      08-21-2016, 08:20 PM   #177
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Originally Posted by TheUltimateDrivingManiac View Post
Change the last figure of the vehicle type from 3 to 1 in FA (no need to save it in the car) and FDL code LHM or FLEs to avoid that boring Step 2
Good luck!
That makes no sense. Why are you modifying an FA to FDL code?
      08-21-2016, 11:16 PM   #178
Freude am Fahren.
Drives: F15 X5 xDrive35i
My bad. Just code it, not FDL way.
Edited my previous message, thanks.
Freude am Fahren.
      09-23-2016, 02:15 PM   #179
mntbiker
mntbiker's Avatar
Drives: F15 X5
Change the last figure of the vehicle type from 3 to 1 in FA (no need to save it in the car) and code LHM or FLEs to avoid that boring Step 2
Good luck!
Does this actually work? Allows skipping step 2?
      09-23-2016, 02:53 PM   #180
alphaod
alphaod's Avatar
Originally Posted by compsyndrome View Post
I've looking for an answer to this question:
Can you code HBA on Xenon equipped F15? No anti-dazzle features but rather auto off/on of the high beams?
Yes you can, but you need to camera for it work.
BDC_BODY 3068 FLA_AKTIVIERUNG
Set to: LDS in A or 2
(From cheat sheet courtesy of RGSport)
      09-24-2016, 07:38 PM   #181
joder
Drives: 535i
dmnc02 and PlayTookies
Thank you for all of your work on this.
Some interesting observations on a '17 x5
When FDL coding FLE there is no F015Wert for the following:
H_plus4_Idx (There is an F015Wert_SA552_ECE_RL option)
PANICMODE_Idx
SIDEMRKLGT_Idx
Also I noticed that HBBLINK_Idx had F030Wert as a default
Furthermore when going through the list of the 79 additional functions none of them contain anything regarding F015. They are either F030Wert_SA552_US, F020Wert, or F030Wert.
Perhaps I have done something wrong or they have changed the functions around to prevent this?
Any help is certainly appreciated.
Edit: It appears on the Lmm values that I can still get the respective Werte values on the PDF guide, however, the labels do not contain F015 but instead F020 and F030.
Is it safe to assume that the Werte HEX values still do the same thing?
      09-24-2016, 08:07 PM   #182
mntbiker
mntbiker's Avatar
Drives: F15 X5
PANICMODE_Idx
SIDEMRKLGT_Idx
Hey, I just re-coded this today after my dealer reset everything. I have a '16 X5 (July 2016 build date) with the latest coding psdzdata (59.4).
I am seeing the same exact thing as you are! I just coded everything to the werte values directly. I used the values in the v2 PDF from January 8, 2016. Many of the named values were different than the ones in that PDF, as you are seeing.
I just got back from a test drive and everything is working perfectly. It's so great. I also have this coded in my M3 and had it on the X5 previously, so I know what it looks like when it's working.
Check your PMs
      09-24-2016, 08:13 PM   #183
joder
Drives: 535i
Check your PMs
Thank you for confirming. I haven't done this in a few years since on my F10. Not even sure it is doing it completely right, however, it looks right to me on the F10. Just removed 5AP and 8S4 on the F10. It looks like a lot of head way has been made on this topic. Not sure if this applies to the F10 as well?
      09-25-2016, 12:25 AM   #184
Almaretto
Almaretto's Avatar
2374
The wertes are the important values. For the F10, it has unique LED's and removing decoding option codes still results in glaring other drivers.
      09-27-2016, 10:31 AM   #185
MrTookies
MrTookies's Avatar
Drives: 2011 E90 328i, 2015 F15 35D
So, are you all clear on this now, or do you still have some issues?
      10-03-2016, 04:59 AM   #186
vincesfo
Drives: 545i
Thank you for work on this topic.
I seem to have an issue on my 16 xDrive40e (Build Date July 2016)
I followed all the steps on the PDF but after a test drive, GFHB/Anti-Dazzle is not working.
After reviewing the coding and trying several times to recode both FLE, the following functions would not "stay" on the F015Wert Value but display "UNKNOWN":
- Stadt_V_Idx with the following Werte 12, 01, 01, 01, 02, 03, 01, 01, 05, 01
- H_plus4_Idx (03, 01, 01, 01, 02, 03, 01, 01, 01, 01)
- Blendfreies_Fernlicht_Idx (0F, 06, 01, 01, 06, 06, 01, 01, 01, 01)
Everything else that was listed on the PDF was changed to F015Werte.
Any help/suggestions would be appreciated.
Thanks - Vincent
      10-03-2016, 06:58 PM   #187
Almaretto
Almaretto's Avatar
2374
Thanks - Vincent
I am not sure how you got those werte's for Standt_V_Idx. But, the werte values are what is important. If you do not find the expected drop-down menu value or it results in a different than expected werte value, change as needed. Generally, you only change werte values or drop-down menus.
If you PM me your VO coded FLE CAFD (without any FDL changes), I can quickly apply the correct werte values.
      10-03-2016, 08:39 PM   #188
HZX540e
HZX540e's Avatar
Drives: 2021 X5MC
I'm new to the BMW world, what camera are you talking about? Could you send me a picture to see if I have it on my X540e?
      10-04-2016, 12:29 AM   #189
alphaod
alphaod's Avatar
I think if you need to have the Driver Assistance Plus package that gives you speed limit info and lane departure warning to have the camera. On the outside the camera says "ConnectedDrive"
The camera looks like this:
http://www.realoem.com/bmw/enUS/show...diagId=66_0314
      10-04-2016, 10:21 AM   #190
HZX540e
HZX540e's Avatar
Drives: 2021 X5MC
What about just the anti dazzle, do you need the camera for that?
      10-04-2016, 05:46 PM   #191
Almaretto
Almaretto's Avatar
2374
You do not need camera for variable light distribution. You do need for Anti-Dazzle or No-Glare High Beams.
      10-04-2016, 05:54 PM   #192
iconoclast
Self-Deprecating Narcissist
iconoclast's Avatar
7266
Originally Posted by iconoclast View Post
exact scenario i have... coding was done properly but this is the end result. as you stated above i can clearly see one of the diodes are not illuminated on the driver's side but once i go into reverse or put the fogs on or manually engage the headlights the lighting returns to the traditional NAR double hump beam pattern. very odd behavior.
coded the headlights again and now all the diodes are illuminated and the anti-dazzle appears to functioning as designed but i wanted to check with others here if this beam pattern looks correct:
      10-06-2016, 12:13 AM   #193
alphaod
alphaod's Avatar
Mine does not have the left hump, and part of the headlight is not illuminated. It only lights up with high beams.
      10-06-2016, 10:10 AM   #194
iconoclast
iconoclast's Avatar
7266
that is how it was before... now after second round of coding the driver's side came back.
      10-11-2016, 02:17 AM   #195
vincesfo
Drives: 545i
Duplicate post on Bimmerfest - hopefully someone encountered a similar issue and can chime in...
Hello,
First off, a big thanks to Almaretto who has helped me narrow down my issue to FLE [44] - Passenger side on a 2016 F015 40e - Built July 2016.
I followed every step of the January 8 guide "How to Enable the GFHB Functionality... on US F15..." - version 2 (appendix 2), yet GFHB is still not working.
Almaretto confirmed that I correctly VO-coded BDC_BODY, KAFAS2 and both FLEs.
The issue seem to be with FLE [44] - Passenger side which doesn't seem to "accept" the FDL coding (whether thru a CAD file that Almaretto helped configure OR manually editing all 70+ parameters). Each time, several functions read back as "Unknown" instead of F015Wert and slightly different werte value. I do not get ANY error messages from E-Sys after coding.
Here is comparison between FLE [43] (which codes without any issues) and FLE [44]:
Schlechtwetter_C1_Idx Left: F010Wert = 00 01 01 01 02 03 01 01 01 01 Right: UNKNOWN = 03 01 01 01 02 03 01 01 01 01
Schlechtwetter_C1_Idx Left: F015Wert = 00 01 01 01 02 03 01 01 01 01 Right: UNKNOWN = 03 01 01 01 02 03 01 01 01 01
Schlechtwetter_C2_Idx Left: F010Wert = 00 01 01 01 02 03 01 01 01 01 Right: UNKNOWN = 03 01 01 01 02 03 01 01 01 01
Schlechtwetter_C2_Idx Left: F015Wert = 00 01 01 01 02 03 01 01 01 01 Right: UNKNOWN = 03 01 01 01 02 03 01 01 01 01
Stadt_V_Idx Left: F015Wert = 04 01 01 01 02 03 01 01 05 01 Right: UNKNOWN = 12 01 01 01 02 03 01 01 05 01
H_8_Autobahn_E3_Idx Left: F015Wert = 03 01 01 01 02 03 01 01 01 01 Right: UNKNOWN = 03 01 01 01 03 03 01 01 01 01
H_6_Autobahn_E2_Idx Left: F015Wert = 03 01 01 01 02 03 01 01 01 01 Right: UNKNOWN = 03 01 01 01 03 03 01 01 01 01
H_5_Autobahn_E1_Idx Left: F015Wert = 03 01 01 01 02 03 01 01 01 01 Right: UNKNOWN = 03 01 01 01 03 03 01 01 01 01
H_4_Autobahn_E_Idx Left: F015Wert = 03 01 01 01 02 03 01 01 01 01 Right: UNKNOWN = 03 01 01 01 03 03 01 01 01 01
H_plus4_Idx Left: F010Wert_SA552_US = 04 01 01 01 02 03 01 01 01 01 Right: UNKNOWN = 03 01 01 01 02 03 01 01 01 01
H_plus4_Idx Left: F015Wert = 04 01 01 01 02 03 01 01 01 01 Right: UNKNOWN = 03 01 01 01 02 03 01 01 01 01
Blendfreies_Fernlicht_Idx Left: F015Wert = 01 06 01 01 06 06 01 01 01 01 Right: UNKNOWN = 0F 06 01 01 06 06 01 01 01 01
Both FLE use the same CAF file, CAFD_000024C3_008_010_000.ncd. They show zero differences when "freshly" VO-coded using the NCD/CAFD comparison tool, yet one accepts the changes (FLE [43] - Driver) without any issues for GFHB but the other (FLE [44] - Passenger) doesn't.
Any help is appreciated!
Thank you.
      11-28-2016, 08:21 PM   #196
MochiEater
Drives: 2017 X5 40e
Anyone solve this problem? I have exactly the same issue. FLE(44) will not accept coding changes. But GFHB seems to be working (either that or I'm blinding everybody but they are too polite to complain).
      02-04-2017, 10:31 PM   #197
JM71
JM71's Avatar
21
Drives: P911
Alright, I am stumped. Followed all of the instructions in the pdf (latest version). I changed the Werte values no problem but not sure how to change the US VO Value to ECE VO Value. Link to screen grab (couldn't figure out how to attach a picture):
https://www.dropbox.com/s/k82sg8lqfq...GFHB.jpeg?dl=0
To clarify, I believe what I did was simply edit the Werte values directly. Perhaps that was wrong.
      02-05-2017, 12:54 AM   #198
Almaretto
Almaretto's Avatar
2374
I am stumped at what you believe you cannot achieve.
Werte values are all that matters.
