      09-07-2014, 12:09 AM   #67
wdimagineer
wdimagineer's Avatar
Drives: 2015 X5 M
To clarify, there's no official OEM retrofit kit, but the cluster is a 100% OEM part. It wouldn't work otherwise. The poster from HK is using an OEM part, too. It might not be the actual part number specified for the F15/F16, but clusters from the F10/F11/F12 chassis are physically and electrically compatible. General availability of the actual part for the F15/F16 just happened.
The retrofit physically has been possible since the F15 launch. But coding wasn't possible because the car's software wasn't able to communicate. I believe the I-Level corresponding to 52.0 (~July?) enabled it due to the 6WB option availability in the X5/X6 and SOP of those cars. If you tried to add 6WB to your VO it wouldn't work if you were running an I-Level lower. (This I-Level was also the one that added new icons into iDrive Navigation.)
The rear carbon fiber cover has no cut out for a hitch.
      09-07-2014, 11:24 AM   #68
kip1
Drives: X5M50d
Originally Posted by jpsjr70 View Post
Thanks Omar, looking forward to your write up. wdimagineer thoughts? Also, off topic subject, does the carbon fiber rear cover work or can it work with the BMW oem hitch?
Joe
I have the mperformance diffusor + foldable hook, if that is what you mean...
      09-07-2014, 07:08 PM   #69
jpsjr70
jpsjr70's Avatar
Drives: 2015 BMW X5M
Yes, talking about Carbon Fiber Difuser and a OEM Hitch.
Joe
      09-09-2014, 02:26 AM   #70
opasha
opasha's Avatar
1331
Drives: 2014 BMW X5 50i
Just an update for everyone. I contacted Bimmer-Tech regarding when my 6WB Digital Display Cluster will be shipped and I got this response from them:
Hi Omar,
We should receive it from BMW by the end of this week so you should receive it from us by the end of next week.
Kind regards,
Patryk Matysiak
BimmerTech
Tel: (646)-439-7920 (USA)
Tel: +48 792-111-152 (Europe)
Email: info@bimmer-tech.net
Website: www.bimmer-tech.net
      09-18-2014, 06:22 AM   #71
opasha
opasha's Avatar
1331
Just another update. My 6WB cluster was shipped late night tuesday from Warsaw, Poland. It is currently in Cincinnati, OH. I should get it either by tomorrow or Saturday (hopefully). I'm going to FA code 6WB today or tomorrow into my vehicle so I get that out of the way before the cluster arrives.
      09-18-2014, 12:23 PM   #72
wdimagineer
Drives: 2015 X5 M
Do you know what I-Level you're on? If you haven't updated recently at the dealer it will likely not take.
      09-18-2014, 01:26 PM   #73
opasha
opasha's Avatar
1331
Ah, keep forgetting to check this. Thanks for reminding me . I'll take a look today at some point and reconfirm with you.
      09-18-2014, 01:46 PM   #74
cy07
cy07's Avatar
Drives: 2015 X5 50i 2016 M3
Hey WDI pmed you about the coding, but it's okay if you are busy.
Omar thanks for all the help! I can't wait to see your steering wheel retrofit and this new instrument cluster.
      09-18-2014, 01:56 PM   #75
opasha
opasha's Avatar
1331
He didn't PM me...do you mean he PMed you? Yeah, I'm a little busy right now, but I can help you out in about an hour or so.
      09-18-2014, 05:33 PM   #76
opasha
opasha's Avatar
1331
@wdimagineer, my I-Level is F025-14-03-503. This I-Level is one step below 53.0 (F025-14-07-502), which I am currently using. I checked the I-Level pdf sheet and it shows 52.3 and 52.4 match my current I-Level. Will I be ok or do I have to get the software update from BMW? This is the I-Level PDF I referenced from @shawnsheridan: http://www.bimmerfest.com/forums/att...6&d=1406976367
      09-18-2014, 07:19 PM   #77
wdimagineer
Drives: 2015 X5 M
Sorry. Been swamped. Only on here briefly.
Opasha - I'd update first. I'm not 100% certain when support was introduced. I heard 53.0.
      09-18-2014, 07:27 PM   #78
opasha
opasha's Avatar
1331
No need to apologize, my friend. Thank you for the response. Is it ok for me to try with my current I-level first just to see or will it cause errors? I want to just make sure this method is doable in case others who have similar I-levels can install without a dealer update (since these updates usually wipe all fdl coding right?).
      09-18-2014, 10:32 PM   #79
wdimagineer
Drives: 2015 X5 M
Personally I would wait. But that's just me being overly cautious.
      09-18-2014, 11:50 PM   #80
opasha
opasha's Avatar
1331
I'll call Bimmer-tech tomorrow and ask them. I totally understand what you mean. Always best to be cautious. Thanks again!
      09-20-2014, 01:53 AM   #81
wdimagineer
Drives: 2015 X5 M
Here's what to look forward to once you're done installing.
      09-20-2014, 01:55 AM   #82
wdimagineer
Drives: 2015 X5 M
2 more. Forgot how bad this app is sometimes.
      09-20-2014, 02:05 AM   #83
opasha
opasha's Avatar
1331
Thanks @wdimagineer. It looks great! I should have this done by this morning around 11-12pm and then a full installation guide with pictures will be up shortly after .
      09-20-2014, 02:36 AM   #84
Snow-Kidney
I love it. Is there a total cost on this yet?
      09-20-2014, 02:39 AM   #85
wdimagineer
Drives: 2015 X5 M
Bimmer-Tech has them available for around $1600.
      09-20-2014, 02:53 AM   #86
opasha
opasha's Avatar
1331
As @wdimagineer said, Bimmer-Tech has it. Here is the link I posted on page 2: http://www.bimmer-tech.net/shop/bmw-...panel-retrofit.
      09-20-2014, 07:42 AM   #87
1230vani
1230vani's Avatar
660
Drives: G05 40i LCI
Congrats! Does it look the same thing as in F10, any improvements, differences?
      09-20-2014, 08:11 AM   #88
skalberti
skalberti's Avatar
Drives: 2017 Mineral White M3
Has anyone tried getting these from GetBMWParts? I'm wondering if the price might be better or at least faster shipping?
It's good to be bad
