07-18-2017, 06:58 PM | #551 |
#buildnotbought
10951
Rep 4,908
What I've heard is that the cabriolet will be called the z4 and that later a coupe will/may come called the Z5
07-18-2017, 07:10 PM | #552 | ||
7909
Rep 11,785
07-18-2017, 07:27 PM | #554 | |
#buildnotbought
10951
Rep 4,908
But BMW's M performance line are basically the strongest cars below the M cars. But they dont have the real performance parts the M cars have (or had have for at least the last 20 years or so), like an LSD and semi floating brakes/rotors. On some cars you can get an LSD as an option (I think the m235i is the only one in that)
supra932487.00 |
07-18-2017, 07:38 PM | #555 | |||
Rep 9,160
5
07-18-2017, 07:43 PM | #557 |
7909
Rep 11,785
07-18-2017, 07:44 PM | #558 |
Rep 9,160
Exactly the market the first Z3 inhabited. A Miata with a few simple luxury features. Then it sprouted a straight six and got a little off track. Then it got comically ugly and I bought an M Coupe, so off track wasn't all bad. But getting back to something direct, simple and fun like the 4 cylinder Z3s would be a great solution.
07-18-2017, 07:51 PM | #559 | |
7909
Rep 11,785
And if so.. why don't they really be different and put some performance into their six cylinder model and make an M ? The simple fact is.. if it's worth building at all.. it's worth making at least 2 versions.. one or more 4 cyl models for the daily driver chick cars and potentially a range topping 6 cyl higher performance model for those that want a more sporting vehicle. |
Red Bread4465.00 |
07-18-2017, 08:02 PM | #560 |
Rep 2,335
So does that mean the standard 6 cyl will be the B58B30M0 and the Z4 M-performance with the B58B30O0? Or some other similar configuration. Sorry I'm not up to date on BMW powertrains.
07-18-2017, 10:14 PM | #561 |
Moderator
7517
Rep 19,368
No. More than likely it means that the M Performance (M40i) model will be the only six cylinder model. This is true for the G2x/G0x 3/4/X3/X4 lineup, so it makes sense that it will hold true for the G29 Z4 as well. Unfortunately, while the others will all get a full blown M model sitting above the M40i powered by a 450hp+ S58, there are currently no plans for a Z4 M (according to SCOTT). But you never know, that could change.
supra932487.00 M3 Adjuster7909.00 |
07-18-2017, 10:16 PM | #562 | |
Rep 887
Isn't the N54 considered one of the best engines in recent years? The 1m is now considered one of the best new M models, capturing the spirit og a true drivers car. Never saw anyone say BMW out a 6 cylinder in to differentiate itselt from a competitor. In fact one could say BMW is known for its amazing 6 cylinders. |
07-18-2017, 11:57 PM | #563 | |
Rep 2,335
07-19-2017, 06:37 AM | #564 | |
Rep 4,058
Re the N54, I understand that it had issues with the high pressure fuel pumps; that was a common issue on the first E89 SDrive 35I Z4's. The later N55 is a much more reliable power plant. The old Top Gear Z4 review:
Huz-Z
BMW Z4 3.0si Roadster. Montego Blue Metallic. Premium and Sport Package. |
07-19-2017, 08:36 AM | #565 |
salty cowboys fan
6174
Rep 3,415
No Z4M but X3M instead bean counters fully in-charge
she’s home! '22 M4 Comp xDrive
07-19-2017, 09:50 AM | #566 |
Rep 9,160
07-19-2017, 09:51 AM | #567 | |
Rep 887
For n54, the hpfp was only an issue in early years. I think from 2011 on it was improved. I know for certain 13'/'14 model years had zero issue. btw I love that Top Gear review for the e85. I also liked the e89 one from Top Gear. Its unfortunate though Fifth Gear compared the regular 35i to a Boxster S, which is a higher trim level. I think the 35is vs Boxter S would have been a better comparison, but why cry over spilt milk. The Z3 was grossly underpowered and did not have enough kit. I do agree that my e89 is bloated in comparison, but I do like all the creature comforts and the n54 is an amazing engine that is very easy to mod for 400+ whp, 4xx+ tq. As you can see by my signature I'm also heavily modded.
GC LITES / BQ TUNE / MHD / FUEL IT BT ECA / WALBRO 525 LPFP / KW V3 / E9X M3 CONTROL ARMS / TURNER REAR CAMBER ARMS / RE BUSHINGS / H&R SWAYS / LUXON STRUTBAR / VRSF 7.5" FMIC / ER CP / TIAL BOV / VTT IN/OUTLETS / AFE PRO5R INTAKE / AR C.L. DP / BMS OCC / RB PVC / CF LIP + SIDE + SPOILER + DIFFUSER / IND REFLECTORS / BLK GRILLS / STUBBY / PB BBK / Forgestar F14 F: 19x9 et35 R: 19x10 et38/ Michelin PSS F: 245/35/19 R: 275/30/19
Red Bread4465.00 |
07-19-2017, 10:38 AM | #571 | ||
7909
Rep 11,785
BMW hasn't even gotten seriously into the 4 cyl game right now again .. when they should be developing a kick arse twin turbo 4 cylinder S motor like an S20 or S48. So yes... they are clinging to the 6 cylinder as a differentiator. The M2 is a 6 cyl and competes with the 5 cylinder Audi and a 4 cylinder turbo boxster/Cayman and a 4 cylinder Mercedes A45 sedan. |
Red Bread4465.00 |
07-19-2017, 11:22 AM | #572 | |
Rep 887
I respect your opinion. To each their own. On a side note its good knowing these changes only help to increase the value of previous gen, so a 4 cylinder turbo, or hybrid, etc will only make the n54 equipped models more desirable.
