      10-07-2016, 01:14 PM   #155
SMC23
Drives: Subaru XTrek / X5 40e
Question - what are you all using for Level 2 Charging?
      10-07-2016, 01:16 PM   #156
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
JuiceBox 40A EV Charger
SMC23180.00
      10-07-2016, 03:24 PM   #157
golovko
Drives: 2021 BMW G80 M3C - IOMG/KO
Originally Posted by Almaretto View Post
Reading their specs, I assume you still need 240v wiring for it to be a true level 2 charger?
This is what confused me: "Can be used with any power source: Plugs into a dryer, RV-type or regular wall outlet with available adapters. Save hundreds of dollars on installation - just install a simple 14-50R outlet and you are ready to plug in your JuiceBox"
2021 BMW M3 Comp
2021 BMW X3M
2018 BMW M3 - SO/SS ZCP - Gone
2017 BMW X5 40e M-Sport - Gone
2015 BMW M3 - Gone - ED Pickup June 2nd, 2015
      10-07-2016, 04:28 PM   #158
Almaretto
Almaretto's Avatar
2374
Check your local power company website for rebates. My power company had up to $2000 rebate to cover cost parts and labor; that offer expired at the end of last year. Now, the rebate is only $500, but good through 2018 or 2019.
I have a garage so I could have gotten one that was rated for indoor/just plug and play. But, the Los Angeles power grid is over-taxed and even occasionally had "insufficient grid power" dash errors with using the level one charger. So, I wanted to make sure it was hard-wired and done correctly.
      11-15-2016, 02:00 AM   #159
fsdks
fsdks's Avatar
10
Drives: 2011 328i xDrive Sports Wagon
Bosch EL-51253. Had an electrician come, put in a new 40amp circuit and hook this up. It hangs indoors (can be installed outdoors too).
2005 Nissan Xterra SE - hers
2011 BMW 328i xDrive Sports Wagon 6-speed - mine
Old: 2019 BMW X5 xDrive40i (hers), 2016 BMW X5 xDrive40e (hers), 2010 Dodge Ram 1500 4WD, 2008 Subaru Outback AWD, 2001 Dodge Dakota 4WD, 2000 VW Golf, 1991 Dodge Ramcharger 4WD, 1988 Mercury Topaz AWD, and 1987 Mercedes-Benz 560SL
      11-15-2016, 04:22 PM   #160
MochiEater
Drives: 2017 X5 40e
I have both a JuiceBox Pro 40A (40A) and a ClipperCreek LCS-20P (16A). Both with NEMA 14-50 plugs.
The JB is great if you have the space to mount it. The plug cable is 6 ft and the J1772 cable is 25 ft and both are very thick and heavy. The box is steel with no indicator lights. Not at all portable at 20 lbs. It has wi-fi and a smartphone app. You can read data in real time, set charging time, set max current, and lots more. Very cool if you are into all the techno. X5 40e can only charge at max 16A so this is a bit of overkill if you don't have another EV.
The CC is a bigger version of the OEM level 1 EVSE in the trunk (it's made by CC too). Plug cable is 6 inches (WTF were they thinking?) and the J1772 cable is 25 ft. The whole thing is just over 5 lbs. You could take it with you to recharge at RV parks or use someone's dryer outlet. It has lights just like the OEM EVSE. It's basic no frills EVSE, has no settings and no data, just plug it in and charge. CC also makes similar models that are rated for more charge.
      11-16-2016, 05:35 AM   #161
SMC23
After much reasearch, I will be going with the ChargePoint charger. Size of the unit and its wifi capabilities won it over.
      11-26-2016, 10:04 PM   #162
_Mbition
_Mbition's Avatar
Nigeria
106
Drives: E92 M3
Originally Posted by pocketdoc View Post
I am currently driving a 35d. I average 27 MPG.
I typically have an 18 mile commute each way, sometimes requiring more than one trip. A good part of the ride is freeway.
I am concerned that I won't get the best gas mileage unless I can find an outlet at my workplace.
Will the car recharge the battery while driving on the freeway, or only when coasting and braking?
What do you guys think?
If you are using all electric, you will drain the battery but can make the full commute one way. Using sport mode and battery save, will charge the battery during drive better whether on free or side streets if braking and coasting.
Have about 5k on my car now, daily driver to work 13 miles each way, and have taken 2 road trips (one to NC and one to VA).
I've achieved 17 miles on a full charge (eDrive), Im currently averaging 38 mpg mixed, and I fill up with gas after mixed driving probably twice a month.
Im charging it overnight daily, and luckily I have a Level 2 at work. Its cheating, I know. (Thank God for Chargepoint!!).
I precondition pretty much daily w/ the BMW Connected app, and I don't use the ventilation/heat on my way to work, just heated seat/steering wheel.
The car really trains you to live a more sustainable lifestyle, My electric bill after daily charging has only gone up 18 or so dollars a month so far, (simple level one charging from outdoor outlet), but saved me a TON in gas. As a matter of fact I'm highly considering solar on the house now.
I love everything this car has taught me so far, and looking forward to my next one already. Convinced one of my friends/coworkers to get out of his 320 and pick up a '17 330e, he'll be doing that Monday, and we will compare stats once he gets in it.
PAST LOVES:: 2 E39's, 4 F30's, 1 E92 M, 1 F80 M, 1 F15 e, and an F56.
CURRENT:: 2ND E92 M3.
      11-26-2016, 10:10 PM   #163
Almaretto
Almaretto's Avatar
2374
Charging at work is not cheating. Unfortunately, I do not have chargers or any outlets at work; otherwise I would as well.
My electric bill has not gone up and do not necessarily need level 2 charger cause it is always fully charged after 6-8 hours over night.
I did not like the drive of the 330e. I was looking forward to the G30 plug-in hybrid, but was think I will miss the extra HP.
_Mbition105.50
      12-03-2016, 09:59 PM   #164
admranger
Retired Curmudgeon
admranger's Avatar
Drives: ‘19 X3M40i, ‘18 m550i
I am getting mid-30's commuting 12 miles each way. No charging station at work unfortunately. On the highway at speeds with the flow of racing traffic, I get low 20's. 4k miles on it so far.
I don't like the feel of the braking at all, especially hard braking. However, I've just adjusted my following distances as best I can, but still, sometimes someone jumps in front of me and stands their car on its nose. Feeling the pedal sink to the floor more than either of my M3's is a bit disconcerting.
Still really like it a lot though. Not regretting the lease, especially in the summer when I bring a cool-ish car into the garage b/c I saved my e-drive juice for the drive home.
If I did a lot of long distance driving, I'd get the diesel or the 3.5 I think.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS
_Mbition105.50
      12-22-2016, 04:31 AM   #165
martin mustang
Ireland
257
Drives: 640d,X5 45e, 911c4s, 635csi
40 e M psort on order, expecting delievery march 2017
love the new 2017 spec, at no extra cost.
      12-24-2016, 08:02 AM   #166
thrilla
Drives: 2020 M2 CS
You're going to love it! We've owned ours for 1 week, and its been very impressive. There is a slight learning curve on how to optimize mpgs, but we're getting there.
      12-28-2016, 10:48 AM   #167
martin mustang
Ireland
257
Thanks, we went for it even without testing one as none around, but with the high taxes in Ireland and short commute for my wife to work it was by far the best option, she only managed 25k miles in 5 years with our current X3.
      02-19-2017, 08:07 PM   #168
haldol
Drives: 2017 X5 40e
Car is coming next week and just realize that the «Multifunctional Instrument Display» (S6WB) is not coming with the 40e (instead of the other X5 models).
http://www.bmw.com/com/en/newvehicle...t_display.html
      02-19-2017, 10:54 PM   #169
Almaretto
Almaretto's Avatar
2374
If you have hud, there is very little reason to look at dash. Plus, with display you are getting you can code blinkers if hud.
      04-19-2017, 03:08 PM   #170
wordsworth03
Drives: na
Does anyone have issues with the all weather cargo mat? The BMW one doesn't seem to fit well due to the extra few inches from the battery pack in the floor of the cargo area.
Also, does your car remember the last eDrive mode? If I set it to Max eDrive, it will not remember it on the next startup so I always have to push it again.
      04-21-2017, 11:54 AM   #171
haldol
Drives: 2017 X5 40e
No memory of the last eDrive mode.
      04-21-2017, 12:19 PM   #172
Almaretto
Almaretto's Avatar
2374
08
      04-22-2017, 08:58 PM   #173
wordsworth03
Drives: na
08
I looked at that. It's currently disabled - is that normal for a 40e? I would think it would be enabled on our cars.
Edit:
I should clarify - the feshasmode8 code is disabled and there is no option for fesallowmode8lastfunction, only 7 is available.
      04-23-2017, 02:18 AM   #174
Almaretto
Almaretto's Avatar
2374
Edit:
Yes, that is normal, just as it is to not see Edrive on Dash when toggling modes with DES switch.
I must have different firmware.
      04-23-2017, 12:40 PM   #175
wordsworth03
Drives: na
Yeah, I don't have that. Did you enable feshasmode8?
      04-23-2017, 01:12 PM   #176
Almaretto
Almaretto's Avatar
2374
No. But, I changed settings in KOMBI & ICMQL.
