12-09-2013, 01:05 AM | #23 |
Rep 1,887
Wow. I've read it six times and it still makes no sense. It creates more questions than answers. Is it remote starting? If it is, why don't they just call it that? Is it a poor English translation from German? For instance... "During the startup phase the engine is protected and fuel consumption reduced by the preheated cooling circuit. " Huh? That just makes no sense. And I still don't know what the "Auxiliary Heating" option means. I really, really hope this is smart phone accessible remote starting. I hope someone with first hand experience with this can explain it to us soon. There must be a dealer out there that knows something about this.
12-09-2013, 02:36 AM | #24 |
Fragile Explosion
23
Rep 113
I understand it to be both smartphone and pre set timer activated.
My dealer said the only time it wouldn't work is when the fuel level in the car was below low level warning. Its certainly on my list to order. I think the image screenshot says a lot. |
12-09-2013, 04:54 AM | #25 |
Rep 528
The ones in Europe use fuel to warm up the engine and interior ( if I remember correctly about 0.2l for a 20 minute cycle). They are either timer or remote control activated( it is a special remote that uses radio waves and has a really long range). I am pretty sure that with connected drive you will have the option to activate it with a smart phone. It does not start engine but a small heater that runs on fuel...hope this helps
12-09-2013, 10:51 AM | #26 |
Rep 120
Remember the European's laugh at the US when it comes to idling cars (wasting fuel) for warm up. Hence, very few if any European brands offer US style remote start. The feature referenced in the above is available on most current BMWs....just go into settings and you will find the ability to schedule warm up ...it's simply an ambient draw on the battery to warm up the cabin...not sure how much it warms it...I've used it once...seems you have to schedule each day.
12-09-2013, 10:58 AM | #27 | |
Rep 537
That option has been available for a long time but I never used. Not sure where the system would get warm air from after the car is parked at -10F for an entire day.
12-09-2013, 11:29 AM | #28 |
Rep 1,887
So, based on what I'm hearing so far; it's NOT a remote start function. It's either...
a) some kind of gasoline based space heater? and/or b) some kind of battery powered heater. Neither of which sounds like a particularly good idea.
12-09-2013, 02:02 PM | #30 |
Rep 2
The aux heater is a stand alone diesel or gasoline burner with an effect of approximately 4kW that uses a small fuel consumption and battery power to heat up the water inside the cooling system at the same time as the fans in the dashboard blow the warm air into the cabin. It usually runs for 30 minutes and after that time you have a warm cabin as well as engine. You can control it by a remote or by an app in your smart phone.
Remote start of the engine? That sounds like stone age to me. I have a hard time remembering how I managed without an aux heater in my cars. It is usually a 2k USD cost for aftermarket install. More info at www.webasto.com (BMW uses this in their E70). |
12-10-2013, 02:56 AM | #32 |
Rep 172
Reading this (confusing) thread makes me so happy I live in California now instead of Minnesota, Chicago, New York, and all the other cold, wintry places I've lived where some form, any form of this feature would be helpful if only one could figure out whether or not BMW actually offers it.
12-10-2013, 01:22 PM | #33 | |
Rep 1,368
Back in Blighty its showing on the .co.uk site as an option you can opt for @ £1,130 It's strange but true but it's NOT included as part of the Cold Weather Package which is just heated seats and steering wheels @ £775. I'm fed up with scraping ice/snow off so will add it to my options. PS it's controlled via an App |
01-02-2014, 03:44 PM | #35 |
Rep 625
The Active Ventilation is Available in Canada even if you do not buy the ConnectedDrive APPS ARTII Package
You can set it manually through your settings and you can set the time up on when you want it to start and finish. It gives you two time slots for On and Off scheduled time. Last edited by originalgoods13; 01-03-2014 at 09:08 AM.. |
01-02-2014, 04:06 PM | #36 | |
Rep 518
Drives: 2024 XM Label
"During the startup phase the engine is protected, and fuel consumption reduced, by the preheated cooling circuit." Assuming that the cabin heater is as BMW describes "Auxiliary Heat" (i.e. a small add-on unit) it would work by heating the cooling fluid from the engine - the fluid that is, in turn, used to heat the cabin. Once this fluid is warm it helps protect the engine from cold start damage ("engine is protected") and reduce fuel consumption as the engine is essentially already warmed up ("fuel consumption reduced"). Bear in mind that this system is *not* "Remote Start", but timed/remote cabin heating - which is often achieved by remote engine starting, but does not necessarily require it. |
01-02-2014, 04:13 PM | #38 | |
Rep 625
I have just the Premium Package and 3rd Row Package Last edited by originalgoods13; 01-03-2014 at 09:09 AM.. |
01-02-2014, 05:43 PM | #39 | |
Rep 1,887
01-02-2014, 05:48 PM | #40 | |
Rep 1,887
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra. Last edited by MysticBlue; 01-02-2014 at 09:07 PM.. |
01-02-2014, 07:46 PM | #41 | |
Rep 1,417
Parked-car ventilation/heating http://f15.bimmerpost.com/forums/sho...d.php?t=910364 page 166, via settings or remote control ( another one) Energy source: battery and gas Note Parked-car heating in enclosed areas Do not operate the parked-car heating in enclosed areas, as breathing of the harmful exhaust fumes may lead to loss of consciousness and death. The exhaust gases contain carbon monoxide, an odorless and colorless but highly toxic gas. Switch off the parked-car heating when refueling. Edit: Jan 3, 2014, this post refers to auxiliary ventilation only. Auxiliary heating, is an option as discussed by others in their posts. Last edited by barcelona; 01-03-2014 at 02:11 PM.. Reason: clarification |
01-02-2014, 09:09 PM | #42 | |
Rep 428
01-03-2014, 05:43 AM | #43 |
Rep 1,417
01-03-2014, 09:16 AM | #44 |
Rep 625
You can activate the Active Comfort Ventilation before you get out of your vehicle and set the in-cabin temperature to your liking (when running quick errands, etc...)
I am trying to set my ConnectedDrive and it is taking quite some time with BMW Assist to configure and Activate my Account on their end. I am hoping I can use the iPhone App BMW Remote to control Active Comfort Ventilation even if I do not have the ConnectedDrive ARTII Package |
