      10-15-2018, 10:48 AM   #23
fbuzila
Drives: 2023 BMW XM
Originally Posted by Feelin Nauti View Post
My weekend project.. I installed 2 JL Audio 12w1v3 subs in a sealed enclosure
(did not have air space for ported) in the trunk area in storage area. I still need to do my grill with perforated metal flush with the floor to cover the subs to keep them safe.
I also installed a JL 600/1 sub amp and a LOC/EQ. I had this left over from previous car. I may add amps in the future for the mids and highs. I installed the remote sub level control in the panel under the CD player.
it looks great!
how did you mount the amp on that location? some custom brackets ?
      10-15-2018, 11:21 AM   #24
Feelin Nauti
Feelin Nauti
Feelin Nauti's Avatar
Drives: 2014 BMW 650i M Sport Frozen
Originally Posted by fbuzila View Post
it looks great!
Yes I made some brackets out of heavy gauge sheet metal and fasten them to stock locations.
2014 650i M Sport Frozen White Matte Metallic
2015 X5 M Sport 50i Mineral White
2012 650I Conv Sapphire Black
2013 Harley Softail, Road King, Road Glide show bikes
2010 40' Express Cruisers Yacht
fbuzila367.00
      10-15-2018, 08:23 PM   #25
duercos
duercos's Avatar
201
Drives: F36>F16>G30
Cant wait to install my 2x 10W3s in ported enclosures in trunk area. They should fit just right. Didn't wanna go crazy over building a custom box)
JWK170200.00
      10-19-2018, 11:20 AM   #26
rptam1
Drives: x5 35d
Here is my install I got completed yesterday. Focal 10" sub, JL Audio mono amp, Audio Control LC2i and remote bass knob. Bryon at Seismic Autosound in Concord, CA did the install. You can tell from his work he is recognized as one of the top 50 car audio installers in the U.S.
      10-19-2018, 12:06 PM   #27
fbuzila
Drives: 2023 BMW XM
finished mine too; bavsound speakers upgrade and 12" sub
      10-19-2018, 12:26 PM   #28
rptam1
Drives: x5 35d
What are your thoughts on the Bav Sounds over the HK? Worth the $ and time to replace? Thanks
      10-19-2018, 01:16 PM   #29
fbuzila
Drives: 2023 BMW XM
You can tell the bavsound speakers are more clear, not a huge difference, but noticeable. Also keep in mind these are new speakers and need time to "warm up" and they only get better in time. But also I'm not an audiophile type person.
The sub+amp in the trunk makes the bigger difference in my opinion.
rptam111.50
      10-20-2018, 06:15 PM   #30
Jrunr
Germany
188
Drives: 2019 BMW X5 M40i - G05
What is the best bang for the buck audio upgrade here? Just add a slim 10" sub the in spare tire well, and you are good?
      10-20-2018, 08:12 PM   #31
rptam1
Drives: x5 35d
If you don't have the third row, JL makes a 10" and 12" enclosure that fits that space well. Power it with a mono amp, Audio Control LC2i and remote bass adjustment knob and you will be good to go. The factory amp and HK speakers will power the highs/mids with no problem while your addition powers the low end.
To give a good comparison, it is like running a home theatre set up with a powered sub vs. not running one at all; night and day difference.
      10-20-2018, 08:47 PM   #32
bmwx1sq
bmwx1sq's Avatar
Drives: BMW X1 35i
Originally Posted by JWK170 View Post
Just curious if anyone has ran a separate amp to the front underseat woofers? I was thinking of doing the BavSound underseat replacements with an additional amp powering those. I have the spare tire option so very limited room in the trunk underhatch.
I see there is a Stealth Box for the E70, but not sure it would fit the F15.
http://www.jlaudio.com/product/54216...29_%2707-%2713
I could make you a single box for that back corner cubby. You would need to tell me what speaker you are going to want to use.
As for a separate amp for the under the seat subs. It would not make that big of a different unless you have different speakers to handle the increased power.
      10-20-2018, 10:20 PM   #33
duercos
duercos's Avatar
201
Drives: F36>F16>G30
Anybody knows from their experience if the stock battery and alternator will work well with a separate amp of 1100W on top of HK?
      10-20-2018, 10:35 PM   #34
Twin Peaks
N00B
Twin Peaks's Avatar
Drives: X5 50i (F15)
As for a separate amp for the under the seat subs. It would make that big of a different unless you have different speakers to handle the increased power.
what about a box in the cubby for a 12 inch mtx thunder 9500?
The owls are not what they seem!
      10-21-2018, 05:53 AM   #35
bmwx1sq
bmwx1sq's Avatar
Drives: BMW X1 35i
Maybe it depends on the depth of that sub. If remember correctly that is a pretty deep sub.
      10-21-2018, 06:04 AM   #36
bmwx1sq
bmwx1sq's Avatar
Drives: BMW X1 35i
So I did some research it's going to be close but it's do able.
      10-21-2018, 06:05 AM   #37
bmwx1sq
bmwx1sq's Avatar
Drives: BMW X1 35i
Yes, I have a 2k and (2) 175x4 amps on a stock battery.
duercos201.00
      10-21-2018, 06:11 AM   #38
Jrunr
Germany
188
Question
Do you have to do anything to the storage cover if you do that? Or are you just firing a woofer directly into it?
      10-21-2018, 10:54 AM   #39
bmwx1sq
bmwx1sq's Avatar
Drives: BMW X1 35i
You can leave it covered. There is no need to cut a hole innit.
      10-21-2018, 02:10 PM   #40
Twin Peaks
N00B
Twin Peaks's Avatar
Did you get to doing yours yet, I'm definitely interested? The reason I am considering this is I have 3rd row seats and suspension upgrades so space is super limitrd.
bmwx1sq145.00
      10-21-2018, 03:28 PM   #41
bmwx1sq
bmwx1sq's Avatar
Drives: BMW X1 35i
I plan on it this winter. My daughter start preschool, which I ll have more time to do it now. Also the hurricane pushed everything back. I have an Fi audio q Neo 12" and it's 11" deep and it's super close. If I had a shallower sub it would fit fine. I ll do some more calculations with your sub and draw up a design. I ll message you later tonight.
      10-22-2018, 10:47 PM   #42
rptam1
Drives: x5 35d
I completely removed both plastic pieces in the rear giving you as much space as possible. They are sitting in my garage so when I sell it one day, it can all be returned to stock.
      10-23-2018, 09:04 AM   #43
Jrunr
Germany
188
Are the Bavsound speakers the only replacements that work for the X5? What about upgrading the dash speaker? Does that help at all?
      10-23-2018, 09:06 AM   #44
fbuzila
Drives: 2023 BMW XM
I'm pretty sure there are other options but I didn't look into too much.
