      04-01-2015, 03:06 PM   #221
pdawg
Drives: 2015 X5 XDrive 35i
HEy R33 how much is that charge pipe and how hard is it to swap out?
      04-01-2015, 03:20 PM   #222
Here is the link to my site.
Polished finish
http://www.rgsportshop.com/index.php...product_id=683
Anodized Black finish
http://www.rgsportshop.com/index.php...product_id=207
It is very easy to swap. About 30-45 minutes of work.
Here is the DIY thread.
http://f15.bimmerpost.com/forums/sho....php?t=1096480
      04-01-2015, 03:41 PM   #223
pdawg
Thanks bud.
      04-21-2015, 11:28 PM   #224
updated the post with the video of the muffler with catless downpipe.
First batch is in production currently.
      04-22-2015, 08:44 AM   #225
Alan l.
Alan l.'s Avatar
5453
Ben,
The gain of 36whp and 29wtq is huge for just swapping to a catless downpipe. Did you ru on a higher boost map as well to achieve this? maybe things have changed since I was modding my N55 but i don't recall a catless dp giving that much of a gain. Also how noticeable is the smell? Is there anything else on the market now that would suppress the catless CEL besides the JB4?
      04-22-2015, 08:59 AM   #226
Originally Posted by Alan l.
Ben,
I didn't change anything but using gas from Chevron instead of Costo in between those 2 runs.
I was surprised too when I saw the gain, but ER said that's about right.
We did 3-4 run on the downpipe part, and every each run, I gain a little more.
The smell is better than the N20/N26 as far I can tell you, because I had catless also on my F10 528 before.
On the N55 seems a little better.
Other than JB4, I can't think off anything that can supress the CEL currently.
      05-12-2015, 02:24 AM   #227
pdawg
thats a pretty bonkers gain for the catless downpipe. So the engine light would be on constantly?
      05-12-2015, 08:54 AM   #228
Alan l.
Alan l.'s Avatar
5453
Not for him since he's running the JB4 which suppresses the no cat CEL.
With a kid this isn't something i could get. The exhaust tips is right at the face level of my daughter and she always in the back of the X5.
      05-12-2015, 09:13 AM   #229
They will outgrow the tip height.
I have 2 kids also.
You can always run the hi-flow cat.
As of today, I will have 5 unit Hi-flow cat in stock and 2 unit catless.
I will open up a thread for it once I got in the office.
      05-18-2015, 06:00 PM   #230
Hi-Flow catted downpipe and catless downpipe are in stock now. Ready to ship.
      06-02-2015, 01:38 PM   #231
Alan l.
Alan l.'s Avatar
5453
Hey Ben,
How much tire pressure do you normally run in your 22" setup? Just curious...
      06-02-2015, 01:41 PM   #232
Originally Posted by Alan l. View Post
Hey Ben,
I bump 2-3psi from the stock.
So, I am currently running 39psi front and 42psi rear.
      06-02-2015, 02:03 PM   #233
Alan l.
Alan l.'s Avatar
5453
Thanks Ben.
I am going to do the same. My wheels came with 37psi all around so i need to bump up the pressure some more. No wonder they road so much better than stock even on 22's lol
Alan
      06-02-2015, 02:08 PM   #234
Thanks Ben.
Alan
Overall, Non-RFT rides better than stock RFT.
      06-02-2015, 02:09 PM   #235
Alan l.
Alan l.'s Avatar
5453
I'm a believer now. I was totally shocked how much better my 22" rode compared to the stock 20"s RFTs. Even my wife noticed the car being smoother
      06-02-2015, 02:16 PM   #236
Blackhawks
Blackhawks's Avatar
Drives: 2015 X5 x35i
Third row (no spare), non-run flats and Chicago potholes = playing with fire. I'll have a tough decision to make soon!
      06-02-2015, 02:32 PM   #237
Kzang
Kzang's Avatar
3240
Drives: 2015 X5 35i Msport SG
I keep telling people this and no one believes me....
      06-07-2015, 02:50 PM   #238
pdawg
Yes it's true, I went from 20s on RFTs to 22s on pirelli non-RFTs and it's better.
      11-06-2015, 11:10 PM   #239
Don Juan
Don Juan's Avatar
Drives: 2020 X7 40i, 2020 I3s Bev
Originally Posted by F15X5 View Post
R33... car looks great!!
Ben,
You mentioned you were able to successfully install the JB4 stage2. But in burgertunning website it is not compatible with the F15. So how did you do it? Specially the red wire, Yellow and blue that gets connected to the battery and tapped into other dme wires.
The reason im asking is because i have a F10 with jb4 stage2 and waiting for my new F15 to be build. Any info will be greatly appreciated.
Ps: i also read that theres is no JB4 stage1 , it is called N55 stage1. Go figure.
2023 I4 40 Msport White/red interior 19"Rims
2023 Ix 50 MSport Hraphite Gray.Oyster interios 22" Rims
Retired
2020 X7 MSport 40i
2020 I3s Bev
      11-06-2015, 11:39 PM   #240
Ben,
BMS kept on changing the name when I did this whole writing. They don't list X5/X6 since it is not in their market, so they never tested it themselves.
I tested it and proven it, but then they don't appreciate what I've done.
      11-27-2015, 05:59 PM   #241
Don Juan
Don Juan's Avatar
Hi Ben,
Well Finalyl have my F15 White Msport and enjoying it. I have installed the F10 BMW intake (fits perfectly) but cant figure out the JB4 connections. My F10 had the pneumatic wastegate and uses a blue wire. The new F15 has an EWG (electronic wategate). Reading some of the BMS instructions, it seems I only need to connect 3 of the 4 connectors but also I read that an EWG wire is needed.
Can you shed some light (and pic if any) of your installation? Specially where is the EWG connector and where did you connected to the EMC.
thanks in advance
Retired
2020 X7 MSport 40i
2020 I3s Bev
      11-27-2015, 06:30 PM   #242
Hi Ben,
thanks in advance
Have you tried contact BMS directly?
I don't want to tell you something and they will ended up telling you that you are SOL for asking me for support.
It is not that I don't want to help you, I just don't want to get you in trouble.
