07-22-2015, 06:53 PM | #89 |
Rep 578
That's right Akhter. I have Hifi (Standard) no HK. My big question here is: How can I install the tweeter? there is no bracket/housing... just an empty space.
07-22-2015, 06:54 PM | #90 | |
Rep 1,690
Drives: 911 992 C2S
Current 2021 Porsche 911 992 C2S
Sold 2021 X7/2018 X5/2014 X5 Sold 2013 520i/2010 325i Sold E90 335i M Sport Alpine White|Tokyo Sold E36 328i Jet Black|NYC |
07-22-2015, 10:09 PM | #91 |
Rep 1,690
Drives: 911 992 C2S
there is also some stuff to worry about on the center. the center signal my have already be crossed over from amp (ie. not full range) so you cannot use the single mid signal and split. you also cannot use the amp L or R signals. so you need a signal summing device out of the full range L+R. you also may need to use something like JL audio cleansweep to flatten the signals (if they are not flat on base hifi). i had to do this on my e90 because the crappy hifi speakers were so bad that bmw had to eq them from head unit.
if i were u what i would do is leave the center alone or replace with a coax 4 inch instead of adding a tweeter as it is too complicated. upgrade teh doors and add a simple 4ch amp (like jl audio). if u want better, add a cleansweep to flatten the signal. if u want more then upgrade the center to coax and use a signal summing and use the 3rd channel of the 4ch amp.
07-23-2015, 11:47 PM | #93 | |
Rep 1,690
Drives: 911 992 C2S
http://www.focal.com/en/dedicated-dr...6-ifbmw-c.html
08-17-2015, 09:47 PM | #94 |
Rep 578
One question for the speaker genius here:
I have the standar hifi ...if I buy the top hifi or high-end (B&O) speakers, are they p&p? I know I "must" add the amp also, but I won't do that...so, maybe upgrading only those speakers do the improvement enough? Ps: I'd like to replace center console 4" speaker and rear doors speakers...while My focal speakers for front doors are still in customs since July 24 here Last edited by LatinBimmer; 08-18-2015 at 08:45 AM.. |
08-18-2015, 11:13 AM | #95 | |
Rep 709
Most speakers are technically plug and play... It's the bracket that BMW uses that makes it difficult. All speakers have terminals that wire goes into... But mounting the speakers is what BMW has made difficult. |
08-18-2015, 11:37 AM | #96 | |
Rep 578
08-18-2015, 11:42 AM | #98 |
Rep 578
08-18-2015, 11:42 AM | #99 |
Rep 709
08-18-2015, 11:46 AM | #100 |
Rep 578
08-18-2015, 11:48 AM | #101 |
Rep 709
No, but I'm going to. I will move the 100KRS components to the rear doors and get the KRX2s for the fronts... But that will require a modification to the front door panel as they have a 6.5" mid. It will also require an amp upgrade and processor. I'm probably going to wait until the spring because it doesn't sound bad the way it is... I just want a little more.
08-18-2015, 11:56 AM | #102 | |
Rep 578
08-18-2015, 12:00 PM | #103 | ||
Rep 709
08-18-2015, 12:05 PM | #104 | |
Rep 578
09-08-2015, 07:44 AM | #105 |
Rep 578
Hello my friends! Today is the day! I'll finally upgrade my standard speakers with Focal 100KRS and tweeters. They came with 2 crossovers and I am not educated about how it works. I'm also curious about the crossover settings. is there a "recommended" settings for the F15?
09-08-2015, 11:52 AM | #106 | |
Rep 709
09-09-2015, 08:25 AM | #107 | |
620
Rep 2,013
It's the only amp/DSP which is 100% plug and play and installation in an F15 takes 15 minutes. Don't take my words for granted and check what F30 guys say: http://f30.bimmerpost.com/forums/sho....php?t=1133999 We are running a special on this kit until tomorrow (check the banner below). If there is anyone willing to review it feel free to email us for more info. |
09-09-2015, 08:50 AM | #108 | |
Rep 578
-F15 with HiFi System Then upgraded to: -Center Console HK Tweeter and MidRange Speakers -Front Doors Focal 100KRS Midrange and tweeters -Rear Doors OEM Hifi Midrange Speakers My questions: -Is this Amp better/worse than Logic 7 Pro (HK Amp)? -Will your software be able to equalize my setup? -Every time I want to change my EQ settings, I understand I have to code using OBD and laptop? -If you code the car in order to show L7 in iDrive, will this work in otder to equalize your amp? This is just an idea... Thanks! |
09-09-2015, 09:41 PM | #109 |
Rep 578
So, here is my setup!
Front doors: Focal 100KRS Center Console: HK No amp for now, but it sounds much better than my standard speakers! Last edited by LatinBimmer; 09-10-2015 at 06:21 AM.. |
