08-21-2015, 10:39 AM | #23 |
866
Rep 611
I think all the points about dedicated snows being superior in winter safety are on point. You have upgrade 20" wheels right now. Those tires will last you 20-25K miles, 30K if you are really lucky. I priced out OEM replacements which are the Contisportcontacts on Tirerack at ~$1800 for tires alone. The Dunlops are ~$1600. A dedicate 18" setup with Blizzak DM-V1's on a cheap set up rims are $1100. The winters tires will last about the same number of miles as the summers. This is a nice savings of $500-700, the added winter safety, and save abuse on your 20" rims.
08-21-2015, 10:44 PM | #25 | |
Rep 1,181
255/55/18 DM-V1s on Sport Edition wheels. Totally understand that severe winter folks who swap out for the season would want nicer/bigger wheels since they have to ride on the setup for months at a time. This setup is perfect for me as I swap in/out from the comforts of my garage, so don't care too much about looks. Heck, if I could find black steel wheels that fit, I'd do that...
08-22-2015, 01:10 PM | #26 |
Russian in a Bimmer
566
Rep 5,619
Silly question
Why are 19's better than 20's with winters on for the snow? Isn't wider better since they cover more ground?
2013 X6 - retired
2015 X6 - retired 2015 435GC - retired 2018 X5 40e - retired 2020 X5 M50i - Current |
08-22-2015, 02:48 PM | #27 |
866
Rep 611
You want wider in dry weather for road grip. On wet and snow cover roads, the narrower the tire, the better. You have less surface to slip and slide on.
08-22-2015, 04:32 PM | #28 |
Rep 5,066
Wider tires also tend to hydroplane more ( more surface area ) and narrower tires sort of cut through the snow easier.
08-23-2015, 03:22 PM | #29 | |
Rep 774
I have studded 20 inch Hakka 8 all around. |
08-23-2015, 03:29 PM | #30 | ||
Rep 709
08-23-2015, 03:34 PM | #31 |
Rep 774
Wider is worse with snow as the weight of the car is spread over a larger area. With wider tire harder to get traction on a slippery road, other way around on dry road, feg studded tires or the tire tread gets less force to dig into ice/snow. Also the wide tire doesnt fit the dry surface tracks made by other cars on snowy roads + wide tire is more prone to follow plow stripes and at times the rear can be very lively. Also in slush snow the narrow tire cuts easier through to the dry surface below, a wide tire might slide on the surface more, compare it to aquaplaning, same effect, wide tires are worse. So more points to the narrow tire in winter. 20 inch usually have less tire tread than 19 inch.
08-23-2015, 03:40 PM | #32 |
Rep 774
Sorry, I dont understand what you mean. An awd car stopps exactly like a rwd or fwd car, or even worse as it weighs more. The only thing that affects braking are the brakes and traction of the tire! A studded tire might stop more poorly on a dry road, but much better on ice, so you need to evaluate the winters you have.
08-23-2015, 03:48 PM | #33 | |
Rep 774
08-23-2015, 04:02 PM | #34 | |
Rep 1,181
08-23-2015, 04:03 PM | #35 |
Rep 709
kip1... an AWD vehicle will provide better traction than a RWD or FWD car in the snow. It is easier to brake and come to a complete stop when you are under control (with good traction) versus being out of control (with poor traction). It's true that in dry conditions AWD braking and F/RWD braking are the same. But, if you're fishtailing in your RWD car, you can't tell me that you'll stop just as well as the AWD that's under control.
If that were the case, there would be no AWD and we would just swap out tires based on the conditions. |
08-23-2015, 04:45 PM | #37 | |
Rep 709
08-24-2015, 01:07 AM | #38 |
Rep 774
Mmmm. Thats exactly what we do in tje Northern countries. Sorry, but you are just wrong in saying that awd cars brake better. Its acceleration and handling that the awd helps in. We have often snow from October to April, so I have a little experience with driving in the snow. A perfect example was once when first snow came and I was on Holiday from University and thought my dads awd Volvo had winter tires, while my car didnt. I went up a hill very slowly and my last thought was, darn its slippery as the car barely made it up the hill. I braked and suddenly found out that I am sliding without any control down the hill on the other side. By miracle I didnt hit anything. My dad also had summer tires, absolutely no traction while braking, so full throttle and up the hill, and down the hill without braking and trying just to control the car with the throttle. Never mentioned this to my parents, but it told me awd is nothing without proper tires.
08-24-2015, 01:56 AM | #39 |
Rep 497
this is the reason why i stuck with the stock 19"s. getting all season/ winter tires on those and getting aftermarket 21" or 22" for the rest of the seasons. Although the stock 20" upgrades were tempting, skinnier/ smaller sized rims were a better option for the winter
F85 (17) - DG/AB
F87 6MT (20) - Comp - BSM F80 DCT (18) - Comp - AW F30 6MT 335i - EBII |
08-24-2015, 03:28 PM | #40 |
Rep 1,547
I'm running Pirelli Scorpion Ice & Snow on my staggered 469M's...been very impressed thus far (1 season on them). We don't see really deep snow here, but they provide sure footing in 6" of snow and slippery conditions.
08-25-2015, 05:15 PM | #41 | |
Rep 2,012
i've driven RWD cars for the past 10 years in chicago, always on snows in the winter. Didn't want to deal with a dedicated set, but it's suicidal to run around on summers in the winter.
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3 I think I have an M3 problem. |
08-25-2015, 05:17 PM | #42 | |
Rep 2,012
AWD diminishes the chances of you fishtailing, I'll agree with you there.
