10-20-2017, 06:26 PM | #1 |
Rep 451
Drives: 2017 X5 & 2020 X5
Good day all
Just bought an F25/26 M Sport paddle shift SW off eBay and just wanted a heads up as what to look out for when I replace the old one with the new purchase. I have replaced a std wheel with a paddle shift one on a VW Tiguan and I am expecting the procedure will be much the same as for the X5. Namely 1. Disconnect battery earth cable in the boot 2. Unclip airbag and disconnect cables and carefully place component face up 3. Mark nut before removing it so as to give an idea of how much you need to re tighten it to when the new one is on 4. Align wheel to straight ahead position before final removal of wheel and replace with new one taking care in lining up the splines beforehand. 5. Retighten nut and connect up all the plugs/cables and in the process check that they match. 6. Clip airbag back on and check to see that is secured as it was prior to removal. 7. Reconnect battery. 8. Code the relevant ECU that paddle shift is now installed. Is there anything I am missing? At this stage I am wondering if I should just FDL code the PaddlesVerbaut from Inactive to active or VO code the - BDC_Body, Kombi, and ICM by adding 2TB to the FA. Any feedback to the above would be appreciated Thanks
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive Last edited by Bambazonke; 11-29-2018 at 05:28 AM.. |
10-20-2017, 10:45 PM | #2 |
Rep 982
I don’t think anyone has been able to make the paddles work on a non m-sport X5. I believe it was determined there was a wire missing. Good luck.
BitteEinBit31.50 |
11-25-2018, 05:14 PM | #3 | |
Rep 451
Firstly there is a subtle difference in the paddle shift wiring on the F25/26 and the F15/16 steering wheel On the X3/X4 the pink and white wires for the paddle shift connect in the 6 pin plug at pins #4 and #5 respectively. These wires then connect to the JBE ECU. In an OEM X5 SW (Steering Wheel) ONLY the white wire connects in the 6 pin plug at pin #5. This wire then connects to the BDC ECU. In the X5 circuit diagram, the pink wire is now spliced to the black wire that earths to the SW. This wire is also spliced again to join the 6 pin plug at pin #3. These splices are not visible as they are covered in black insulation tape. I removed the tape to confirm the status of my SW and then reconnected the pink wire previously connected at pin#4 to now where the black wire earths on the SW. I did this by unscrewing the T10 Torx screw and wedging the metal "fishplate" under the black wire plate (see last photo) Once this wiring mod was done, I then wrapped up the wires with cloth insulation tape, reconnected the plug and airbag and then reconnected the car battery. I then FDL coded the paddle shift option in the BDC module from nicht aktiv to aktiv Once again many thanks to DW at BMW Townsville for his valuable assistance
MY 17 X5 2.5d sDrive Last edited by Bambazonke; 11-29-2018 at 05:37 AM.. |
7
11-25-2018, 10:54 PM | #4 | ||
Rep 7,160
DuSh2113.50 |
11-26-2018, 09:44 PM | #5 | |
Rep 535
OP what was the part number of the wheel you used? Was it from a F25?
Present: 2014 X5 50i
11-28-2018, 02:52 PM | #6 | |
Rep 451
If it has "SET" written on the button it is most likely from a F25/26 which will mean you having to modify the wiring as I have done above plus coding. I also swapped my original buttons from my original SW to match the LIM function as programmed in the car
MY 17 X5 2.5d sDrive |
11-28-2018, 02:57 PM | #7 |
Rep 451
Would have to buy a brand new airbag that is big $$$$ plus find a SW with the active cruise control buttons which are rare and also expensive. I have one of these SW's on my X3 and not really a fan of them. They are far more suited for a F2X/3X or a 5 series in my opinion
11-28-2018, 02:59 PM | #8 | |
Rep 7,160
11-28-2018, 03:49 PM | #10 |
Rep 451
Steering Wheel I have been in Australia too long they love acronyms here
Maverik2594140.00 |
11-28-2018, 03:52 PM | #11 |
Rep 451
Works on mine no reason it should not work on any other F15 X5
11-28-2018, 10:00 PM | #12 |
Rep 2,511
Can you provide more details? You had a basic non heated,no vibration steering wheel? No M-Sport, Driver Assistance Plus package or Traffic Jam Assist packages on your car? Your new steering wheel is from F25/26? On your pictures I also see at least 4 pink cables, can you provide a better explanation of the wiring or may be you have a wiring diagram and before/after pictures?
11-29-2018, 06:08 AM | #13 | |
Rep 451
The SW I bought off ebay I suspect was from an X3 or X4 as it had the "SET" button and different wiring as I have since discovered. All Australian models have the "LIM" button as Driver Assistance is standard across the range. X5's in North America and Europe may differ. The SW also had vibro but no heating. There is only two pink wires. The first piece has each end joining to the 2 blue 2 pin plugs that then go to the paddle buttons. Half way along this piece of wire. there is a splice with another pink wire that goes to the 6 pin plug. This is what you have to modify ie remove from pin#4 location to the earth point as shown in the last photo. There is also two white wires that also join to the 2 blue plugs and also has a splice to the 6 pin plug. Do not modify these wires as this goes directly to the BDC module. I have posted photos of the 6 pin plug before I modified it and a photo of a genuine X5 steering wheel 6 pin plug with paddle shift at the below link https://f15.bimmerpost.com/forums/sh....php?t=1341944 Post#12
MY 17 X5 2.5d sDrive Last edited by Bambazonke; 11-29-2018 at 02:31 PM.. |
BitteEinBit31.50 |
12-13-2018, 07:26 AM | #14 |
Field Marshall
32
Rep 117
Finally, the paddles work on my non M-sport F15!!
I can confirm Bambazonke’s solution works! I have a 2014 no line that came with the thin no paddle steering wheel. I purchased an F85 steering wheel from Ben at RGSport two years ago. Ben and I, and even Opasha, tried everything we could think of to get the paddles to work. We switched out paddle circuit boards, and the connecting wire between them…nothing worked. We had pretty much given up. Then last week, I saw Bambazonke’s post and thought, yeah right, it can’t be that simple, what the hell, I’ll try one last time. So Bambazonke walked me through his solution, and Ben helped me with coding. Removing the pink wire from the six pin connector in the steering wheel was a bit tricky, but Bambazonke walked me through it no problem. Our first attempt yielded a partial outcome; the paddles worked, but not properly. So Ben, in his infinite wisdom, sent me some non-M car paddle circuit boards, I swapped them out and voila, the paddles work perfectly. So if you’re skeptical, fear not, this is the solution you’ve been looking for. Last edited by BitteEinBit; 12-13-2018 at 02:39 PM.. |
6
12-13-2018, 05:12 PM | #15 |
Rep 2,511
Dang,now I want to swap my wheel really bad to get shifters. Not sure if it worth the money for me, I have heated and vibrating wheel so it might be too price to get a new wheel just for paddle shifters. I was sleeping better when I thought its not possible :-)
BitteEinBit31.50 |
12-18-2018, 07:04 PM | #16 | |
Rep 218
03-23-2019, 01:38 PM | #17 | |
Rep 2,511
03-25-2019, 03:11 PM | #18 |
Field Marshall
32
Rep 117
Yes
Bambazonke210.00 |
03-27-2019, 01:46 PM | #21 | |
Rep 18,713
Technically, you should be able to rig it. Just need to get the correct SMD resistor and know how to solder it. I never play around with soldering SMD, I don't have steady hand. Thank you for the referral.
BitteEinBit31.50 RED_Y_1054.00 |
03-27-2019, 02:33 PM | #22 |
Rep 2,511
