      02-22-2024, 10:35 AM   #1
kdad
Drives: 2015 428i conv
Air suspension pump operation
MY 2018 F15 with 70k miles
The air pump comes on for about a second every morning I start driving
Wanted to check if this is within reason to replenish air. Or do I have leaks which is possible at this age.
Thanks
      02-23-2024, 12:25 AM   #2
tlow98
Drives: 2009 E91, 2014 F15 x35i
That sounds normal and I have fresh bags. You’ll know the bags are wearing out when the car is sitting flat with the wheels jammed into the wheel wells.
      02-24-2024, 09:47 AM   #3
kdad
That has happened a couple times in the past six months or so. Am I better off changing the bags preemptively?
      02-24-2024, 09:49 AM   #4
CatalinP
Drives: BMW X5 F15 2014 3.0xd
Only if you don't want to wait until you have to replace the air compressor as well.
      02-24-2024, 11:56 AM   #5
BDO
Drives: 2016 X6 40d M-sport
Yes, if you don’t your compressor will fail eventually. Changing the bags is easy and cheap.
      03-31-2024, 10:49 PM   #6
jc-
jc-'s Avatar
Drives: 2018 X5 50i
I’m having similar issue- but it started after I dropped the front… and put those parts in rear to that makes the computer read the suspension should stay similar on each side….
      04-02-2024, 08:27 AM   #7
kdad
I'm OP. Just changed the bags diy.
Just do it if your car is in the 70k mi range
