      04-04-2024, 06:53 AM   #1
onurx5
Drives: 2016 bmw x5
Vibration at low speeds
Hi everyone,
I have a f15 x5 30d which has a slight vibration problem at low speeds, starting around 20mph then gradually stopping at 35mph.
I have changed transfer case oil with genuine dtf1 and also done a vtg calibration and the vibration is still there.
I had a look around the engine bay today and saw grease around the front propshaft.
Does this look normal?
      04-04-2024, 07:25 AM   #2
dr_greenthumb
Drives: 14' F15 X5 35i x
I'd be checking tires first.
      04-04-2024, 07:31 AM   #3
onurx5
Drives: 2016 bmw x5
Its got budget tyres fitted, im going to recheck the balance and see from there, thanks
      04-05-2024, 12:05 AM   #4
spit
Drives: BMW F15 x35i
Originally Posted by onurx5 View Post
Hi everyone,
I don't want to say anything, but if grease appears, it's bad. Check the clearance on front propshaft.
watch this video... the problem is known
what is your current mileage?
      04-05-2024, 03:46 AM   #5
onurx5
Drives: 2016 bmw x5
The mileage is on 73k miles.
      04-05-2024, 02:33 PM   #6
onurx5
Drives: 2016 bmw x5
Today it went in for road force balancing and the drive is 10times better, now the vibration is only happening between 20-30mph and goes away as i speed up.
I had a look under the car and the front side propshaft flange end has excessive play, can this prop cause any vibrations?
      04-05-2024, 10:37 PM   #7
spit
show in the picture where exactly you found the looseness
      04-06-2024, 03:17 AM   #8
onurx5
Drives: 2016 bmw x5
The play is in splined area.
      04-06-2024, 07:11 AM   #9
m4forum
79
Drives: M3
could you drive better the play. make a video?
      04-06-2024, 07:43 AM   #10
onurx5
Drives: 2016 bmw x5
I have a video but it wont let me upload video on the forum.
      04-06-2024, 11:17 PM   #11
spit
maybe youtube?
      04-07-2024, 12:26 AM   #12
m4forum
79
Drives: M3
use google drive and add link
