      08-06-2014, 09:17 PM   #111
opasha
opasha's Avatar
1329
Drives: 2014 BMW X5 50i
Originally Posted by mikikuki7 View Post
Anyone knows what this error means? Im using F25 target con next vĂ*a VIN.
I took my X5 to dealer for service and they change something and they had to reset everything...
Help!
Can you list what ESYS version and what PSDZDATA version you are using just so others know in case they run into the same issue. Thank you .
@r33, I currently have ESYS 3.24.3 and PSDZDATA file 52.1. I just want to make sure in case the dealer updates anything in the future. Last I checked, this was the latest software, but I could be wrong. Thanks .
      08-06-2014, 09:35 PM   #112
PM sent.
      08-07-2014, 01:53 PM   #113
Armen383
Armen383's Avatar
Cyprus
83
Drives: Mercedes-Benz E63S
I had ESYS 3.25.3 + PSDZDATA 2.53.0 installed back in July...
      08-07-2014, 02:12 PM   #114
opasha
opasha's Avatar
1329
Thanks for the update, Armen. Ben sent me the updated psdzdata .
      08-08-2014, 02:54 PM   #115
Karthik
Drives: 2015 x35i M Sport
What are these features that are being tested?
Sailing / Coasting Function - EcoPro Mode
LED headlamp Tweaks - Work in Progress!
any description in brief?
      08-08-2014, 04:24 PM   #116
opasha
opasha's Avatar
1329
Sailing/Coasting feature just gives you a visualization of when the car is in this mode, which is when the vehicle should technically shift into Neutral when it reaches above a certain speed (40km/h and up). Saves gas.
LED Headlamp tweaks are the parameters for the LED Lighting package where he changed the ramp time (time it takes to change from one to another) from low beam to high beam, etc. He also modified the brightness for the cornering lights. Basically, to get these features to work, you have to have the LED package.
      08-08-2014, 08:00 PM   #117
Karthik
Awesome...Thanks for the info.
Sailing/Coasting feature -- Does this automatically change to ECO mode after reaching 40+ km/h. what was speed that we get with the vehicle?
LED Headlamp -- When you mentioned cornering lights, are those the ones above corolina rings?
      08-08-2014, 09:32 PM   #118
opasha
opasha's Avatar
1329
No, I think you have to be in ECO Pro mode when you coast/sail first. That's the whole point of it. Someone else that has it coded can chime in if they know more details.
The cornering lamps I am not 100% sure where they are located because I don't have the LED package. Hopefully, someone else can answer this for you.
      08-10-2014, 03:30 AM   #119
CatFlap
United Kingdom
21
Drives: ...
You still have to select Eco-Pro mode 'manually' though the car selects neutral automatically and 'sails' / 'coasts' whenever you back off the gas above 30mph! The gear selector indication still shows 'D' though the gearbox actually selects neutral during this time, the engine rpm drops to idle. The feature works really well and I have noticed an improvement in fuel economy overall.
The LED package has built in additional cornering LED's in the headlamp units. I'm not sure about the Xenons, do they still use the fog lights for this purpose?
X5 F15 - gone after 5 months!
      08-10-2014, 03:41 AM   #120
CatFlap
United Kingdom
21
Drives: ...
Talking Coasting / Sailing Video
This video shows the sailing function in action. I was driving at ~30mph in Eco-Pro mode, as I back off the throttle you'll see that the engine rpm drops to idle as the gearbox shifts automatically to neutral. The car continues to sail along at ~30 mph. Increasing the throttle causes the gearbox to re-select the appropriate gear again. Works really well, particularly on slight downhill gradients (obviously )
https://www.dropbox.com/s/pxu58fav5m...2008.34.11.mp4
      08-10-2014, 05:23 AM   #121
opasha
opasha's Avatar
1329
Ok, this truly looks beneficial/awesome. Have you encountered any hiccups at all? So do I need to press the Cruise button to allow to work or is it automatic when you let go of the throttle at above 30mph exactly when Eco Pro is engaged? When/how does this get enabled? I just want to make sure I do this 100% correct as you have shown. Thank you, my friend!
      08-10-2014, 05:56 AM   #122
CatFlap
United Kingdom
21
Drives: ...
It works in Eco-Pro mode only, one of the coding mods enables a new 'coasting mode' tick box on the Eco-Pro set up set up screen. There's also a new odometer on the Efficient Dynamics status screen that shows the distance coasted though this does not work with the coding done so far (indicates zero miles) - more research needed to get this working!
Here's a video showing the Efficient Dynamics status screen with the coasting mods done (sorry for the poor video quality, it was made whilst driving!):
https://www.dropbox.com/s/fw0svq3a3j...2020.30.52.mp4
Once this mode is enabled and you select Eco-Pro driving mode the car will 'coast' when you're above 30mph and back off the throttle. It's clever enough (in the UK anyhow) to use sat-nav / speed limit data to know when coasting should be disabled to allow the engine to slow the car down i.e. it puts the car back in gear to facilitate engine braking!
I've seen several Eco-Pro 'driving tips' on the display telling me to back off the throttle since there's a lower speed limit ahead, in this case the sailing mode seems to be inhibited.
Coasting mode is disabled when cruise control is enabled.
This has certainly been one of my more interesting coding sessions!
You're more than welcome @opasha
      08-10-2014, 06:08 AM   #123
opasha
opasha's Avatar
1329
Thank you very much for this informative post . I love hearing about tips and tricks from fellow members, especially when coding is involved. Because of these features, I'm so glad I learned how to code. It really makes things more convenient/fun/interesting. Looking forward to hearing anything new you find!
      08-10-2014, 06:22 AM   #124
CatFlap
United Kingdom
21
Drives: ...
I'm away on vacation so my X5 is parked up having a well earned rest for a few weeks. I'm enjoying my time away though, in some ways, I can't wait to get back to do more 'research'!
My mods to the led lighting transition timings were interesting, I'm noticing far more changes to the dipped beam patterns than before. The changes in beam pattern are not new it's just that they're more noticeable than when the ramp times were longer. There's a definite change takes place at around 15mph, the beams width and throw/distance changes noticeably. I think I need to make further changes to the timing parameters, I plan to increase them since my current settings are a little too abrupt!
      08-10-2014, 06:57 AM   #125
opasha
opasha's Avatar
1329
Ah, that is interesting. I don't know if you have a GoPro camera or have the time, but I'd love to see the LED tweaks in action.
Enjoy your vacation, @CatFlap!
      08-10-2014, 10:11 AM   #126
CatFlap
United Kingdom
21
Drives: ...
Yes i have, now the shorter days are coming I'll try to capture the action!
Thanks!
      08-10-2014, 10:22 AM   #127
opasha
opasha's Avatar
1329
Thanks!
Awesome!
You're very welcome, buddy!
      07-22-2015, 04:43 AM   #128
Mentat
Romania
27
Drives: BMW X5 F15 M50d
I cannot test this
HU_NBT 3000 -> REGEN_SCHLIESSEN
default: nicht_aktiv
change: aktiv
Sunroof Closing on Rain Detection
It's possible for us to have Taigate opening with foot below the rear bumper?
http://www.bmw.com/com/en/newvehicle..._tailgate.html
      08-25-2015, 04:00 PM   #129
X54TH
Member
X54TH's Avatar
Drives: 2019 X5 40i M Sport
Is it possible to code the F15 to start off in Sport Mode or Eco Pro Mode?
2019 X5 Alpine White M-Sport
Software Version 11/2022.31
2023 M2 (HEA) Brooklyn Gray
2021 330i XDrive Alpine White M-Sport
      08-25-2015, 04:30 PM   #130
Paddy_Lux
Drives: 2015 F15 40d M-Sport
It should be an option for 2016 models in Europe, all prior models weren't equipped with the sensors underneath the rear bumper (although I've seen some people trying to figure out how to retrofit them)
      08-26-2015, 02:07 AM   #131
chealsea007
Drives: F16 X6 M Sports
I take it the F15 is the same as F16 coding?
Would M sports features more things to code?
      09-25-2015, 08:02 AM   #132
Fast400
Fast400's Avatar
Germany
683
Drives: iX M60
2014 BMW  [0.00]
Has anyone successfully coded the full anti-dazzle (BDC_Body, LHM43, LHM44) on a F16 model?
2014, coding f15, f15, f15 coding
