03-14-2022, 12:37 PM | #1 |
Rep 15
BMW. 5 f15 50i. Drivetrain malfunction problem
It's been a while since bmw can't fix my car. When accelerating the car starts to shake and drivetrain malfunction pops up on the dashboard. I changed all spark plugs and coils I fixed the transfercase. Changed 2 injectors. Everything was done at bmw. When I picked up the car after changing all that, the problem was not solved. Now they told me that there's another problem "Diagnostic - Check Engine Light:
$1.64 vehcile is setting charge pressure to low faults. found waste gate pressure convertors to not hold vacuum. needs bank 1 and 2 wastegate epdw". I have no idea what is this. Please can anyone tell me what is this and any suggestions what I can do? I told them are you sure that this is the problem, because last time they told me that the car is fixed but it wasn't. And they said that it's the only problem that we can see now. I believe that the BMW can't fix their car, and they just keep charging money for nothing(since until now the problem isn't fixed). |
03-14-2022, 05:38 PM | #3 |
Rep 648
Ask BMW if they did a smoke test.
If not, have them do one. If you have any air leaks around intake by turbos etc, it will show. Also, if you have over 100k miles, I recommend testing all fuel injectors, make sure none of them has any issues with leaking gas, when they are supposed to be closed. Can cause catastrophic issues. FYI, BMW is way overpriced for the injectors. It's actually quite ridiculous what they charge for them. A slap in the face kind of price! |
03-14-2022, 05:48 PM | #4 | |
Rep 15
03-14-2022, 05:49 PM | #5 |
Rep 15
03-14-2022, 05:50 PM | #6 | |
Rep 15
