      03-15-2016, 02:14 PM   #1
dubsesd
#dubspec
dubsesd's Avatar
6336
Drives: G05 X5/ 2016 F80 M3 INDVL
Eibach springs/links installed
i have been debating installing any form of lowering on the f15 because i didnt want it to ruin the ride. although the car rides at a pretty acceptable height, another 1" would make it perfect imo. i chose the euro version Eibach spring with rear links. the font lowers about 1.3" and the rear you basically adjust wherever you like with the links. ride is great! most noticeable difference was driving it away after lowering. it felt tighter in any form of turning and slightly stiffer. after a week of driving, i cant remember it driving any different. winter is ending and our roads are full of random cracks and holes, and it drives very well regardless. no bounce, no jarring rebound.
car sits at 31.15" from ground to fender on oem 20" wheels. in the pics i test fit the 22" wheels to see how they look. very happy with the results
LCI ///F80 M3 Individual Atlantis Metallic / Black Full / Carbon Cermics / 6MT
MPE / M Performance & Carbon package / KW v3 / 20" HRE R101LW / 20" HRE 527s / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow
instagram: @ dubsesd
Appreciate 12
      03-15-2016, 03:38 PM   #2
Jesse E93
Drives: 2009 335i E93
the drop is perfect. Congrats on a beautiful beast!
      03-15-2016, 04:00 PM   #3
crackerjack15
crackerjack15's Avatar
842
Drives: 2024 X5 50e
Outstanding!
      03-15-2016, 04:26 PM   #4
Alan l.
Alan l.'s Avatar
5449
Looks awesome. BTW congrats on the upcoming toy!
I was wondering why you were hanging out on the other side of the forums
Alan
      03-15-2016, 04:33 PM   #5
dubsesd
#dubspec
dubsesd's Avatar
6336
Thanks! It's going to be a little wait but i should have it by June.
      03-15-2016, 05:14 PM   #6
gtmassive75
gtmassive75's Avatar
361
Drives: G05 X5,G20 M340,Infiniti Q50RS
Drop looks good, perfect for the 22s. I cant find those 599 reps anywhere, i called the place you recommend, they told me they stop making them..
2020 G05 MSport 40i--Phytonic Blue Metallic/Vernasca Coffee Leather/Multi Contour SeatsTrim/Executive Package/MSport Brakes/Icon Adaptive Led HeadlightsW/Laserlight/Harman Kardon/Heated Front Seats Armrests & Steering
      03-15-2016, 06:44 PM   #7
stewy604
stewy604's Avatar
290
Looks great man. Well done.
2007 Suzuki GSX-R 750
      03-15-2016, 07:29 PM   #8
dubsesd
#dubspec
dubsesd's Avatar
6336
Appreciate 8
      03-15-2016, 08:03 PM   #9
Kzang
Kzang's Avatar
3240
Drives: 2015 X5 35i Msport SG
One of the best looking X5's . Looks great.
      03-15-2016, 10:00 PM   #10
Taran.J
Taran.J's Avatar
Drives: BMW, LEX, MBZ, RAM, TESLA
I need to order some Eibach springs. Can't believe they aren't openly available in the states like the E70 springs
      03-16-2016, 04:58 AM   #11
elisiX
elisiX's Avatar
Australia
687
Drives: '20 X3M Competition
Looks great!
Are these essentially the same as the ACS Spring for he X5M?
H&R is more aggressive but from reports it rides harder, while the ACS spring (which I believe is rebranded Eibach), rides like stock
      03-16-2016, 05:46 AM   #12
robbys3m3
Drives: M3's
Perfect drop!
      03-16-2016, 08:21 AM   #13
Alan l.
Alan l.'s Avatar
5449
Where did you order the eibach springs from? Did you measure the drop before and after with the same wheels to see if it was lowered by the advertised amount?
      03-16-2016, 09:11 AM   #14
X5Jouster
X5Jouster's Avatar
110
Drives: X5 xDrive50I Msport
im really digging those 22s and the x5 looks great!..... but i couldnt imagine the ride on 22s after the drop(Those tires look way to thin for any pothole)
lowered with H&R spring/link and 20s with Mich. PSS. its a perfect driving setup for every occasion. the 30mm spacers take it to another level, and are the only reason the 20s work.
      03-16-2016, 10:20 AM   #15
BMW - BEKTAS
BMW - BEKTAS's Avatar
16
Drives: X5M
I have been waiting to see how Eibach will look on your car. It looks perfect. Hope it rides well. Now I will have to look for Eibach for my ride ��
      03-16-2016, 10:22 AM   #16
BMW - BEKTAS
16
Drives: X5M
Do you have spacers front and back 30mm?
Thanks
      03-16-2016, 11:16 AM   #17
dubsesd
#dubspec
dubsesd's Avatar
6336
Thanks
I only have 12.5mm rear spacers added. Could use 5mm up front but not nessacary
      03-16-2016, 11:17 AM   #18
dubsesd
#dubspec
dubsesd's Avatar
6336
Baan velgen. Great price too. Drop is pretty much bang on as advertised.
      03-16-2016, 11:18 AM   #19
dubsesd
#dubspec
dubsesd's Avatar
6336
Originally Posted by elisiX View Post
Looks great!
They are half the cost of the overpriced ac schnitzer springs.
      03-16-2016, 02:15 PM   #20
X5Jouster
X5Jouster's Avatar
110
Thanks
yes 30mm all four corners. i wanted to keep the ?geometry ratios? the same for the stance, but it might sit a tad wider then it needs to in the front....25 all around is probably best, but i believe the reason i did it was because of the DRA spacers options and sizes. i wanted stock bolt sizes and no extended lugs. i think 25 mm spacer have extended lugs only and to get DRA which bolt to the hub then you bolt the wheel on, you need to jump up to 30mm
      03-16-2016, 02:20 PM   #21
mdallas
Drives: 2021 G05 40i
that is outstanding!!!
I'm having the H&R Kit installed tomorrow (for 2VM). I also got the 5mm (front) and 15mm (rear) spacers. Will put those on in a few weeks when the 20" 451 Y spokes go back on.
      03-16-2016, 09:06 PM   #22
42pilot
42pilot's Avatar
591
Drives: 2014 X5 35d MSport
That is a very cheap price. Approx $50-ish per corner... Too bad they're progressive. How many miles on your car when installed?
