10-06-2017, 01:25 AM | #1 |
Rep 101
Upgrading Speakers for Current F15
Hey Guys,
I am planning to upgrade the current speakers, but i am not sure the speakers' size. Are they 1" Sweeters /4" mids /8" Sub woofer? Looking forward to hear from your advise. Thanks! http://www.audiotec-fischer.de/lng/e...-83c-bmw2.html Last edited by baubaulu; 10-06-2017 at 01:48 AM.. |
10-06-2017, 01:48 AM | #2 | |
Rep 826
Drives: 2017 C43 AMG
2014 X5 xDrive50i Mineral White | DinanTronics Stage 1 | Vossen HC3
10-06-2017, 02:05 AM | #3 | |
Rep 101
Does the music quality on the NBT lowest version good enough? Thanks! |
10-10-2017, 06:25 AM | #4 |
Rep 41
Drives: BMW X5 45e -20, 225xe -16
Hi,
actually the version of NBT doesn't really have any impact to sound quality. I upgraded my 335i with DLS UP4i front speakers, Earthquake SWS-8i subs, added JBL MS-8 to drive everything else than Earthquakes which had Mosconi AS-100 highend amplifier. This sounded very good even compared to my X5 which has B&O. 335i had HiFi option which has a big benefit, i mean the audio signal to original amplifier is a line level signal. This setup could work well in x5 as well. I kept the back seat speakers stock as I use to bias the audio to front speakers. |
10-10-2017, 07:28 AM | #5 | ||
Rep 101
Thanks |
10-10-2017, 01:06 PM | #6 |
Master of my own domain!!
153
Rep 1,049
Anyone know if you can upgrade the number of speakers from Hi-Fi to HK? Is the wiring already there or would this require a lot of work?
10-10-2017, 02:17 PM | #7 |
Rep 18,707
baubaulu , I suggest to go with BavSound speakers set with BimmerTech amp upgrade.
Ferg , You can, mostly you will need a new enclosure or covers for the rear doors and rear D pillars. While wiring, I believe there are none on the D pillars. Best way is to do BavSound with BimmerTech amp as I mentioned above.
10-10-2017, 02:32 PM | #8 | |
Rep 2,699
10-10-2017, 08:24 PM | #9 | ||
Rep 826
10-10-2017, 08:44 PM | #10 |
Rep 18,707
NBT and NBT EVO just the software.
The hardware themselves (speakers and amp) are still the same.
10-12-2017, 12:31 AM | #11 |
Rep 2,699
Hope you have a car to test beacuse it is true without placebo effecylt. I listen FLAC files mostly and on the 2014 F15 would hook up iphone via USB for better sound. Blutooth as I said was quite poor quality. Apple CarPlay sounds pretty amazing.
10-12-2017, 08:01 AM | #12 | |
Rep 18,707
Tested FLAC before and after BavSound speaker upgrade. They all sound the same. The only difference, due to new enclosure design, the G30 with NBT EVO have better bass.
10-12-2017, 01:45 PM | #13 | ||
Rep 2,699
10-12-2017, 01:58 PM | #14 | |
Rep 18,707
I wouldn't play FLAC wirelessly. It defeat the purpose IMO. I uses USB thumbdrive to play FLAC. AFAIK, wireless connection, especially Bluetooth, there is limitation.
10-12-2017, 02:42 PM | #15 | ||
Rep 2,699
