      08-15-2022, 03:39 PM   #1
Brah02
Drives: '23 BMW X5 45e, '16 X5 40e
Replacing F15 Parking Brake Actuator
I keep getting the error "parking brake reduced" and was told it could be the parking brake actuator. I ordered one and will be taking this job on tonight, I had a question though. Does anyone know if i'll need to replace the cables or can I just replace the control unit? Replacing the cables will require removing the wheels & rotors etc so will be a more labor intensive job vs just replacing the control unit.
      08-16-2022, 09:31 PM   #2
scotty339
Drives: 2015 BMW X5 x35i M-Sport
Depends on if you can get it into workshop mode and release the cables. This should help.
2015 BMW X5 x35i | M-Sport | Alpine White
      09-02-2022, 09:41 PM   #3
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Is it just me or are the images completely non-legible
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      09-03-2022, 03:50 AM   #4
CatalinP
Drives: BMW X5 F15 2014 3.0xd
Click on the images...
      05-03-2023, 04:13 AM   #5
Bulletx5
Drives: BMW X5 40e
I replaced pads, discs, shoes, caliper bolts, cleaned everything down, regreased and refit including the actuator and cables. I think youre better off taking everything apart, if the tension sensor was to blame, chances are the cables are damaged. Better to be safe than sorry!
      08-06-2023, 04:53 PM   #6
patrocle
patrocle's Avatar
Drives: 2017 Bmw X5 F15
So did you get a new original or aftermarket? did you had to program to the car? or worked out of the box? Have 2017 x5 f15 and need to replace my p-brake and thinking of going with aftermarket new one, Thanks
2017 Bmw X5 F15
      08-07-2023, 01:58 AM   #7
Bulletx5
Drives: BMW X5 40e
I bought one from a crashed x5 for a fraction of the cost. €300. Included Bowden cables and everything.
You don’t need to code it to the car but you will need to calibrate the tension on the parking brake shoes initially. I did this as a precaution but You could probably get away with no doing the calibration to be honest.
BMW recommends 7 turns to the right of the brake shoe tensioner wheel on each side when the shoes are new. For the small cost, replace everything on the back and do the 7 turns so you won’t have to calibrate it. If you decide to give it a go let me know. Happy to answer any questions if it helps 👍
      08-08-2023, 11:33 AM   #8
BeachsideF30
Drives: E90--> E92-->F30
I’m dealing with this too, it goes on and off every other day now
      08-14-2023, 07:06 PM   #9
patrocle
patrocle's Avatar
Thanks for that info.
Well i got a new after market one as i don't want to put a used one and a new oem is like $1300. Should come this week, and also order rotor pads and sensor to replace those is are all most done.
Now, regarding the calibrate the p-brake shoe tension, is that done with a obd scanner? As i am not going to replace the p-brake shoes as i checked the shoes few weeks ago and they where fine.
2017 Bmw X5 F15
      08-14-2023, 07:11 PM   #10
patrocle
patrocle's Avatar
I guess your amber light comes on and off? U done anything yet?
2017 Bmw X5 F15
      08-16-2023, 06:49 AM   #11
BeachsideF30
Yea it comes on and off every other day I’d say. I’ll let the dealer deal with it at its next oil in 2k, it’s still under CPO. I’ll report back with there findings
      08-18-2023, 08:36 PM   #12
patrocle
patrocle's Avatar
Now, if the shoes are the same and not changed then the "calibrate the tension" needs to be done or just install the actuator with cable and you good to go? My pads are in good shape from what i saw.
2017 Bmw X5 F15
      08-18-2023, 08:37 PM   #13
patrocle
patrocle's Avatar
Thanks!.
2017 Bmw X5 F15
      12-15-2023, 05:42 AM   #14
atopa2002
atopa2002's Avatar
Drives: Z3M, 2013 e92 M3, F15 X5
Thanks!.
Did the AFTERMARKET Parking Brake Actuator Control Module work?
Having same issue and want to go the aftermarket route
Thanks
      12-15-2023, 06:48 AM   #15
patrocle
patrocle's Avatar
Thanks
Yes, it did work for me.
2017 Bmw X5 F15
      12-15-2023, 07:01 AM   #16
patrocle
patrocle's Avatar
This is the one i got:
https://www.ebay.com/itm/185767157161
but you have to make sure it fits your year.
Also the one i got it was not adjusted right, per the 3 turn rule.
My brake pads i left the old ones. Some say to put brand new.
If the actuator cables are not connected to the brake rotors assy do not press the p-brake button in the cab as it will mess up the adjustments. All must be connected.
After install , and before plug in the connector, clear the codes. Then connect, test, drive.
When i did it i took the rotors down, and when the cable need's to go into the hole behind the rotor there is a way to take the cable lock mechanism off it will be easier to lock the cable in. Right side is easier to do, but the left is little harder to lock it in.
Good luck.
2017 Bmw X5 F15
atopa2002202.50
      02-06-2024, 04:37 AM   #17
BMWTANGO
United Kingdom
Drives: bmw x5
EMF CABLE
Does anyone know if the parking actuator connects to its own wiring loom straight back to the handbrake switch, or is it connected to the main wiring loom? can identify the plugs and cables on realoem.
thanks in advance.
