      08-03-2022, 04:51 AM   #45
640ijims
Drives: 2018 X5M , 14%E2%80%99640i ver
2018 X5///M  [7.50]
2018 BMW  [0.00]
Just reread it, you are partially correct. I.E., cleaned hubs, checked for damage, rotated wheels & called it done.
      08-03-2022, 04:36 PM   #46
Chilled
Chilled's Avatar
Australia
366
Drives: F85 X5M
Well the bad news is that the ticking will be back in about 1k.
      08-03-2022, 04:57 PM   #47
640ijims
2018 X5///M  [7.50]
2018 BMW  [0.00]
You are probably right
      08-04-2022, 09:09 AM   #48
640ijims
2018 X5///M  [7.50]
2018 BMW  [0.00]
Have to fess up, old ASM advised this is not covered by Platinum( unobtainium) CPO wrap
      08-04-2022, 09:10 PM   #49
Housekeeping
Drives: 2013 BMW M5
Left tie rod cured mine, see prev comment pg 2. Been 2500 miles and quiet as a mouse.
      08-05-2022, 05:06 PM   #50
Chilled
Chilled's Avatar
Australia
366
Drives: F85 X5M
Hey was this before or after you had the front diff replaced?
      08-05-2022, 08:16 PM   #51
Housekeeping
Drives: 2013 BMW M5
Same time actually, literally same service
      08-23-2022, 05:46 AM   #52
f90.kar
@f90.kar
f90.kar's Avatar
Drives: F90 M5C
Originally Posted by bmwx5er View Post
Recently started hearing the ticking noise and came across this thread. Does anyone know if this would be an out of pocket repair if I'm out of warranty? Not sure if it's treated like a recall or something and is covered by the dealer
| M5C | Satin Black | Argon Brown | MAD Primary & Secondary Catless Downpipes | RC GTS Black |
      08-23-2022, 08:48 AM   #53
DallasDave X5M
DallasDave X5M's Avatar
83
Drives: MBW X5 M
More than likely it would be out of pocket, but I wouldn't take it to the Dealer to begin with. If you looks at most of the threads, the Dealer is just moving the front wheels to different lug bolt holes (ie., rotating the wheel/tire 72 degrees). Just try it yourself or take it to get the tires rotated. I bet that will fix it without the hassle of a trip to the Dealer.
2018 BMW X5 M in Donington Gray Metallic with Aragon Brown Merino interior, etc.
2016 Audi S8 Plus with Dynamic Package, APR Stage One tune, etc.
f90.kar94.50
      08-23-2022, 01:07 PM   #54
640ijims
2018 X5///M  [7.50]
2018 BMW  [0.00]
That is what they did to my X5///M a couple of weeks ago & it is still effective
f90.kar94.50
      08-23-2022, 02:19 PM   #55
640ijims
2018 X5///M  [7.50]
2018 BMW  [0.00]
Tip, go in for side to side rotation after you caulk rims and hub, tell them to rotate tires and move tires one lug down. Much cheaper than how I did it. Both tires should be up or down from mark on hub ( or edge of rotor)
      08-23-2022, 08:45 PM   #56
jab23
224
Drives: 2017 X5M
Still tick free a month later after the surface cleaning and rotation.
      01-30-2023, 04:35 PM   #57
DallasDave X5M
83
Drives: MBW X5 M
Just got the call from the Dealership. Yep, they hear the ticking and quoted me around $1,200 to repair it (even though the vehicle is still under CPO). The SA told me that there is a shim that will be installed between the wheel and hub assembly. I challenged the cost, as it seems REALLY high for something that will probably take them less than 1.5 hours. I told them to just leave it and take care of the other issues (oil change and noisy blower motor).
It is hard not to be really disappointed in BMW's overall service (with two local dealerships). We were also quoted $460 for cabin air filters, $485 for engine air filters and ~$1,100 for spark plugs. The SUV has around 45k miles and the plugs were done around 24k miles. "Well with the M vehicles we recommend....", blah, blah. Buddy, I will follow the maintenance book and plugs are not needed. BTW, I did all the filters myself about twelve months ago.
How the hell do they get away with charging so much for simple repairs like the air filters?!
      01-30-2023, 05:14 PM   #58
Chilled
Chilled's Avatar
Australia
366
Drives: F85 X5M
God, I would love to see the BS justification for those filters. Lol.
Btw, the shims are 31108053073 and you need 2x per wheel so 4 in total. Originally i think they only put the shim between the rotor and the wheel but now it looks like they also put it between the rotor and hub.
I think just the hub cleaning is prob the quickest and cheapest fix for this. Take wheel off, clean rust, install, no tick. Repeat as needed.
      01-30-2023, 06:25 PM   #59
DallasDave X5M
83
Drives: MBW X5 M
Thank you so much for posting that!
BTW, I pulled up the part number you listed and it directs me to another part number: 31108053074 (2018 X5M)
      01-30-2023, 06:29 PM   #60
DallasDave X5M
83
Drives: MBW X5 M
These damn things are $100 each, lol. I was thinking about getting wheel spacers...maybe I will do that instead!
      01-30-2023, 07:05 PM   #61
Chilled
Chilled's Avatar
Australia
366
Drives: F85 X5M
Those are for the rear, not sure on the difference between them and the fronts.
The fronts are 31108053073, and are around $60.
Oh BTW, be happy its only $60ish USD.
Here Down under they are $170ish AUD = $120USD.
      02-09-2023, 02:59 AM   #62
Chilled
Chilled's Avatar
Australia
366
Drives: F85 X5M
Lol, was having a chat with my dealer last week about the annual serive and was quoted $1,500AUD/$1100US(ish) for engine oil, engine air filters and rear diff (centre only) oil change.
I guess its not only lawyers that charge $1000p/h. Mechanics do too.
      01-23-2024, 10:43 PM   #63
I Luv BMW
Australia
91
Drives: BMW F86 X6M
Reviving an old thread. Had the ticking issue on left turns only. Could only hear it when in enclosed spaces liking parking lots, etc.
Had my indie undertake the 'spacer install' TSB from the earlier pages for the front wheels. Each spacer was $180 each! Did it as part of the front brake rotors replacement, so the total bill definitely hurt.
Anyway, it seems to have resolved the issue somewhat, but the ticking is still there, just the frequency/tempo of the ticking has been reduced.
      01-24-2024, 01:11 AM   #64
Chilled
Chilled's Avatar
Australia
366
Drives: F85 X5M
The clicks are a normal thing. Assuming its not your bearings/CV. Try this. Pop off the front wheels, clean the rust of the hub/rotor area that mates with the rim. Also clean the back of the wheel and re-install. This will stop the clicking.
I've had the clicks/ticking and this fixed it. There doesn't seem to be a real fix per-se. Some people have had the clicks return even with the spacers.
I also put coper anti-seize on the hub lip where the rim sits on.
      01-24-2024, 01:42 PM   #65
lemonslap
Drives: BMW X5M
Mine had this and I sorted it 10k miles ago. I removed the front wheels, wire brushed the disc mating surfaces then applied a thin coat of copperslip to the mating surfaces, torqued up the wheel bolts to 140Nm.
      01-24-2024, 06:45 PM   #66
jab23
224
Drives: 2017 X5M
Same. It works for like 6 months and I just do it again. So strange.
