      02-18-2016, 02:46 PM   #1
zacklee
United Kingdom
17
Drives: 2015 X5 F15 UK
Retrofit speed limit info 8TH success UK
First of all thanks for shawnsheridan kindly help!!
I have a 2015 x5 30d M sport come with Kafas2 camera for 5AC AUTOM. HIGH-BEAM HEADLIGHTS CONTROL and 5AS DRIVING ASSISTAN. The dealer didn't order the 8TH Speed limit info. Therefore I try to find how to get it activated as I know SLI use the same Kafas2 camera.
After searched, understand need FSC code to active this function, speak to Shawnsheridan, he give me Gerry's details, who order the FSC code for me, take about 3 days.
After recived the code, follow this process
http://www.bimmerfest.com/forums/sho...90&postcount=2
And change the parameter fields as follow:
Diag Address = 0x5D
Base Variant = KAFAS2
Application Number = 0x7E
Upgrade Index = 0x01
After that, it's working now on my HUD or dashboard.
I do the VO coding before import the code,
adding 8TH to FA and VO Coding KAFAS2, KOMBI and NBT.
Thank you for everyone's help! Good luck.
JustChris17423.00
      02-19-2016, 04:10 AM   #2
alphaod
alphaod's Avatar
Good info... so this isn't standard?
      02-19-2016, 06:28 AM   #3
zacklee
United Kingdom
17
No in the UK, this option allow the kafas2 camera read speed limit signs on the road may + from maps.
I know china version get the speed limit info from map only.
      02-19-2016, 07:51 AM   #4
wearenh
Drives: 2015 x5 x35i DHP
also, I stumbled on this device for retrofitting map based speed limit if you don't have the kafas
ww w.cust0mretrofit.ro/bmw-speed-limit-info-activator (remove space in www's and replace 0 with o)
for some reason, when I try to insert this as a link, or even as text, it replaces the URL with ******
is cust0mretrofit blocked by the forum for some reason ???
      09-28-2016, 05:39 AM   #5
lyjfe_ning
Drives: BMW X5 F15 30D
Thanks for sharing. Is there any chance you can give me Gerry's detail? I'm interested in retrofitting mine.
      09-28-2016, 07:02 PM   #6
alphaod
alphaod's Avatar
Interesting. I just figured it was standard with the HBA and KAFAS2 camera. I guess if some places you can still order the F15 with halogen lights, they'll find a way to charge for speed limit info.
      10-28-2017, 02:05 PM   #7
wilche
Drives: 2015 F15 X5M50d
Hi any chance of PMing details of where I can order the SLI FSC code?
      05-11-2018, 07:07 AM   #8
Doncee
United Kingdom
12
Drives: X5 F15 2015 2.5D
Hi Zacklee, I am new to the forum and just got my X5 F15. I am in the UK. I don't have access to the coding equipment and wondered if you would do the Speed Limit retrofit for me....for a charitable donation of course . I have lane departure warning, collision warning and on the windscreen it says 'connected drive' so I believe I have the necessary hardware. Please can you let me know
Search this Thread:
Advanced Search
