it took around 2 weeks as I was clueless, but in reality it should only take a couple hours.
Below is a list of parts I used.
32306859265 - Touch sensor module
32307851355 - Steering wheel wiring harness for Touch sensor module
32307851513 - M sports steering wheel leather without heat as my car didn't come with heat.
61317847654 - Switch, MF steering wheel, M-Sport (You do not need this however reighngold complains about the old switch unit)
After installing all the hardware you need to VO code BDC_Body, KAFAS2 and KOMBI and run a calculated test plan in reighngold in order to calibrate the new touch sensor.
I recommend downloading version 3.45 as the other versions gave me trouble when trying to run the calculated test plan.
      11-02-2016, 09:53 PM   #136
DGStopGo
Drives: X5 Space Gray M-Sport 35i
I have Acc stop go on my 16
How much will it cost for me to retrofit TJA ?
      11-22-2016, 02:06 PM   #137
ThunderTiger0806
Drives: bmw x5
Originally Posted by McDonaldD View Post
32306859265 - Touch sensor module ~60 euro
32307851355 - Steering wheel wiring harness for Touch sensor module ~27 euro
32307851514 - M Sport touch-enabled steering wheel w/heat ~600 euro
My brother lives in Germany so I had him ship me the parts.
I, too, decided to skip swapping out the buttons on my steering wheel - it would have been ~200 euro for the new switch cluster but I did not want to call attention to the feature.
Photos are attached but the process is pretty simple. The "touch enabled wheel" is definitely a different part, it has an additional set of wires that my m-sport w/heat did not. These wires connect to the new touch module. The new wiring harness is required for all US vehicles and is basically an extension that has the new leads for the touch module.
Not sure if all of these were entirely necessary but I VO coded BDC, KAFAS2 and KOMBI. The buttons and notifications worked at this point but the new module caused a malfunction each time I tried to activate it. I used Rheingold to clear the errors and it automatically calibrated the new touch module as part of its "calculated test plan."
Attachment 1120460
Attachment 1120457
Attachment 1120458
Attachment 1120461
Attachment 1120462
Attachment 1120467
Attachment 1120464
Attachment 1120465
Hi, as the I got all the parts installed but once I press the bottom it shows TJA fail so how you connect the car with Rheingold with enthernet cable or Dcan cable and what is the procedures with Rheingold?
Thanks for help
      11-23-2016, 04:41 AM   #138
ThunderTiger0806
Drives: bmw x5
Hi how did you go with your retrofit? I'm done all the hardware coding got TJA failure once I press the new button got Rheingold bust can not find any fault memory so it can not start a calculate test.
Any idear
Thanks
      11-23-2016, 05:03 AM   #139
ThunderTiger0806
Drives: bmw x5
Hi PlayTookies,
Hi my Rheingold cannot find any fault so how I can let it go for a calculate test to calibrate the touch sensor, now once I press on the new button idrive will show TJA failure
Need help please
Thanks
      04-30-2017, 10:36 AM   #140
davedave1234
Drives: 135i (on order)
Need help please
Thanks
I am pretty new to this myself but did you code the features into the system? Rheingold is just for the calibration process, from what I gather from the other post's. I forget the software used for coding but there is a section on this forum about it that will help. Anyway good luck and hope that helps somewhat.
      04-10-2018, 12:16 PM   #141
dwissing
Person
dwissing's Avatar
Drives: 2016 X5 50i
Need Rheingold
I think I am going to try this if I can find the parts (touch wheel, sensor, wire harness).
Can anyone PM a link to get Rheingold?
2016 X5 50i M Sport with ACC, Driver Assist+
      04-10-2018, 05:35 PM   #142
Twin Peaks
N00B
Twin Peaks's Avatar
Drives: X5 50i (F15)
These would be the parts (I think) for my 2014 X5 50i. I did ask my local BMW dealership and parts told me it should all be plug & play minus the coding. I didn't ask about coding.
F15 Traffic Jam Assistant
http://f15.bimmerpost.com/forums/sho...fic+jam&page=6
HTML Code:
32306859265 - Touch sensor module.
32307851355 - Steering wheel wiring harness for Touch sensor module.
32307851513 - M sports steering wheel leather.
The owls are not what they seem!
      05-29-2018, 09:27 AM   #143
dwissing
Person
dwissing's Avatar
Drives: 2016 X5 50i
An update on adding TJA to my 2016 US F15...
I have it working, and it's pretty nice, but it depends on very specific conditions to actually work. most of the traffic I sit in isn't on a large highway, so I get a lot of the "lane too narrow or not detected" messages and then it shuts off. I suspect the version on the G series will be more advanced.
I used the $300 Quidzel module so I didn't have to change the steering wheel or anything else and I don't have to keep hands on the wheel for it to work, but I'm usually holding the wheel anyway.
spike5150421.50
      05-29-2018, 01:14 PM   #144
spike5150
Drives: 2020 X5 M50i
Wow thanks for sharing this! Did you need the Rheingold software, or is just ESYS coding required? I have been pining for this feature, just didn't want the retrofit hassle.
      05-29-2018, 05:43 PM   #145
dwissing
Person
dwissing's Avatar
Drives: 2016 X5 50i
I just used Esys for coding. Didn’t need to calibrate. The Quidzel chip is tiny and easy to install. You just remove the airbag (two spring clips) and plug in the module into the existing 3 wire harness where the buttons are, then pop the airbag back on.
spike5150421.50
      05-29-2018, 06:48 PM   #146
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Hmm didn't hear there was an aftermarket quick fix. Given it's cheaper than buying a whole new wheel and then doing all the wiring etc. why hasn't this been more wifey popular route?
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      05-30-2018, 08:59 AM   #147
spike5150
Cool, thanks. Ordered one yesterday so we’ll see how it goes. I’ll post some pics of the install.
      05-30-2018, 09:06 AM   #148
spike5150
Quick question - do you plug the module in line with the cruise control buttons on the left side of the wheel?
*Never mind - they sent me a video link. Actually plugs into the right side (which seems counterintuitive)
      05-30-2018, 02:35 PM   #149
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
That is weird but sweet.
'06 C55 AMG (sold)
      05-30-2018, 09:08 PM   #150
dwissing
Person
dwissing's Avatar
Drives: 2016 X5 50i
That's why I figured I'd post about it. Also, it's very new, especially for the F15.
      05-30-2018, 09:23 PM   #151
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Just so I'm understanding this correctly this whole thing is to allow the car to actually manipulate the steering wheel to follow the car in front of you. Up to a max speed of 63mph it coded.
'06 C55 AMG (sold)
      05-30-2018, 10:44 PM   #152
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Also I noticed they keep saying "test" and I good to assume this is a legal term they're adding to describe the function as to not get in trouble? It does give you full function of TJA. They even mention on the site to use this and then you can purchase the full retro kit?! A bit Confusing
'06 C55 AMG (sold)
      05-31-2018, 09:53 AM   #153
spike5150
Correct. Its called Congestion Assistant in the US Owners Manual.
      05-31-2018, 09:55 AM   #154
spike5150
I'm not a lawyer, but...
From reading the website, this module emulates the signal output by the OEM touch steering wheel and module. So, the car thinks you are holding onto the wheel, but you don't actually have to be.
Mine arrives Monday. Once I get it up and running I will report back.
driving assistant, traffic assistant
