      12-29-2021, 03:21 PM   #23
CaliX6M
Drives: BMW X6 M
Originally Posted by Chilled View Post
In Cali with a X6M, are you sure you had the blinker option fitted?
Such an informative and helpful reply 😜
destroy26165.00
      01-19-2023, 10:18 AM   #24
Franktea1$
Franktea1$'s Avatar
Drives: BMW e39 540 sport & BMW X5M
Originally Posted by SRT14PimPin07 View Post
Hello, having a little problem was wondering if anyone would have any advice. When I turn my right blinker on, the turn signal lights outside the car work but on the dash it usually doesn't light up "blink". It sometimes stutters but usually doesn't light up at all. It makes the noise but no light.
The left side blinker works fine. If I turn on the hazards, the lights outside work perfectly but inside only the left side works "blinks".
Does anyone know if I can get just the bulb inside replaced? Or am I supposed to change the whole unit in the cluster gauge? Basically, if I can get away with replacing just a bulb I'm going to fix it. If I have to change the whole unit which I know will be expensive, I'm going to leave it alone.
Thanks
I have the same issue, I will probably take the cluster out in the spring time and see what can be done. If someone has a repair solution would love to here.
      01-19-2023, 10:21 AM   #25
Franktea1$
Franktea1$'s Avatar
Originally Posted by mcbridX5 View Post
Hey! Did you ever figure out how to fix this, or should I bring it to the dealership because I have the same exact issue?
Hi am going to address it in a few months, i called the dealer a new cluster is $2600 just for the part. I would imaging its a failed LED light, thats what sucks about these LED lights, tech behind them needs to improve.
Thanks,
Frank
      04-19-2023, 10:03 AM   #26
Franktea1$
Franktea1$'s Avatar
Wondering if anyone has resolved this with a DIY?
      04-19-2023, 11:25 AM   #27
RED_Y_
Drives: 2014 X5 3.5d
Yes:
https://f15.bimmerpost.com/forums/sh....php?t=1988681
      04-19-2023, 11:52 AM   #28
Franktea1$
Franktea1$'s Avatar
Originally Posted by RED_Y_ View Post
Thank you!!!!!!!!!!!!!!!!!!!!!!!
      02-08-2024, 04:32 AM   #29
x5toledo
x5toledo
Drives: BMW I01
My F15 with 6WA also had the right indicator arrow fail. Having looked at the repair process and got a few quotes it went off for repair (UK car). Totaltronics in Dorset fixed it with an OEM LED for a really competitive price.
