      06-21-2016, 08:53 PM   #111
critical_mass
93
Drives: Ps
Thank you!
      06-21-2016, 10:11 PM   #112
onfireX5
Drives: F90M5,F85X5M
http://f15.bimmerpost.com/forums/att...1&d=1461112958
The CAUSE listed on that document is worrisome.
      06-22-2016, 05:20 PM   #113
Luca42
Drives: AMG
Originally Posted by jcfay View Post
Please do. I'll take some snapshots of my last service order just in case there's somethere there...
Ok, got the car back yesterday. No clicking detected.
Put the car in on Monday and the car was ready on Tuesday afternoon.
My service advisor explained that this fix entailed replacing both front wheel hubs with bearings (Part No. 31-22-7-850-161). The first fix (done about a month ago) only entailed removing and resanding the original wheel hubs.
Looking at the service order, they also replaced two collar nuts (33-41-1-133-785) and eight collar screws (31-20-6-783-065).
      06-22-2016, 05:53 PM   #114
jcfay
jcfay's Avatar
Drives: 2016 BMW X5 M
Thanks man. Did your SA know what the issue was prior to you bringing the car in? I gather they had the parts in stock? I had to wait a week or more IIRC for the "spacers"...
2016 X5 M - Sapphire Black/Aragon Brown, IND Black front/side grilles/side markers
2014 C63, Klassen M52Rs, Eurocharged tune - Gone
      06-22-2016, 09:19 PM   #115
dkhm3
dkhm3's Avatar
Drives: 991.2 GT3 2020 X3MC
strange, it lists the f80 as also part of this fix. never had that issue, 17k miles.
Currently:
2018 GT3 2020 X3MC
Previously:
1999 M3 2002 M3 2005 S4 2008 C63 2015 M3 2016 X5M 2019 911S
      06-22-2016, 09:49 PM   #116
Luca42
Drives: AMG
I think the SA knew but didn't do/order anything until they had my car. I believe the parts were overnighted and the install was quick (I think a few hours -- from the moment that the SA said they received the parts to the car being ready to pick up).
The SA did say that BMW has taken a gradual approach to addressing this. Apparently the first "fix" works for some cars and delays the need for the more complete replacement fix that I just had. Accordingly, BMW directs its dealers to do the minor repair first before ordering the full replacement kits. My SA told me this the first time I came in. Unfortunately, I was back less than a month later.
      06-22-2016, 10:33 PM   #117
vince7870
Drives: 2017 x5m azurite black metalic
My truck is in now. Service manager is looking further to make sure it's not a front diff problem. I'll keep you guys updated. He's aware of everyone claiming front bearing issue. He's just going beyond to make sure it isn't diff.
      06-22-2016, 10:58 PM   #118
Alan l.
Alan l.'s Avatar
5453
Is it confirmed to be the bearing causing the clicking sound or is it the F85 two piece rotors? For those that is absolutely at the end of the straw you may want to consider swapping in the old E70 X5M rotors on since its the same exact size/fitment but its a traditional one piece rotor design (not cross drilled) The rotors are interchangeable.
Look at this article about the M5 brakes making clicking noises as they heat up and down. The X5M front rotors looks like the same design
http://m5carblog.blogspot.com/2013/02/brakes.html
"The front brakes do more work than the rears as the weight of the car shifts towards the front during hard braking and therefore there is more traction available at the front and more braking force needed there.
The steel outer ring is completely symmetrical, so when it expands due to heat it does so uniformly without introducing any bends or kinks that can rub against the brake calipers As the brakes cool you hear them "ping ping ping" as the outer disk collapses back onto the inner aluminium ring via the pins.
Alan
      06-23-2016, 05:54 AM   #119
critical_mass
93
Drives: Ps
This isn't the cooling "ping ping ping" noise. We don't hear the noise when the car is coming to a halt; only when the wheels are turning does it happen--even if I just turned the car on from overnight.
      06-23-2016, 07:47 AM   #120
Alan l.
Alan l.'s Avatar
5453
^^ gotcha. It seemed like some get the noise only after some spirited driving but since yours makes this noise on a cold car then its something else...
Alan
      06-25-2016, 09:05 AM   #121
critical_mass
93
Drives: Ps
Had the car fixed this week. So far, so good.
      06-25-2016, 10:53 AM   #122
elisiX
elisiX's Avatar
Australia
687
Drives: '20 X3M Competition
Mine is not fixed entirely.
I'd say that with the spacer fitted per the bulletin, the clicking is about 80% quieter and does not happen more when turning like it did. Now, it clicks all the time in forward motion but much quieter. Go past some parked cars or a narrow street and you can easily detect it still.
2020 BMW X3M Competition ///M - ALPINE WHITE / SAKHIR ORANGE
Past: 18' BMW M3CS | 18' BMW X5M | '17 BMW M3 Competition | '16 Mercedes GLC250 | '16 BMW X5M | '15 BMW X5 M50d | '14 Audi SQ5
      06-25-2016, 12:05 PM   #123
critical_mass
93
Drives: Ps
So now what? Do we live with this potentially dangerous fault until something really bad happens?
      06-25-2016, 08:18 PM   #124
Luca42
Drives: AMG
I agree. Got mine back on Tuesday and concur with your assessment. Much quieter but still there.
I would say that mine clicks more quietly and only when turning in a tight radius. No clicking in forward motion.
      06-28-2016, 02:43 AM   #125
DirkDiggler84
Drives: 1 m and 320 da m
Hello again. What should i demand Bmw to do? Change the wheel Bearing totally ?
Dont want to do the quickfix because from others experience it will come back.
      06-28-2016, 08:05 AM   #126
onfireX5
Looks like this is the comprehensive fix that you need.
      06-28-2016, 10:45 AM   #127
JOHN ///M
JOHN ///M's Avatar
Drives: M3
I'm having the same issue and dropped it off yesterday, currently the dealer is not willing to work on my vehicle due to aftermarket suspension, anyone have this kind of issue. Ty
'12 MW E92 M3 I Piano Black Trim I Vorsteiner Aero Front Lip I Varis Rear Diffuser I Varis Rear Skirt I Platte Forme Side Skirt I Ohlin's Road and Track Coilover I Akrapovic GT4 X-pipe I Akrapovic Slip I ESS Tuning I Brembos Brakes I Euro Front Bumper I BBS Limited Black Edition Lugs/Locks I Macht Schnell Studs I BMW Performance Carbon Fiber Spoiler I BMW Performance Grills/Gills I BMW Performance Seats I Rogue Short Shifter I BBS FI
      07-01-2016, 01:05 PM   #128
vince7870
New bearings installed noise is back!
      07-02-2016, 08:51 AM   #129
critical_mass
93
Drives: Ps
are you kidding me?? this is pathetic....at this point, i don't think i'm buying another BMW for long, long time
      07-02-2016, 08:53 AM   #130
critical_mass
93
Drives: Ps
i guess why have to look at this "problem" as not a "problem" but a "feature" to warn pedestrians that a large, heavy truck is turning.....
      07-02-2016, 02:07 PM   #131
vince7870
Yeah I'm a little pissed to say the least. Insult to injury when it was I. There last the dealer decided to ignore my wishes and have the assholes in the back wash my truck. At which point they scratched the passenger doors front and back and even into my expel coated rocker panels. I'm going to have issue addressed four times and then look to lemon law this thing. I prefer they fix the issue and I'll go on about my way, but 4 times for same issue on new car and it's staying there.
It's beyond annoying!
      07-03-2016, 10:39 AM   #132
Luca42
Drives: AMG
Vince --
I feel your pain. I think we are all in the same boat. I think the only solution is to be a thorn in your BMW dealer's side (and BMW NA, for that matter) for as long as you can and collectively, it will make it better for all owners. This is a real issue and will only grow as these cars age.
Right now, the majority of the cars are under warranty and BMW is bearing the brunt of these repairs. But as we slowly move past 4 years and 50K miles, these cars will be expensive to maintain. I don't know what the parts and labor cost, but it will not be sustainable if you have to come back in every 1000 to 3000 miles.
I had originally thought to keep this car for awhile, but now am planning to replace it before I get to that point.
Think about it, I am sitting at seven months and 9000 miles. I have had the car in twice for this issue and the clicking is back (albeit softer). The first time was clearly a temporary fix -- the clicking was back within 500 miles. Even the more substantial, second "fix" did not completely resolve the issue.
The only hope is that enough of us bring our cars in every time we hear this. Only then will it be in BMW's interest to solve the problem. The two "fixes" that I have had are not the solution.
