10-20-2016, 04:11 PM | #23 |
156
Rep 346
10-21-2016, 03:38 PM | #24 |
Rep 3,834
Drive to 80mph, slams on brake, it's solved for a week. Otherwise you dealer can sand down the rotors and pads, which could help too.
10-21-2016, 05:59 PM | #25 |
Rep 710
Let's see what my dealer says about this...
Cars: 2016 BMW X5M. 2017 BMW X1.
Bikes: 2007 BMW F650GS. 2014 BMW K1600GTL Exclusive. 2014 BMW HP4 Competition. 2016 BMW K1300S. |
10-21-2016, 10:48 PM | #26 |
Hooligan
55
Rep 680
dont slam on the brakes. it will ruin the rotors.
2014 Porsche Cayenne Turbo S 2011 X5 5.0 Dinan - SOLD 2007 Imola Red Z4 M Coupe -SOLD 2004 Navy Blue BMW 325Ci |
10-24-2016, 01:37 PM | #28 |
Rep 710
Dealer confirms new brake pads exist and has ordered a set for me.
10-24-2016, 08:53 PM | #29 |
Rep 165
Let me be more clear. Fattmatts advice about not slamming on the brakes is WRONG and clueless. These brakes can withstand track abuse. Most here will only drive their M on the street and the brakes should handle anything that you could sanely throw at them on the street. Slam them at 100 mph and your rotors will be fine. Why fattmat would say this? |
10-24-2016, 10:15 PM | #30 |
Hooligan
55
Rep 680
Experience. I have a Cayenne Turbo S with brakes and rotors that are as big if not bigger than what is on the X5M. They are also manufactured by Brembo. They can be warped. I made the mistake of listening to the same advice you've given, only it was given by a porsche dealership tech, and subsequently had my rotors replaced at dealership expense. They were also kind enough to install the aftermarket brake pads I purchased. Haven't heard a peep out of the brakes since then. Best part is, I haven't had to drive like a jackass to accomplish that.
Pads are cheap, rotors are not. My advice to fix your squealing brakes is to buy pads with less steel in them. It's an immediate fix which doesn't require one to break the law and engage in dangerous behavior. It's worth the 2-3 hours of labor you might pay to have the pads installed. By the way, do you think it's reasonable to expect someone to do what your advocating merely to get the brakes on a $100,000 vehicle to stop squeeling? I don't. Personally, I think when you pay that much for a car, it's perfectly reasonable to expect that one can just get into the car and drive it without it sounding like freight train, but that's just my opinion. You are free to drive 100 mph and slam on the brakes as you see fit, arrivederci.
10-24-2016, 10:45 PM | #31 | |
Rep 165
Noisey brakes are likely due to brake pad choice (as you said). While you also say that it is unacceptable, why did you provide different pads for your Porsche? Was that not a 100k+ vehicle too? Why didn't the dealer 'fix' it for you by providing alternate pads? So many questions. Audi says the same thing in their s cars about noisey brakes...even has a brochure to make it seem ok to people complaining. Reality is that there's a trade off for changing to different pads. I don't think you know much more than what you read on boards or the dealer tells you. No offense intended as most people that buy 100k cars won't or don't turn wrenches on them or anything else. What I want others to understand is that slamming brakes on an x5m or car with similar brakes is no big deal. They are designed for it. Btw, brake pad install should take less than 1 hour. |
10-24-2016, 10:56 PM | #32 |
Hooligan
55
Rep 680
You know what, I think you definitely must be right. The best solution for these squeaky pads is to drive 100 mph and slam on the brakes as hard as you can. Seems reasonable.
10-24-2016, 11:38 PM | #33 |
Rep 165
Reading comprehension not your forte? You said slamming the brakes will ruin the rotors. I said not true...the x5m should be fine. I also agreed with your point that changing the pads could quiet the brakes down. Wrong pads though could make them even louder.
magzx12r0.00 |
10-24-2016, 11:59 PM | #34 |
Rep 18,683
Don't get eaten by brand name.
Brembo do OEM and not all manufacturers get the same exact setup from Brembo. Oh and rotors, a lot of car manufacturers opted to get them from different vendors, like the 2 car manufacturers that you guys are mentioning.
Xtremery33.50 |
11-07-2016, 01:28 PM | #35 |
Rep 710
Here's the info on the new pads from my invoice:
New Pads Ordered Per SIB 34 08 16. 34-11-7-852-969 REPAIR KIT, BRAKE PADS
AwesomeM31639.00 |
11-08-2016, 02:17 PM | #36 |
Rep 2,775
Drives: F95 X5MC
Great info, thanks!
2020 F95 X5///M Competition CarBahn Autoworks Stage 1 | 2023 Lamborghini Huracan Tecnica
11-10-2016, 02:01 PM | #37 | |
Rep 710
Dealer says they will install aftermarket pads for me, so now the hunt begins.
11-10-2016, 02:15 PM | #38 |
Rep 2,245
Drives: '16 991.1 911 GTS, '16 F85 X5M
What a debacle.
2016 991.1 911 Carrera GTS
2016 F85 X5M - Carbon Black/Mugello Red |
11-10-2016, 02:23 PM | #39 |
Rep 710
I think I'm going to try these:
http://www.brakeworld.com/Product/Pr...ds-Front-D1429 http://www.brakeworld.com/Product/Pr...Pads-Rear-D919
11-10-2016, 02:40 PM | #40 | |
Rep 2,245
11-10-2016, 06:27 PM | #41 |
Rep 710
I don't know, but I'm going to replace them all so they match (and are hopefully all silent.)
11-10-2016, 10:45 PM | #42 |
Rep 710
I ordered the full set of Disc Italia ceramics. Will lose a bit of braking power but a) I don't track my car or drive it super aggressively often, and b) I'm happy to trade that for less dust and squeal.
Will report back my results in a couple of weeks once they are installed.
11-14-2016, 12:57 PM | #43 | |
Rep 2,245
11-14-2016, 01:44 PM | #44 |
Rep 710
My brakes don't really squeal when the roads are wet. As soon as they dry off, the pain returns!
