12-21-2015, 11:00 AM | #1 |
Rep 208
JL Audio dual powered 8" sub
I'm thinking about adding a sub to the f15. I like this setup from JL, it fits across second row seat with 3" on both sides, and only protrudes about 6". I have done any audio to any of my cars in quite some time, so I would appreciate any help in how I would wire this up to Harmon Kardon, as well as power from battery, and remote. Thanks in advanced
Brian Last edited by Bigb348; 12-21-2015 at 11:43 AM.. |
12-21-2015, 06:49 PM | #2 |
Rep 106
That's the setup I have... It's powered by a JL Audio XD 300/1. The output is spectacular without knocking the doors off. I had it professionally installed for $250. After the install, I checked things out and it's actually quite an easy install as the battery is in the rear and the access to the wires for the HK amp are right in the back as well. Probably took them 90 minutes to do the whole thing.
I see you PM'd me, but I thought I'd share this as it may help others. Looking at the install, it seems they tapped the purple and yellow wires from the HK amp (no idea what speakers they lead to, however). I installed a line driver to improve the signal from the stock amp as it was a bit low (cost $100). Additionally, they used a fuse tap, which runs across the spare tire well where the batteries are held, to act as a a power on source. The setup is clean and easily accessible. Last edited by jugdish; 12-21-2015 at 07:05 PM.. |
12-21-2015, 09:03 PM | #3 |
Rep 208
Thanks for the pics. If you could also post pics of the sub setup you have and how you secured it from moving and a pic of the battery fused lead to amp it would be appreciated. I think I may attempt the install myself thanks to your pics.
How does it compliment with the bavsound ghost subs? I plan on popping my ghosts in the next couple of days. |
12-22-2015, 01:54 AM | #4 |
Rep 993
Nice. That box already has the amp built in. I think I might get the single 12" box. Should be a simple install. I'll have to measure and see if it would fit in storage compartment, but putting it there might cause a lot of cancellation with the lid shut?
12-22-2015, 11:14 AM | #5 |
Rep 106
I'm out of town now so can't post anymore pics as the X5 is at home. Basically, I have the sub laying across the back cargo area behind the second row seats. It's a beast and doesn't move at all. As Crackerjack15 says, you can get this setup with the amplifier built in. However, I went with separate components because you can always upgrade one or the other for future use and the only thing that is exposed is the speaker wire. If you get the sub with the built in amp you will see the exposed ground and power cables which are quite large in diameter.
Pretty sure this sub won't fit in the spare wheel well storage compartment, it's larger then it looks. I think you will also lose some thump if you did place a sub there. Hooking up to the battery is a snap as it's located under the back cargo area. There's something like 8 screws that need to be removed and the plastic trim lifts off of the battery..... Oh... and it sounds awesome with the BAV Sound ghost woofers... |
12-22-2015, 11:34 AM | #6 | |
Rep 208
setup. Can't wait to hear it w the bavsound ghosts. |
01-02-2016, 07:17 PM | #7 | |
Rep 7
Thanks, Paul |
01-02-2016, 09:46 PM | #8 |
Rep 7
looks like this maybe a viable option as the remote turn on source:
http://f15.bimmerpost.com/forums/sho...13&postcount=2 |
01-03-2016, 12:41 PM | #9 |
Rep 106
here are some close up pics of the connections. The fuse panel is behind the rear passenger side cover. I used a fuse tap to tap the fuse that controls the exterior mirrors as I know that feature only works when the ignition is on. The last pic shows the specific wires that were tapped for the subwoofer input.
My cargo area is full and I don't have time to dismantle the area to show the connections to the battery. However, it's the easiest of all the connections: Red power cable to the red terminal and you can either ground to the negative terminal on the battery, or scrape some paint of an area in the back and ground to a bolt in the rear. |
Kof36.50 |
08-30-2017, 09:46 AM | #12 | |
Rep 428
Drives: 2015 X5 35d
Thanks Last edited by fromkrypton; 08-30-2017 at 09:59 AM.. |
08-28-2019, 02:58 PM | #13 | |
Rep 842
https://www.audiocontrol.com/car-aud...-upgrade/lc2i/
'23 B8, '84 Monte Carlo SS, '23 Escalade, '21 S 580, '20 AMG GT 53 , '18 LS 500, '18 X6, '16 Corvette, '12 750Li, '14 GS 350, '13 ES 350, '10 Maxima, '09 Challenger |
09-13-2019, 06:54 PM | #14 |
Rep 1
If anyone is interested I found the OEM subwoofer wires and tapped into those rather than the rear speakers. I initially tapped into the wires shown above which are the rear speakers but wasn't getting the bass response that I should have been getting, which sent me into troubleshooting mode. It appears that the rear speakers are filtered from either the head unit or the amp. Either way, you will not get the proper low frequencies for a subwoofer from the rear speaker taps. In order to do that, tap into the subwoofer wires and you'll notice a night and day difference. Hope this helps someone.
Left Sub: Thick Black and Red, Black and Brown Right Sub: Thick Blue and Brown, Blue and Red |
5
10-28-2019, 08:06 PM | #15 |
Rep 11
This post was very helpful. I successfully connected all the components in 30 minutes but couldn’t leave it due to an airport run. I’ll get back to it Saturday and tuck everything away, nice and clean.
10-27-2020, 04:32 PM | #16 | |
Rep 740
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
10-27-2020, 07:55 PM | #17 |
<3 Flat Four
217
Rep 754
left side of the trunk, open the panel n ull see the oem amp and those wires inside.
2011 335is Le Mans Blue
10-29-2020, 11:27 AM | #18 |
Rep 740
Thanks! Realized it the next day haha.
12-07-2022, 12:50 AM | #19 | |
Rep 161
Am I better just to tap into the wires and leave the factory subs running, or cut them and just use the aftermarket sub? On my previous A6 Allroad I removed the factory sub and tapped into its connection, meaning the aftermarket sub was the only 1 working. |
